lynnmor 9,081 #26 Posted November 18, 2025 1 hour ago, heysavoy said: Working on that now. I thought I remembered a flat - spring of some type that sat under the plate and pressed against the control lever is to keep the lever in position. But perhaps I'm wrong. Thanks You are correct, there is a wave washer (flat spring) that keeps tension on the cam plate. You adjust the nut on top till you get enough drag to hold it in place. The special washers above and below the cam plate are hardened but they still wear. That wear can be corrected by sanding or grinding them flat, of course they can be flipped to get two uses out of them. 2 Share this post Link to post Share on other sites
