Lee1977
Weight Box
Lee1977
I have had this metal building steel around 40 years decided to make a front weight out of it. Got it cut out and tacked together.
Turn into a joint project with Kevin as he welded it up. Had enough steel left so I cut another one for Kevin. It has around 2" of sheet lead inside.
Best guess it weights 50 #.
  • Excellent 7
ebinmaine
Niiiiice!
Got a bar on the back to mount in the front hitch?
ri702bill
I was going to say why not wheel weights - looks like those narrow rims have no thru holes for weights...
kpinnc
I'll try to get mine welded up by the weekend Don. Thank you very much! A very cool idea! :thumbs:
I think I'm gonna use it as my hood stop on the newest tractor. I gotta pick up some lead too.
Yes they do. Don made up a bracket that uses a 5/8 bolt and a standoff to fit in the front hitch.
kpinnc
The one disadvantage to Vanguard engines (if one exists) is that they are much lighter than a Kohler. Since Don and I both have more than one machine with a Vanguard in it, the box makes sense that it can quickly move from one to the other.
Also mine have 1 inch spindles and none of my wheel weights fit.
Lee1977
One reason I used a 5/8" bolt in the hitch is you can tighten it once it's in the hitch. Stops any movement.
The wheels came off a trailer that why the don't have weight holes.
Edited by Lee1977
ri702bill
Got it. Perhaps a "when you have the time" project would be to fab a pair of homemade weights using the WH spacing. Both my 854 and C81 have a dedicated set of barbell plate weights - different hole spacing. I have a guy locally that buys & sells used gym equipment - his selection of incomplete weight sets is rather extensive. Tapping cast iron is a chore - the grain structure of those castings is quite coarse; much more difficult to drill & tap than Machine Tool fine grain castings. I recall using a carbide masonry bit to get the holes started...
Wayne0
I made one out of a .50 cal ammo can that mounts on the front tachomatoc and rests on the plow frame for down pressure. Pivots up and down with the plow.
There is a thread on here somewhere.
Found it.
Edited by Wayne0
peter lena
 @Lee1977  https://www.google.com/search?q=isolation+pad+%2C+for+heavy+weight&rlz=1C1CHBF_enUS866US866&oq=isolation+pad+%2C+for+heavy+weight+&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIICAEQABgWGB4yDQgCEAAYhgMYgAQYigUyDQgDEAAYhgMYgAQYigUyCggEEAAYgAQYogQyBwgFEAAY7wUyCggGEAAYgAQYogQyCggHEAAYgAQYogTSAQk0NDk0N2owajSoAgCwAgA&sourceid=chrome&ie=UTF-8  have a number of these in use , regularly  used them back in my day  , really helps  soften and  isolate , on cast areas , have one on the bottom of  all my rear hitches , that  long  metal to metal , set up  was added years ago , pete
kpinnc
Got mine started tonight. Sides are on, just gotta set up the attachment hardware on the back and fill her up. :thumbs:
Edited by kpinnc
kpinnc
Got a bucket full of lead wheel weights from a buddy of mine. When I melted them down, I found out only about half were actually lead. I had no idea.
So I covered everything in a little concrete just to keep it from rattling around. I'll weld on a cover when it dries.
So far it's 80lbs. Prolly go up a little when I finish it up.
Edited by kpinnc
Handy Don
I sure hope that was an outdoor event and that you stayed upwind!
kpinnc
Garage door was open and I wore a respirator.
peter lena
@ri702bill realise its not on subject , c-81 start a penetrating oil soak / or  mineral oil , let it sit for days or more , paint should  darken to the patina stage , would rub run it down with a clean cloth  and more lubrication . would not , scratch pad that at all , darker  base color  / stage , tells you what's left , once its gone , it,s  repaint time . all my stuff is  patina based saved colors . pete
kpinnc
Got a few minutes to finish mine up today so far as welding. Made a test fit just for giggles.
This thing is hard to get situated. I thought I had something crooked until I saw the right side of the nose hitch is bent. Handles or not, the floor jack is a must. It weighs just over 80lbs.
Now to figure out how to paint this thing!
Handy Don
Sometimes I just give up and accept that I cannot support a part accessibly for painting in one session. 😉
