adsm08 4,472 #26 Posted November 12, 2025 7 hours ago, Handy Don said: Depending on how your town’s engineering department operated, and keeps records, they may well have a site plan on file from the original construction that shows the locations. In our village, anything built from the late 40’s onwards is on file. Yeah, they probably do, but doing anything involving the township is a pain because I'm pretty sure it's just one guy with a roll of duct tape and a pack of chewing gum. 1 Share this post Link to post Share on other sites
adsm08 4,472 #27 Posted November 15, 2025 No construction crews this week. Cement got moved back to Wednesday, garage door is being installed Monday. I got started on the electrical by myself today. Took good pictures of the sub-panel's insides, then disconnected everything, took it off the wall, and moved it out by the new door and reconnected the incoming power, and got one circuit partially hooked up. I started hooking up for the lights, so that I can actually get things done after work, got as far as getting the switch wired to the panel, and quit for the night because the next step is 14 ft in the air and I'd rather do that in the light. 5 Share this post Link to post Share on other sites
adsm08 4,472 #28 Posted November 17, 2025 Overhead door got hung today: Goes up easier than the 6ft doors on the other side. And I got the lift post locations marked for Wednesday. 3 3 Share this post Link to post Share on other sites
adsm08 4,472 #29 Posted November 19, 2025 Floor got poured today: New section of the shop is off limits to foot traffic for two days, all other traffic for two weeks. Also got a chance to talk to the lift guy, he said call him in two weeks and he'll grab two guy for a Saturday and come put it up. 1 8 Share this post Link to post Share on other sites
ebinmaine 78,851 #30 Posted November 19, 2025 Awesome! Share this post Link to post Share on other sites
adsm08 4,472 #31 Posted November 23, 2025 Yesterday the concrete guy came back to do the stress joints. This morning my dad, my son and I went rabbit hunting, then after lunch dad came over and we worked on securing wires and hanging lights for about 4 hours. Only work I have to do on interior lighting is get covers on the outlet boxes, but I wanted to get everything in place and tested before I closed up the boxes. Those were taken about 8 pm, so no help from the sun in the window. Pretty well lit for only 4 lights. 2 2 Share this post Link to post Share on other sites
Handy Don 16,603 #32 Posted November 23, 2025 (edited) 1 hour ago, adsm08 said: Pretty well lit for only 4 lights. Getting there, but this is with no equipment in there. In my shop and have several lights (all LED tubes, now) spread around on separate switches so that I can up the brightness where needed while having basic light everywhere. Edited November 23, 2025 by Handy Don 2 Share this post Link to post Share on other sites
adsm08 4,472 #33 Posted November 23, 2025 9 hours ago, Handy Don said: Getting there, but this is with no equipment in there. In my shop and have several lights (all LED tubes, now) spread around on separate switches so that I can up the brightness where needed while having basic light everywhere. Very true. I am going to add the rest of the lights after the final inspection. I'm not sure the township won't find a way to have an issue with them being daisy-chained, despite them being designed for it, and all of the ones i have only drawing about 7 amps total. 4 Share this post Link to post Share on other sites
ebinmaine 78,851 #34 Posted November 23, 2025 7 minutes ago, adsm08 said: Very true. I am going to add the rest of the lights after the final inspection. I'm not sure the township won't find a way to have an issue with them being daisy-chained, despite them being designed for it, and all of the ones i have only drawing about 7 amps total. We have some interesting loopholes here. On our new barn 3 years ago... - My own local Building Inspector can ONLY approve STRUCTURE. No plumbing or electrical inspection. - If the electrical installation is done when the building is new, the system must be inspected, living space or not. - If the electrical installation is done to an existing (not new) living space the rules vary but inspection is usually necessary. - If the electrical installation is done to an existing NON residence there was no inspection in >this< county. My area has no Electrical inspector so we would default to calling in a State Inspector. That's fine but takes time. Again... necessary for a living space but not a barn. For our barn we waited several months to add electricity. Only after the permit was filed and mortgage was processed so we KNEW there was no inspection needed did we start adding circuits. Secondary loophole to the above. Our ceiling lights are on a switched outlet. The lights are then hung independently and plugged in to the outlet. This takes a daisy chain out of the realm of an Electrical Inspector and also keeps it Code compliant as long as the light manufacturer recommendations are met. Example: max 4 lights per chain. 2 2 Share this post Link to post Share on other sites
