ebinmaine 80,067 #1 Posted November 18, 2025 This was with a bench grinder we just got from an auction. It has 4 separate "gear" rollers? that move independently of one another. A stone dressing tool of some sort? 2 Share this post Link to post Share on other sites
Bar Nuthin 2,926 #2 Posted November 18, 2025 (edited) That's a dressing tool for your grinding wheels. To true up the face of the stone. Best if you have a solid guide you can rest against to stay flat with the face of the stone. Edited November 18, 2025 by Bar Nuthin 10 1 1 Share this post Link to post Share on other sites
Ed Kennell 46,793 #3 Posted November 18, 2025 I have better results using the single diamond point dresser. Working the stop against the grinder work rest. 1 1 1 Share this post Link to post Share on other sites
ebinmaine 80,067 #4 Posted November 18, 2025 2 hours ago, Bar Nuthin said: solid guide you can rest against Here's the machine. Two solid guides. Two different stones at two different angles. 1 hour ago, Ed Kennell said: I have better results using the single diamond point dresser. Working the stop against the grinder work rest. I have a couple much smaller dressing tools made from square stock coated with diamond grit. Never used a round ended one. 2 1 Share this post Link to post Share on other sites
formariz 12,381 #5 Posted November 18, 2025 (edited) Curiously I never liked using either type. I use and have great results using an old used diamond cutting saw blade. I find it easier to control and more versatile being able to use the very tip or the sides. Easier to control with faster results. Edited November 18, 2025 by formariz 5 4 Share this post Link to post Share on other sites
ri702bill 12,688 #6 Posted November 19, 2025 Similar to the one I have... I did have to disassemble it to add a washer spacer at one end of the stack to limit the amount of "wander" the wheels had. That improved the wheel finish. I thought for a minute that the wheel on the right of your grinder was green, not gray. Green is for dressing carbide - and that wheel is expensive... 1 Share this post Link to post Share on other sites
JoeM 10,120 #7 Posted November 19, 2025 Not much for stone wheels, installed a 6 inch flap disc. It self levels. I really have no need to sharpen tooling tho. About once a year I can reinstall a wheel and do the saved up bits etc, and have a session. 4 Share this post Link to post Share on other sites
ebinmaine 80,067 #8 Posted November 19, 2025 39 minutes ago, JoeM said: Not much for stone wheels, installed a 6 inch flap disc. It self levels. I really have no need to sharpen tooling tho. About once a year I can reinstall a wheel and do the saved up bits etc, and have a session. Interesting thought. I could do that too. What grit wheel do you use? Share this post Link to post Share on other sites
lynnmor 8,966 #9 Posted November 19, 2025 Your wheel dresser may need new star wheels. This type of dresser works well if you are grinding things that quickly load up the wheel, they quickly clean and true the wheel but the dust can be incredible. 3 1 Share this post Link to post Share on other sites
ri702bill 12,688 #10 Posted November 19, 2025 (edited) 22 minutes ago, ebinmaine said: Interesting thought. I could do that too. What grit wheel do you use? The one slightly less abrasive than the temperament of an ex-wife!! Edited November 19, 2025 by ri702bill 2 Share this post Link to post Share on other sites
ri702bill 12,688 #11 Posted November 19, 2025 Your wheel dresser may need new star wheels... Yup. Those wheels wear as does the stone wheel. 1 Share this post Link to post Share on other sites
ebinmaine 80,067 #12 Posted November 19, 2025 1 minute ago, ri702bill said: The one slightly lass abrasive than the temperament of an ex-wife!! So like a grit of. ... 14? 2 Share this post Link to post Share on other sites
ri702bill 12,688 #13 Posted November 19, 2025 3 minutes ago, ebinmaine said: So like a grit of. ... 14? Nope - coarser than that!! 2 Share this post Link to post Share on other sites
