1987_WHEEHORSE312 53 #1 Posted October 30 I sourced these lights off Amazon gor $25 for the pair. They are direct boltup, plug and play, no modification required. You can see the huge improvement they make over stock. I have included photos of the part number and the box they came in. 8 1 Share this post Link to post Share on other sites
Sparky-(Admin) 23,831 #2 Posted October 30 Couple of mine have LED’s. Very happy with em 2 1 Share this post Link to post Share on other sites
1987_WHEEHORSE312 53 #3 Posted October 30 14 minutes ago, Sparky said: Couple of mine have LED’s. Very happy with em Awesome to hear! 2 Share this post Link to post Share on other sites
kpinnc 15,798 #4 Posted October 30 1 hour ago, Sparky said: Couple of mine have LED’s. Very happy with em All of mine have LEDs. Very few "new" stuff is an improvement nowadays, but this is one for sure. 3 1 Share this post Link to post Share on other sites
1987_WHEEHORSE312 53 #5 Posted October 30 7 hours ago, kpinnc said: All of mine have LEDs. Very few "new" stuff is an improvement nowadays, but this is one for sure. Awesome! I cant wait till snow season to use the lights! 2 1 Share this post Link to post Share on other sites
Bar Nuthin 1,525 #6 Posted October 30 The comparison between the LED and the sealed beams is quite significant, I just scored a couple more pair of vintage tractor lights earlier this week. I like the ones with the cupped base and internal wire, but they're harder to locate. 3 Share this post Link to post Share on other sites
ebinmaine 74,708 #7 Posted November 2 On 10/29/2025 at 11:18 PM, kpinnc said: All of mine have LEDs. Very few "new" stuff is an improvement nowadays, but this is one for sure. Agreed. Every build we do or every light that gets replaced is LED. HUGE difference in the dark moving snow. 2 Share this post Link to post Share on other sites
MainelyWheelhorse 2,111 #8 Posted November 2 On 10/29/2025 at 11:18 PM, kpinnc said: All of mine have LEDs. Very few "new" stuff is an improvement nowadays, but this is one for sure. @1987_WHEEHORSE312 @kpinnc I’ve upgraded 2 of my three tractors to the PAR 36 LED headlights. one set from Home Depot, one from Amazon. I agree, it’s a definite improvement. The C-141 Auto is the next upgrade candidate. 2 Share this post Link to post Share on other sites
DBlackston 317 #9 Posted Thursday at 02:59 AM I am pretty much LED everything across the board. Theyre cheap and reliable, plus a huge upgrade typically. House, cars and trucks, tractors, etc... 2 1 Share this post Link to post Share on other sites
ebinmaine 74,708 #10 Posted Thursday at 09:50 AM 6 hours ago, DBlackston said: I am pretty much LED everything across the board. Theyre cheap and reliable, plus a huge upgrade typically. Agreed. 6 hours ago, DBlackston said: House, cars and trucks, tractors, etc... Same. Share this post Link to post Share on other sites
Bar Nuthin 1,525 #11 Posted Thursday at 01:12 PM On 10/30/2025 at 8:32 AM, Bar Nuthin said: I just scored a couple more pair of vintage tractor lights earlier this week. I thought I was getting 4" tractor lights - turns out they are 7" lights (big tractor or possible vehicle). They're in great shape overall so, I guess I'll clean them up a little and try and find someone that can use them. 1 Share this post Link to post Share on other sites
Bar Nuthin 1,525 #12 Posted Thursday at 01:25 PM 10 hours ago, DBlackston said: I am pretty much LED everything across the board. Theyre cheap and reliable, plus a huge upgrade typically. House, cars and trucks, tractors, etc... Same here. Several of them are smart bulbs. I tell Alexa good morning, and my home office lights come on at 30% brightness. Once I get my **** together and some coffee in my system, I tell her "bright light" and they bump up to full brightness. I have LEDs in my shop, but I kept one 6 bulb bank of fluorescents in the center of the shop. I was resizing and polishing my wedding band one day and thought I had it perfect - until I walked under the fluorescents. I could clearly see some tooling marks that I didn't get polished out. Under the LED's they were invisible. Evidently, something in the color spectrum. So now when I'm looking at something with regards to surface finish, I always make sure to check under various lighting. 3 1 Share this post Link to post Share on other sites
Handy Don 14,758 #13 Posted Thursday at 03:05 PM 1 hour ago, Bar Nuthin said: Evidently, something in the color spectrum. My neighbor is a lighting engineer and he schooled me on both temperature and spectrum after he noticed that I’d equipped my kitchen fluorescents with one each of a warm and daylight tube. He approved! 2 Share this post Link to post Share on other sites
Lagersolut 752 #14 Posted Friday at 01:41 AM (edited) Can you switch to LED with lights powered off the stator vs the battery - I never upgraded because of the variable voltage on the 416 and frowned doing a rewire to come off battery Edited Friday at 12:27 PM by Lagersolut Share this post Link to post Share on other sites
kpinnc 15,798 #15 Posted Friday at 06:20 AM 4 hours ago, Lagersolut said: Can you switch to LED with lights powered off the magneto vs the battery - I never upgraded because of the variable voltage on the 416 and frowned doing a rewire to come off battery The magneto provides power to your spark plug- once per revolution of the flywheel. I assume you meant the stator (AC) or rectifier (DC). Some manufacturers have used AC for lights but I wouldn't do that because any loss in the AC will affect the DC output of the rectifier. You can connect directly to the rectifier output at the battery side of the starter solenoid if you prefer. Most magneto ignition key switches have a tab labeled "L" for lights or accessories. You can usually splice in there and the lights will only work when the switch is in the first detent or when the engine is running. Be sure and add an inline fuse holder. And just my opinion, but unless you are using LEDs, I would include a voltmeter if you don't already have one. It's a nice failsafe to make sure the lights you install don't drag the charge voltage below about 12.7 VDC. Otherwise you could overload the rectifier and drain the battery even with the engine running. 1 Share this post Link to post Share on other sites