adsm08 4,472 #35 Posted November 23, 2025 9 hours ago, ebinmaine said: We have some interesting loopholes here. On our new barn 3 years ago... - My own local Building Inspector can ONLY approve STRUCTURE. No plumbing or electrical inspection. - If the electrical installation is done when the building is new, the system must be inspected, living space or not. - If the electrical installation is done to an existing (not new) living space the rules vary but inspection is usually necessary. - If the electrical installation is done to an existing NON residence there was no inspection in >this< county. My area has no Electrical inspector so we would default to calling in a State Inspector. That's fine but takes time. Again... necessary for a living space but not a barn. For our barn we waited several months to add electricity. Only after the permit was filed and mortgage was processed so we KNEW there was no inspection needed did we start adding circuits. Secondary loophole to the above. Our ceiling lights are on a switched outlet. The lights are then hung independently and plugged in to the outlet. This takes a daisy chain out of the realm of an Electrical Inspector and also keeps it Code compliant as long as the light manufacturer recommendations are met. Example: max 4 lights per chain. Where I live used to be reasonable. After 20 years of letting the area become over-developed the rules have changed, and even me being out away from all the developments I still have to follow the townie rules. What I was told that I need to have an outdoor light above the man door, one GFI outlet, and one outlet no higher than 5.5 feet to meet local codes, and of course the proper gauges of wire for the loads, lengths, etc. I have my GFI about 2 feet off the floor, and a few non-GFIs about 14 feet off the floor, for lights, all wired in 12-2, none of it longer than about 40 ft, or intended to ever draw more than 8 amps. I was also told that nothing in the old section would be subject to inspection unless "changes were made". I am hoping that just reconnecting the existing wiring to the relocated panel doesn't qualify as "changes" as no other changes were made. 3 Share this post Link to post Share on other sites
oliver2-44 11,482 #36 Posted November 24, 2025 17 hours ago, adsm08 said: Where I live used to be reasonable. After 20 years of letting the area become over-developed the rules have changed, and even me being out away from all the developments I still have to follow the townie rules. What I was told that I need to have an outdoor light above the man door, one GFI outlet, and one outlet no higher than 5.5 feet to meet local codes, and of course the proper gauges of wire for the loads, lengths, etc. I have my GFI about 2 feet off the floor, and a few non-GFIs about 14 feet off the floor, for lights, all wired in 12-2, none of it longer than about 40 ft, or intended to ever draw more than 8 amps. I was also told that nothing in the old section would be subject to inspection unless "changes were made". I am hoping that just reconnecting the existing wiring to the relocated panel doesn't qualify as "changes" as no other changes were made. My son lives in town, and we relocated the main house panel when we did his addition. Everything had to be brought up to new code. We had to use a new panel, upgrade all breakers in the panel to the various new type, and upgrade plugs in the house to the new child safe window type and GFCI as required. Thankfully the inspection was a tiny bit flexible where we couldn't quite achieve everything like the requirement of the island having a plug receptacle. Share this post Link to post Share on other sites
ebinmaine 78,851 #37 Posted November 24, 2025 1 hour ago, oliver2-44 said: requirement of the island having a plug receptacle The electrician we have doing the work at the house is a Maine Licensed guy that works for a company specializing mostly in Commercial stuff but they do some Residential as well. Him, inspectors, codes, his company... They've all had several go-arounds. 2020 code required the addition of outlets to Islands. But they were allowed on the sides. People were getting injured or worse, not being able to see the cord as they came around a corner or not paying attention. Code was updated for 2023 that you still have to put the wire in. But you no longer have to install the receptacle. They've been trying to figure out for three or four years now which way they're going to go because nobody wants the liability or responsibility. His company has decided to stop installing electrical outlets because they don't want the liability of future spills getting into a defective GFCI and causing electrocution. From the interwebs: "2023 Electrical code? 2020 had specific requirements for a lot of additional outlets on peninsulas and islands. 2023 doesn't require them at all, and also doesn't allow them underneath anymore, but if you don't install them in the surface, requires "provisions for future addition" .. so you could pre-wire under the countertop, leave them out for inspection, point to "provisions for future" to your inspector, " Share this post Link to post Share on other sites
adsm08 4,472 #38 Posted November 25, 2025 8 hours ago, oliver2-44 said: My son lives in town, and we relocated the main house panel when we did his addition. Everything had to be brought up to new code. We had to use a new panel, upgrade all breakers in the panel to the various new type, and upgrade plugs in the house to the new child safe window type and GFCI as required. Thankfully the inspection was a tiny bit flexible where we couldn't quite achieve everything like the requirement of the island having a plug receptacle. That sucks. So far it is my understanding, although I may be wrong, that this is not as strict since it is an out-building and not the main residence. 2 Share this post Link to post Share on other sites
adsm08 4,472 #39 Posted December 5, 2025 Final inspection, including electrical, was signed off today. Still waiting for gutters to be installed, but that isn't on the inspection check-list (still needed, but apparently not holding anything else up now). Now I just have to wait for the paperwork to process before I can get the final occupancy permit. 1 3 Share this post Link to post Share on other sites