JoeM 10,120 #14 Posted November 19, 2025 I have an 80 on it now but 40 is best for what I do. Got to check to see if the wheel comes with spacer bushings to fit the grinder shaft, I had a set from before and can't remember is these came with or without. 1 2 Share this post Link to post Share on other sites
8ntruck 9,171 #15 Posted November 19, 2025 Check to make sure you are not going to exceed the max rpm on the flap wheel. 'Ring' your stone wheels before mounting to confirm they are not cracked. 1 1 Share this post Link to post Share on other sites
ebinmaine 80,067 #16 Posted November 19, 2025 7 hours ago, JoeM said: best for what I do. What's your average usage for a bench grinder? Share this post Link to post Share on other sites
JoeM 10,120 #17 Posted November 19, 2025 26 minutes ago, ebinmaine said: What's your average usage for a bench grinder? I debur metal stuff, edges, holes etc. the flap works real nice for sharping axes, mower blades too. I did use it some on small parts to take off some paint along with a wire wheel on the other side of the grinder. Kind of the clean up center. 2 Share this post Link to post Share on other sites
ebinmaine 80,067 #18 Posted November 19, 2025 25 minutes ago, JoeM said: I debur metal stuff, edges, holes etc. the flap works real nice for sharping axes, mower blades too. I did use it some on small parts to take off some paint along with a wire wheel on the other side of the grinder. Kind of the clean up center. Pretty much identical to our usage here. Definitely a worthwhile looksee into the flapper for me. Share this post Link to post Share on other sites
MainelyWheelhorse 3,008 #19 Posted November 19, 2025 @ebinmaine I’d put a wire wheel on one side. I’ve used my father’s more times than I can count to clean up bolts, parts and to de paint parts. It really comes in handy 1 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,973 #20 Posted November 20, 2025 13 minutes ago, MainelyWheelhorse said: @ebinmaine I’d put a wire wheel on one side. I’ve used my father’s more times than I can count to clean up bolts, parts and to de paint parts. It really comes in handy 1 Share this post Link to post Share on other sites
ebinmaine 80,067 #21 Posted November 20, 2025 24 minutes ago, MainelyWheelhorse said: @ebinmaine I’d put a wire wheel on one side. I’ve used my father’s more times than I can count to clean up bolts, parts and to de paint parts. It really comes in handy 10 minutes ago, SylvanLakeWH said: Oh I have a couple already. I may have a bench grinder hoarding problem too. This is number four. Four different sizes. 2 Share this post Link to post Share on other sites
8ntruck 9,171 #22 Posted November 20, 2025 (edited) Got to remember that wire wheels can grab a part out of whatever you were holding it with and throw it in into an orthogonal dimension never to be seen again quicker than you can believe Edited November 20, 2025 by 8ntruck 1 Share this post Link to post Share on other sites
ebinmaine 80,067 #23 Posted November 20, 2025 21 minutes ago, 8ntruck said: Got to remember that wire wheels can grab a part out of whatever you were holding it with and throw it in into an orthogonal dimension never to be seen again quicker than you can believe I've done this. And I've learned. And I've done it again and again. So obviously I've learned nothing. 1 Share this post Link to post Share on other sites
wallfish 20,375 #24 Posted November 20, 2025 19 minutes ago, 8ntruck said: Got to remember that wire wheels can grab a part out of whatever you were holding it with and throw it in into an orthogonal dimension never to be seen again quicker than you can believe I believe they go wherever those lost socks from the dryer go! Or, maybe with those little springs that are never seen again once they fly out. No one ever finds random socks or springs once they're lost. 2 Share this post Link to post Share on other sites
ebinmaine 80,067 #25 Posted November 20, 2025 1 minute ago, wallfish said: I believe they go wherever those lost socks from the dryer go! Or, maybe with those little springs that are never seen again once they fly out. No one ever finds random socks or springs once they're lost. Or the little steel balls from the shifter forks. Share this post Link to post Share on other sites
