NCSteve 24 #1 Posted November 18, 2025 I have owned my 1976 C120 now for 30 minutes! I bought it to do some driveway leveling, so now I need to start researching blades and blade attachments. The tractor appears sound, and it starts and runs ok, but it moves very slowly. I need to explore belt, clutch spring, etc. I think. Any suggestions for reasonably priced blades would be welcomed! 2 4 Share this post Link to post Share on other sites
WHX?? 57,810 #2 Posted November 18, 2025 Steve Nice lookin and should serve you well. For grading and leveling driveways a mid mount blade will be at the top of the list. Unfortunately they are (sometimes) hard to find and can (sometimes) be somewhat pricy if you do. Never know tho. Next would be a front blade for back dragging and such. Third on the list is a back blade or a mini box scraper. Back blades can suffer from lack of down pressure. Others will be along to welcome and offer advice on ground engaging implements. 2 Share this post Link to post Share on other sites
8ntruck 9,219 #4 Posted November 18, 2025 to the forum. The C120 is a very capable machine. It should handle driveway grading just fine. As far as the tractor moving very slowly, you need to know that it has a two range transmission. When in low range, high gear is just a tad faster than 1st gear in high range. 1st gear in low range is about 1 mph - maybe. The short shift lever that moves right and left is for selecting high or low range. Left for low, right for high. In your picture, it looks like it might be in the low range position. The shifter fork on the high/low range shifter can be damaged if you use excess force on it. Good luck and have fun with your recently acquired toy, no, tool. Check out the manuals section of the forum. You will probably find an owner's manual for your machine there. 3 Share this post Link to post Share on other sites
953 nut 68,529 #5 Posted November 18, 2025 In your photo I can see that the High-Low range lever is in the Low position. The attached owner manual should be helpful. 3 4 Share this post Link to post Share on other sites
Achto 32,347 #6 Posted November 18, 2025 As mentioned above center blades and dozer/snow blades can be found, might have to do a little searching. I you want instant gratitude, you can go with a Brinly box scraper. https://www.tractorsupply.com/tsc/product/brinly-38-in-box-scraper-and-rear-blade-bs-381-2-in-1-tool-for-versatile-landscaping-2523107 You will also need a Brinly hitch adaptor. https://wheelhorsepartsandmore.com/product/toro-wheel-horse-slot-hitch-adapter/ 5 Share this post Link to post Share on other sites
Ed Kennell 46,997 #7 Posted November 18, 2025 (edited) to the The C-120 is a great worker. Yes, try to shift it to High range. Don't force it, it may help to put it in 1st gear and rock the tractor while you apply pressure to the HI/Low shifter. Edited November 18, 2025 by Ed Kennell 4 Share this post Link to post Share on other sites
NCSteve 24 #8 Posted November 19, 2025 Thank you all for the kind welcome and good advice. I can easily shift into all the gears in both H and L range. I think the belt is the problem.It is very loose and looks ancient! I will replace that first. 3 Share this post Link to post Share on other sites
parsonsponyz 401 #9 Posted November 19, 2025 That looks like a nice, capable machine. I believe you are on the right track checking the belt first and then go from there. Share this post Link to post Share on other sites
ebinmaine 80,323 #10 Posted November 19, 2025 11 hours ago, NCSteve said: Thank you all for the kind welcome and good advice. I can easily shift into all the gears in both H and L range. I think the belt is the problem.It is very loose and looks ancient! I will replace that first. Also replace the idler. For the belt ... some folks have okay luck with aftermarket belts. I have not. I use only WH belts. And ..... 1 Share this post Link to post Share on other sites
NCSteve 24 #11 Posted November 19, 2025 Thanks to all. I found a Brinly rear scraper blade for $100, so I will probably start with that and the Wheel Horse sleeve hitch. I will see how that works for driveway work and go from there. 1 2 Share this post Link to post Share on other sites
ebinmaine 80,323 #12 Posted November 19, 2025 5 minutes ago, NCSteve said: Thanks to all. I found a Brinly rear scraper blade for $100, so I will probably start with that and the Wheel Horse sleeve hitch. I will see how that works for driveway work and go from there. Once you get the "feel" for it you'll be happy with that. Be aware of downward tension and the possibility of needing extra weight. And please post more pics!!! Share this post Link to post Share on other sites
Racinbob 13,111 #13 Posted November 20, 2025 I'm onboard with Eric on the drive belt. You're best to just use a Toro belt. Do a search for Wheel Horse (or Toro) 7473. Also like he said the idler can be suspect. Make sure it's good or just replace it. Then there's the spring. I've seen many replaced with something close from the hardware store. That's a no no. While you're searching for the belt also search for a 108035. I always try to keep a couple spares on the shelf. Once you've addressed those items and you have it working well you can go on to tweak the linkage if you'd like to but I've found that unless there's excessive wear it's really not needed. 1 1 Share this post Link to post Share on other sites
953 nut 68,529 #14 Posted November 20, 2025 5 minutes ago, Racinbob said: Do a search for Wheel Horse (or Toro) 7473. Some sellers list the Wheel Horse part number fore a knock-off belt that is wider than 5/8" and will not be correct for your tractor. 2 Share this post Link to post Share on other sites
ebinmaine 80,323 #15 Posted November 20, 2025 2 hours ago, 953 nut said: Some sellers list the Wheel Horse part number fore a knock-off belt that is wider than 5/8" and will not be correct for your tractor. Definitely a good point. Anytime you see the word, replaces, or fits, it doesn't... 1 1 Share this post Link to post Share on other sites
Racinbob 13,111 #16 Posted November 20, 2025 Yup, ya gotta watch that and make sure you get the real thing. The 7473 I just replaced on my 76 this summer was genuine and actually measured a fuzz under 5/8". The TSC blue belt was right on but was a tad shy of seating in the pulley properly. 2 Share this post Link to post Share on other sites
NCSteve 24 #17 Posted December 14, 2025 Here is my solution to the transport problem: two 5/8" x4" carriage bolts, six washers. two nuts, two spring clips,and two wheels with pneumatic tires borrowed from my hand truck. It works great! 5 Share this post Link to post Share on other sites