Lagersolut 752 #16 Posted Friday at 12:26 PM 6 hours ago, kpinnc said: The magneto provides power to your spark plug- once per revolution of the flywheel. I assume you meant the stator (AC) or rectifier (DC). Some manufacturers have used AC for lights but I wouldn't do that because any loss in the AC will affect the DC output of the rectifier. You can connect directly to the rectifier output at the battery side of the starter solenoid if you prefer. Most magneto ignition key switches have a tab labeled "L" for lights or accessories. You can usually splice in there and the lights will only work when the switch is in the first detent or when the engine is running. Be sure and add an inline fuse holder. And just my opinion, but unless you are using LEDs, I would include a voltmeter if you don't already have one. It's a nice failsafe to make sure the lights you install don't drag the charge voltage below about 12.7 VDC. Otherwise you could overload the rectifier and drain the battery even with the engine running. My mistake - I meant stator - my 416 the lights are powered off the stator - idle lights are dim - throttle up they’re bright … I’m by no stretch an electrical guru but it was always my thinking the lights power supply would need to be converted over to battery for LED to work … 1 Share this post Link to post Share on other sites
WHX?? 53,021 #17 Posted Friday at 01:36 PM Like @Achto always says the stock lights are akin to holding a candle in front of you. 2 1 Share this post Link to post Share on other sites
ebinmaine 74,708 #18 Posted Friday at 01:57 PM 1 hour ago, Lagersolut said: My mistake - I meant stator - my 416 the lights are powered off the stator - idle lights are dim - throttle up they’re bright … I’m by no stretch an electrical guru but it was always my thinking the lights power supply would need to be converted over to battery for LED to work … If you run the tractor at all at night, it's absolutely worth it to make the change over to LED. For you to run two or three wires from the battery to a switch, including a fuse. Easy peasy. 3 Share this post Link to post Share on other sites
peter lena 9,479 #19 Posted Friday at 04:26 PM @1987_WHEEHORSE312 also agree on the LED DIFFERENCE , DO A LOT OF ROAD EDGE PLOWING , often at night , minimal traffic , etc , the back of the tractor is just glowing red , also have a reflector back there . at walmart , they have a wall full of same size bolt on lights , looks like a perfect fit . also wear a reflective vest . pete 2 Share this post Link to post Share on other sites
Lagersolut 752 #20 Posted Friday at 11:55 PM 9 hours ago, ebinmaine said: If you run the tractor at all at night, it's absolutely worth it to make the change over to LED. For you to run two or three wires from the battery to a switch, including a fuse. Easy peasy. Somebody ( it may have been you ) had a post for small bullet style LED’s they mounted on the bottom of the hood for xtra light with a link … I can’t find the thread or those lights. My mind was already on LED lights when this thread was started - got dark when I was plowing the garden last week was thinking of a magnet mounted spot out the back - jungle site has the magnets . 1 1 Share this post Link to post Share on other sites
ebinmaine 74,708 #21 Posted yesterday at 12:43 AM 46 minutes ago, Lagersolut said: Somebody ( it may have been you ) had a post for small bullet style LED’s they mounted on the bottom of the hood for xtra light with a link … I can’t find the thread or those lights. My mind was already on LED lights when this thread was started - got dark when I was plowing the garden last week was thinking of a magnet mounted spot out the back - jungle site has the magnets . I've used the magnet mounts. They do well ... but.... the lamps vibrate and slowly fall. Be aware of the paint being worn where they are. Share this post Link to post Share on other sites
ML3 1,960 #22 Posted 23 hours ago (edited) Installed these leds on my 654. Also put them on the 702 & may try to fit a pair on the Workhorse. Harbor Freight led floodlight $11.99ea. They are really bright, affordable, & if needs replaced easy to obtain. They held up thru last winter & still work fine now. They dont look too bad but they are installed on working tractors so Im not concerned about authenticity. VID-20250103-WA0017~3.mp4 Edited 23 hours ago by ML3 1 Share this post Link to post Share on other sites
peter lena 9,479 #23 Posted 8 hours ago @ML3 like it , reflective of set up and insurance of function , also like oiled patina look , you using a belt for the blower chute swing ? looks like something I would do , pete Share this post Link to post Share on other sites
Handy Don 14,758 #24 Posted 8 hours ago (edited) 15 hours ago, ML3 said: The video shows the only downsides of the relatively low mounting and flood style--the lifted blade blocking the light and reflecting it back into the operator’s line of sight. Note, too, that many outdoor LEDs have 6000K+ “daylight" temperature but not the full daylight spectrum. This can make for very bright but “flat” lighting, especially in snow. Not a deal breaker by any means, but something to consider. (Full spectrum combines LEDs of different colors and phosphor coatings to get the full range.) Edited 8 hours ago by Handy Don 1 Share this post Link to post Share on other sites
