Farmer Forbes 5 #1 Posted 20 hours ago Hello everyone, Need to replace the axle oil seals on a 1975 C-100 (Model 1-0391) WH tractor. Unfortunately the wheel hubs are both rusted fast or the key has created an obstruction and will not allow the hub to move. Anyone have any experience removing these to be able to reach the seal? Share this post Link to post Share on other sites
oliver2-44 10,990 #2 Posted 20 hours ago Removing Wheel Horse rear hubs is one of the more challenging task on these tractors. 1st. Do not use a 3 jaw puller on the outer flanges of the hub You will break them. Remove the square head bolt that locks the hub to the shaft. Starting soaking it with a good penetrant like Kroil for several days. Here's a thread with several hub pullers shown. The key is to use a puller that goes behind the hub and pulls as close to the shaft as possible. 2 2 Share this post Link to post Share on other sites
ri702bill 10,125 #3 Posted 19 hours ago (edited) A last resort is to remove the Unidrive and split the case. This allows you to disassemble the differential, remove the axle side gears and remove the axles / hubs as assemblies. Then use a 20 ton hydraulic press to get the hubs off..... ask me how I know.... Edited 4 hours ago by ri702bill 2 Share this post Link to post Share on other sites
Handy Don 14,742 #4 Posted 18 hours ago 6 minutes ago, ri702bill said: A last resort is to remove the Unidrive and split the case. Thiss allows you to disassemble the differential, remove the axle side gears and remove the axles / hubs as assemblies. Then use a 20 ton hydraulic press to get the hubs off..... ask me how I know.... This is how my hubs got removed--and it taxed the press to its max. 1 hour ago, oliver2-44 said: Do not use a 3 jaw puller on the outer flanges of the hub You will break them. You may ask how this could be so--the hubs seem so strong and beefy? 3-jaw pullers are stronger. ‘Nuf said. 3 Share this post Link to post Share on other sites
ri702bill 10,125 #5 Posted 18 hours ago (edited) I made this one for pulling C series hubs. Still did not budge the one I had to split the case on..... Edited 16 hours ago by ri702bill 4 1 Share this post Link to post Share on other sites
pfrederi 19,006 #6 Posted 18 hours ago The joys of hub pulling...... 2 1 Share this post Link to post Share on other sites
ri702bill 10,125 #7 Posted 18 hours ago And do not even consider using a slider hammer puller! It will defeat the large snap ring the holds the side gear on the axle; the axle & hub WILL exit the Unidrive, leaving you no other option except to split the case as described above to reassemble... 2 Share this post Link to post Share on other sites
JoeM 8,940 #8 Posted 17 hours ago I have set a map gas torch on the floor pointed at the hub for ten minutes or so with the puller in place snugging it and giving the head of the puller bolt a love tap. Your changing the seal anyway so the heat is not an issue there. I use an old hub that I drilled out the threat to allow the 7/16 bolts to pass through. 3 1 Share this post Link to post Share on other sites
lynnmor 8,103 #9 Posted 17 hours ago With that set screw removed, look in the hole to see if the axle might have rotated in the hub, some times it isn't just the rust and pulling against a key that is rotated into a wear spot is next to impossible. Keep applying the penetrating oil. I will be going thru Spring Grove next Thursday and I have a puller that should work. Send me a PM if that is something you might want. 2 Share this post Link to post Share on other sites
OutdoorEnvy 1,786 #10 Posted 17 hours ago I agree with the highly soaking it in the keyway hole as much and long as possible. Once you decide on a puller you are using if it isn't coming off and you feel you have a lot of force pulling on it. You can try tapping around the hub by the axle with a hammer or similar, not hard though. I had a stubborn one break by doing that when I was afraid to keep cranking on the puller. Good luck...stick with it...once you get one or two it's not as intimidating as the first 1 Share this post Link to post Share on other sites
kpinnc 15,778 #11 Posted 17 hours ago 20 minutes ago, ri702bill said: And do not even consider using a slider hammer puller! It will defeat the large snap ring the holds the side gear on the axle; the axle & hub WILL exit the Unidrive, leaving you no other option except to split the case as described above to reassemble.. Not to mention you will likely strip the edge that the retaining ring holds onto, effectively requiring machine shop work to fix or purchase another axle to repair. 2 1 Share this post Link to post Share on other sites
Bar Nuthin 1,506 #12 Posted 17 hours ago We had to remove the hubs from my neighbor's B-100. We ended up using a junk hub that I had and some long through bolts to make a puller. I had an impact socket just slightly smaller than the1/8" axle on the one end and large enough to not pass through the donor hub on the other end. Then in rotation, we tightened down the through bolts. After giving up on penetrating oil, we resorted to heating the hubs and melting crayons into it. Let it cool, repeat about 5 times. Each time tightening the through bolts. On about the 5th attempt, we got some movement and off it came. 3 Share this post Link to post Share on other sites
peter lena 9,474 #13 Posted 16 hours ago @Farmer Forbes have any KROIL PENETRATING OIL ? personally would remove the set screws , and get some kroil in all related areas , would also drive it around to enhance the lubrication creep , those hubs need lots of help in removal . never too early to get lube in the , set screw area , sitting at 12 o clock . so it can show you any soaking gain , pete 3 Share this post Link to post Share on other sites
953 nut 62,306 #14 Posted 15 hours ago 2 hours ago, ri702bill said: do not even consider using a slider hammer puller! It will defeat the large snap ring the holds the side gear on the axle; the axle & hub WILL exit the Unidrive, 2 hours ago, kpinnc said: Not to mention you will likely strip the edge that the retaining ring holds onto, effectively requiring machine shop work to fix or purchase another axle to repair. Been there Done that Don't Do That! 1 2 Share this post Link to post Share on other sites
Ed Kennell 43,152 #15 Posted 12 hours ago All good advice. Do remove the hub locking bolts and make sure there isn't a second set screw in the hole. 1 2 Share this post Link to post Share on other sites
Lane Ranger 11,637 #16 Posted 6 hours ago (edited) 10 hours ago, peter lena said: @Farmer Forbes have any KROIL PENETRATING OIL ? personally would remove the set screws , and get some kroil in all related areas , would also drive it around to enhance the lubrication creep , those hubs need lots of help in removal . never too early to get lube in the , set screw area , sitting at 12 o clock . so it can show you any soaking gain , pete If you use Kroil Penetrating Oil be extremely careful about getting this on your skin, face or eyes. This stuff is pretty toxic. I have used before and it does break down rust but it is dangerous to your body if you get it on you- clean it off fast! https://www.kroil.com/wp-content/uploads/2022/11/AEROKROIL-NA-GHS-9-4-24.pdf Edited 6 hours ago by Lane Ranger Added photo 2 1 Share this post Link to post Share on other sites
Racinbob 12,247 #17 Posted 2 hours ago Here's the puller I made up when Dino was fighting me. I should have done this decades ago. Initially I just ran the bolts through the stuck hub. I was putting so much force into it that I got a bit worried about it so I made up a backer plate to disperse the pressure even more. After many days of keeping pressure on it and soaking it finally came off. I've got a third plate to make a backer that will go behind the entire hub which could come in handy but if the hub is too tight to the transmission case it wouldn't work. That would be a better choice on 3 hole hubs and the lighter 5 hole. 3 Share this post Link to post Share on other sites
