ri702bill 12,106 #1 Posted November 8, 2025 I added an additional 20 lb barbell weight plate to my existing Bolens 75 pounders, as there was enough room for it in the C81 wheel... the problem is they now weigh 95 pounds each and are a bear to install. Solution - adapt the floor jack to lift & center the weights..... works well. 6 15 Share this post Link to post Share on other sites
Achto 31,809 #2 Posted November 8, 2025 Excellent idea !!! 4 Share this post Link to post Share on other sites
peter lena 9,885 #3 Posted November 8, 2025 @ri702bill wait a minute , are you suggesting a cure for a problem ? we gotta talk , totally agree with the , close to floor heavy lift , added heavy screw in eye bolts , to my sheds , in open space areas , use a ratchet lift , https://www.google.com/search?q=ratchet+chain+hoist&rlz=1C1CHBF_enUS866US866&oq=ratchet+chain+lift+&gs_lcrp=EgZjaHJvbWUqCAgBEAAYFhgeMgoIABBF, got it at H/F 21$ on sale , add a small lift strap 3 /5 ft , makes deck moving / plow storage , much easier . use it to mount my vacuum pump rotor , to my rear hitch , for similar snow traction . after having done a lot of on the deck physical work , most of my life , now have a screw in movable ring go to area on every wall , great minds , or what's left , of them , think alike , pete Share this post Link to post Share on other sites
ri702bill 12,106 #4 Posted November 8, 2025 34 minutes ago, peter lena said: wait a minute , are you suggesting a cure for a problem ? Yup - just like my old Engineering days... Access the problem.. Define the weights and forces required.. Sketch up at least two possible solutions.. Pick the "better" choice & streamline it to be as simple as possible.. Utilize suitable existing resources & materials... Source & purchase what is needed.. (Two muffler clamps & flat stock) Fabricate & evaluate. Note any required changes. I would call this a "2 beer job"! 4 1 4 Share this post Link to post Share on other sites
ebinmaine 78,854 #5 Posted November 8, 2025 2 hours ago, Achto said: Excellent idea !!! Share this post Link to post Share on other sites
Treepep 1,130 #6 Posted November 8, 2025 I would call this a "2 beer job"! Had a girlfriend that would infuriate. Did not Fempute. Buddy yesterday said it was going to be 375 buck for disc brakes on his Tacoma. I said buy the parts I will do. About a beer a side. He also did not understand. I am saying its easy man. easy 5 Share this post Link to post Share on other sites
kpinnc 18,245 #7 Posted November 8, 2025 8 minutes ago, Treepep said: Fempute OMG I am using that one. Of course I mean to myself, as I have a wife and 3 daughters... If I suddenly stop posting here you'll know I slipped up and accidentally said it out loud. 2 hours ago, ri702bill said: Fabricate & evaluate. Note any required changes. I use your same steps, with one addition here: trash previous attempt, recover what you can and return to previous step. Repeat as necessary. 1 6 Share this post Link to post Share on other sites
peter lena 9,885 #8 Posted November 8, 2025 @ri702bill was in engineering , PFIZER maintenance over 25 years , rarely had a day that didn't get interesting , CHANGEOVERS , were always loaded with , surprises , thats when your shop , had to switch lines , change every related gasket , to every related line dive 1000, + gal glass lined tanks , for inspection , also included , every related pump or drive unit , clean out and repack every tank " stuffing box " top of tank drive unit , endless detailing , for a product change , reconfiguration , to current set up , for different product . this was also , entirely FOOD GRADE standards , every completed stage was , LAB TESTED , at product line discharge , no wonder we see things differently , 2am call in , pete 2 Share this post Link to post Share on other sites
ri702bill 12,106 #9 Posted November 8, 2025 24 minutes ago, peter lena said: 2am call in As a Manufacturing Engineer, I very seldom got those panic phone calls. On the other hand, the Process Engineers and the Maintainence guys all had that imaginary "Property of Stoneridge" tattoo on their backsides.... 3 3 Share this post Link to post Share on other sites
WHX?? 56,597 #10 Posted November 9, 2025 I recenty gave The Pullstart a set of weights because they are too heavy for my 66 yo back. I want em back Kev ... 8 Share this post Link to post Share on other sites
squonk 46,565 #11 Posted November 9, 2025 When I had the loaded rear wheels I used a Motorcycle jack to cradle the tire. 3 Share this post Link to post Share on other sites
ebinmaine 78,854 #12 Posted November 9, 2025 1 hour ago, squonk said: When I had the loaded rear wheels I used a Motorcycle jack to cradle the tire. We use a floor jack under the tractor and raise or lower the whole machine to match the wheel & studs by height. Wheel & tire stays on the floor. Slide the wheel in/out as needed. 2 1 Share this post Link to post Share on other sites
ri702bill 12,106 #13 Posted November 9, 2025 35 minutes ago, ebinmaine said: We use a floor jack under the tractor and raise or lower the whole machine to match the wheel & studs by height. Wheel & tire stays on the floor. Slide the wheel in/out as needed. I do the same with the loaded chained tire. I am using the OE lug bolts - I substitute 2 modified Chevy lug studs - thread them into the hub, slide the tire inward over them... 1 Share this post Link to post Share on other sites
ebinmaine 78,854 #14 Posted November 9, 2025 1 minute ago, ri702bill said: I do the same with the loaded chained tire. I am using the OE lug bolts - I substitute 2 modified Chevy lug studs - thread them into the hub, slide the tire inward over them... Similar here but with 5 studs. No original bolts. 1 1 Share this post Link to post Share on other sites