Handy Don 16,603 #40 Posted December 6, 2025 On 11/24/2025 at 12:23 PM, ebinmaine said: specific requirements for a lot of additional outlets on peninsulas and islands I get the issue--protect from spills or protect from passers-by bumping the cord or don’t have the convenience of appliances on the island! Hmmm. Maybe a ceiling mounted retractable extension cord like I have in the workshop? 🙃 We had a side outlet in the kitchen island included at construction. I added a sturdy towel bar above the outlet at just below countertop height. We route the cords for our out-only-when-in-use. island-top stuff (toaster, popcorn maker, waffle iron, et al) through the towel bar and into the outlet. 3 Share this post Link to post Share on other sites
SylvanLakeWH 31,413 #41 Posted December 6, 2025 17 minutes ago, Handy Don said: Maybe a ceiling mounted retractable extension cord like I have in the workshop? 🙃 Excellent idea! Maybe add an air hose while you're at it... make clean up a breeze and just imagine the Mrs's reaction!!! 1 3 Share this post Link to post Share on other sites
Handy Don 16,603 #42 Posted December 6, 2025 1 hour ago, SylvanLakeWH said: Excellent idea! Maybe add an air hose while you're at it... make clean up a breeze and just imagine the Mrs's reaction!!! During one of our pre-construction design sessions I proposed floor drains in the bathrooms that would make it easier when cleaning (which was one of my chores--Mom taught me well). Quickly vetoed. Since then my spouse has observed (40 years too late) how common they are in European bathrooms we’ve visited. 4 Share this post Link to post Share on other sites
adsm08 4,472 #43 Posted December 9, 2025 This weekend was spent finishing hanging lights, and buttoning up some electrical stuff. I have a little bit of carpentry and plumbing to do, but it isn't urgent or extensive. Stuff not included in the original plans that I didn't know I wanted done until I saw the finished product. Also got the lift moved into place tonight. Now I just gotta call the lift installer. 4 Share this post Link to post Share on other sites
adsm08 4,472 #44 Posted December 20, 2025 (edited) Last big update, for a while at least: The guys who do our lifts at work are a small business. I wanted to make sure this was done right, and I like supporting small businesses, so I called them up to put mine in. Owner and his kid came out this morning and had it up much faster than I could have. Then I got the wife's car in for an oil change and tire rotation. Made the boy do it. Edited December 20, 2025 by adsm08 5 3 Share this post Link to post Share on other sites
Handy Don 16,603 #45 Posted December 20, 2025 20 minutes ago, adsm08 said: Excellent work and nifty mentoring as well! And no oil on the floor...yet! 2 Share this post Link to post Share on other sites
adsm08 4,472 #46 Posted December 20, 2025 (edited) 7 minutes ago, Handy Don said: And no oil on the floor...yet! Yeah, about that... I don't have a funnel that works well with the wife's car. I went walking through with an empty bottle looking for a knife so I could cut it open for a funnel and ended up slinging oil all over the place. At least it was clean oil. Happened after that picture was taken though. Edited December 20, 2025 by adsm08 2 Share this post Link to post Share on other sites
Bill D 2,859 #47 Posted December 20, 2025 Whst are you doing for insulation and heat? 2 Share this post Link to post Share on other sites
adsm08 4,472 #48 Posted December 20, 2025 6 minutes ago, Bill D said: Whst are you doing for insulation and heat? Same thing I'm doing about finding Jimmy Hoffa and D.B. Cooper. Nothing. I have a torpedo heater and a radial kerosene unit. I'll see how they do this winter and make adjustments from there. I am going to get a few cans of spray foam and close gaps where the old building's wall is chipped and the corrugation of the wall leaves gaps to the framing. The old section of the building has broken windows and is also poorly insulated, but I took the door out because it was a pain, and the wood was so rotten that the screws wouldn't thread out. But that door is an odd size, so replacing it is not cheap or easy, so I have a giant hole in the wall either way. 3 Share this post Link to post Share on other sites
adsm08 4,472 #49 Posted January 1 So I've been out there quite a bit in the last two weeks since the lift went it. The torpedo is keeping up well enough, it's chilly enough to not sweat, but warm enough I can get down to short sleeves. Unfortunately last night one of the lift rams sprung a pretty good leak. The installer and I were both a little worried that might happen because it sat completely unused for so long. On the bright side it looks pretty easy to get the cylinders out and reseal them. The guy I had install it services our lifts at work, he said he can get me the parts I need. I'm hoping to be back up and running by next weekend. 4 1 Share this post Link to post Share on other sites
adsm08 4,472 #50 Posted January 3 (edited) Cylinders are out. It was about as easy as it looked on Youtube. Can't quite figure out how to get them open. It looks like there is spring-clip, you have to align a mark on the end cap with the slot the spring is visible through. That's all I'm sure of though. I found two videos of guys working on this style cylinder, looks like one pushed the spring in, and one pulled it out, and neither showed what they did clearly, so I am eating deer baloney and watching Stargate instead. Edited January 3 by adsm08 1 Share this post Link to post Share on other sites
