BradKahler 34 #51 Posted 7 hours ago 50 minutes ago, ri702bill said: Yup, sorry to say, but the special full dog point 1/4-20 shifter retainer screw IS broken off and must be dealt with... The unbroken one would protrude out of the boss by about 3/8" to accept a hex nut to set the adjustment. SOMRTIMES, you can get lucky drilling it with a left-handed bit, the size for a screw extractor, aka Easy-Out. Your next task!!! I was afraid it was broken It looks like a good candidate to weld a nut on the end. Any idea if that has been tried before on this bolt? I've used the weld a nut process multiple times in the past with pretty good success. 1 Share this post Link to post Share on other sites
BradKahler 34 #52 Posted 7 hours ago 17 hours ago, WHX?? said: Ideally a bearing collar behind the very inboard side of the hub. Pic below is another method but yes as mentioned be carful since you will have the more fragile "star" hubs. Being a neub you probably don't have a spare junk hub tho. You can try the puller you pictured but with extreme caution. If it don't feel like its gonna go lightly don't push it. 2nd pic ask me how I know. My way now is to try and get what appears to be the easiest one to get off. Then split the cases which allows one to disassemble the differential and get the other axle out and to a press. getting hitch pins out and hubs off are a rite of passage here. Any issues STOP ...set the wrench down and slowly step away ... and use a shout out. That is great advice...I just wish I was better at following it 1 Share this post Link to post Share on other sites
BradKahler 34 #53 Posted 7 hours ago 12 minutes ago, stevasaurus said: That manual has excellent step by step instructions on how to open up that trasmission. You do need to get the shifter out first. Here is another thread that has videos of the process. This video is for a 4 speed which means the brake drum is on the cluster gear shaft instead of the mushroom gear. The only difference between your trans and the video thread. Check this out. I was wondering if the shifter had to come out before splitting the case. Thanks for confirming. I'll watch the videos this evening to give me a feel for what I'm getting into. Thanks! 1 Share this post Link to post Share on other sites
702854boy 308 #54 Posted 6 hours ago 1 hour ago, BradKahler said: That is great advice...I just wish I was better at following it Did you break something? Share this post Link to post Share on other sites
BradKahler 34 #55 Posted 4 hours ago 1 hour ago, 702854boy said: Did you break something? Not this time, but I can guarantee that I've broken things in the past. 1 Share this post Link to post Share on other sites
BradKahler 34 #56 Posted 3 hours ago Today turned out to be a productive one. I had no problems getting the case split and you can see from the pictures the transmission is really grungy inside. There was no metal debris inside at all, other than the water and oil that created that grunge. I've started cleaning the parts in my ultrasonic cleaner and so far I'm really happy with the results. The first batch of parts spent about 58 minutes in the cleaner. Tomorrow I'll need to clean out the ultrasonic cleaner and then I'll run all the parts through it again. I'm not sure yet how I'm going to clean the two cases. I think they are to big to fit in the cleaner so I may end up using a pressure washer for the first pass and then figure out what to do after that. Making progress 1 Share this post Link to post Share on other sites
702854boy 308 #57 Posted 3 hours ago Yikes, good thing you are going through all of that 1 Share this post Link to post Share on other sites
953 nut 62,445 #58 Posted 2 hours ago 14 minutes ago, BradKahler said: pressure washer for the first pass and then figure out what to do after that. Pressure washer and a small wire brush should do the trick. If you haven't visited Lowell's site for the parts you'll need here is a link. https://wheelhorsepartsandmore.com/product/base-kit-1-for-manual-transmission/ Your 1533 bearings ( the big ball bearings on the inner end of the axle) will probably clean up and be able to be reused, if not he sells them too. Share this post Link to post Share on other sites
ri702bill 10,169 #59 Posted 2 hours ago (edited) So far, so good! Do check the condition of the 2nd / 3rd gear. The third gear side has the row of drilled holes that should not show excessive wear... That is waht causes the Unidrive to jump out of high gear. New reproduction gears are available thru Lowell too. Edited 2 hours ago by ri702bill Share this post Link to post Share on other sites
