Krice58 181 #1 Posted November 21, 2025 Got a leaky lift valve on the C160 and so I ordered the o-ring kit to seal it up. Anything to know about this job? Or is it pretty straightforward? I hate messing with the hydro system. From what I’ve gathered I read about keeping track of Mylar shims. I’d be curious to see what the inside of the valve looks like before I tear into it but I can’t find any pictures or diagrams of it disassembled, just the parts list which shows the whole valve. Also have an extra valve off of ‘77 C160 that looks the same, I would assume it would be interchangeable as a spare. Also have the lift cylinder on the ‘77 that has the snap ring instead of being welded shut. Does that replace the welded one if I need to swap it out at some point? Any input would be appreciated. IMG_8922.webp Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,481 #2 Posted November 21, 2025 An older manual 1 1 Share this post Link to post Share on other sites
Krice58 181 #3 Posted November 21, 2025 2 hours ago, gwest_ca said: An older manual Doesn’t look too bad. That’ll be this weekends job 2 Share this post Link to post Share on other sites
ebinmaine 80,488 #4 Posted November 21, 2025 4 hours ago, Krice58 said: Doesn’t look too bad. That’ll be this weekends job Pics would be neat! 1 Share this post Link to post Share on other sites
Krice58 181 #5 Posted November 21, 2025 14 minutes ago, ebinmaine said: Pics would be neat! Will do! Probably tear into it tomorrow 1 Share this post Link to post Share on other sites
Krice58 181 #6 Posted November 22, 2025 (edited) Came apart easy enough. Just gonna clean it up, replace the o rings and put it back together. Did not see any Mylar shims. The document does say “if used” so maybe some don’t have them? Edited November 22, 2025 by Krice58 1 2 Share this post Link to post Share on other sites
kpinnc 18,916 #7 Posted November 23, 2025 Those old style valves work so much better than the newer squealers. Smoother, slower, and quiet. If I ever have an excuse to go back into my center console on either of my 520s, I'm gonna swap those new ones out. 1 Share this post Link to post Share on other sites
oliver2-44 11,718 #8 Posted November 23, 2025 (edited) Put a little wheel bearing or heavy grease in the groove to help hold the O-rings as you assemble it. Edited November 23, 2025 by oliver2-44 Share this post Link to post Share on other sites
Handy Don 17,400 #9 Posted November 23, 2025 13 hours ago, kpinnc said: Those old style valves work so much better than the newer squealers. Smoother, slower, and quiet. If I ever have an excuse to go back into my center console on either of my 520s, I'm gonna swap those new ones out. Maybe not a good idea. The old valves were only on the Sunstrand hydros which had pressure relief valves built into the charge pump. The Eatons required external pressure relief so the relief valves are built into the control valve. To use the old valve on an Eaton, you’d need to plumb in a separate pressure relief valve and, coincidentally, these are the usual source of the squeal! (I suspect the Sunstrand's design of its pressure relief valve inhibits squeal.) As a side note, the correct terminology for all the stock WH valves is “Tandem Center”, not “Open Center.” Tandem Center valves block flows to/from the cylinder when the control is centered, which locks the implement in position. Open Center valves permit flows to/from the cylinder when centered. This lets a raised implement fall (or a lowered one be pushed up) by external forces (gravity, uneven ground, etc.) . On a couple of WH models, GT-14 and C-195 that I know of, the valve's “float” position is the equivalent of “Open Center” Share this post Link to post Share on other sites
kpinnc 18,916 #10 Posted November 24, 2025 11 hours ago, Handy Don said: Maybe not a good idea. The old valves were only on the Sunstrand hydros which had pressure relief valves built into the charge pump. Well... Crap! 1 Share this post Link to post Share on other sites
Handy Don 17,400 #11 Posted November 24, 2025 8 minutes ago, kpinnc said: Well... Crap! I put in a separate PR valve when I added two remote circuits to our Eaton 500 tractor. Tricky fitting it in and routing the plumbing. 1 Share this post Link to post Share on other sites
mowboy 12 #12 Posted November 27, 2025 I have a control valve to put back together after the previous owner took apart. The IPL here shows a "special washer" is it one of the two in the pic attached? So shoulder screw goes thru spring retainer cap, thru spring and threads into push rod. Is there tension on the spring when this is all together? Thanks for your help! and Happy Thanksgiving! Share this post Link to post Share on other sites
Krice58 181 #13 Posted November 27, 2025 6 hours ago, mowboy said: I have a control valve to put back together after the previous owner took apart. The IPL here shows a "special washer" is it one of the two in the pic attached? So shoulder screw goes thru spring retainer cap, thru spring and threads into push rod. Is there tension on the spring when this is all together? Thanks for your help! and Happy Thanksgiving! I did not see any “special washer” when I disassembled mine but I did not remove the spring from the piston so I would imagine it sits behind that. The top black washer/clip should be for connecting the handle to the piston which applies pressure to the spring when moved back and forth. Share this post Link to post Share on other sites
mowboy 12 #14 Posted November 27, 2025 do you remember if there is washer, like the silver on in my first picture, that fits at the end of the spring- see new picture. That would put tension on the spring, I guess. Thanks! Share this post Link to post Share on other sites
ineedanother 2,850 #15 Posted November 30, 2025 On 11/27/2025 at 11:18 AM, mowboy said: do you remember if there is washer, like the silver on in my first picture, that fits at the end of the spring- see new picture. That would put tension on the spring, I guess. Thanks! Yes, there should be. Share this post Link to post Share on other sites
mowboy 12 #16 Posted December 1, 2025 Thank You! (from an hour down the road) 1 Share this post Link to post Share on other sites
