adsm08 3,734 #101 Posted yesterday at 11:20 PM 6 minutes ago, ebinmaine said: One can hope I like snow. It's just not coming here because I am ready. You'll probably end up with our share. 3 Share this post Link to post Share on other sites
ebinmaine 75,187 #102 Posted 23 hours ago Just now, adsm08 said: I like snow. It's just not coming here because I am ready. You'll probably end up with our share. Tomorrow we're forecast for 6 ish to 10+ depending who you ask. Our winters are FAR more mild than just 12 to 15 years ago. 2 Share this post Link to post Share on other sites
Bar Nuthin 1,692 #103 Posted 20 hours ago 4 hours ago, ebinmaine said: That may get changed to the wiiiide 60" blade or the two stage tall chute snowblower. If they underestimate snowfall totals like they did in my area, my bet is the tall chute goes on! 1 Share this post Link to post Share on other sites
Handy Don 14,937 #104 Posted 20 hours ago (edited) 13 hours ago, Lane Ranger said: Very easy to correct by screwing the detached piece back in the spring and reattaching on the horizontal rods with ins. Sad to inform you that the motion of the spring against the cast iron end piece has been slowly wearing away the “threads” on the cap and the inner surface of the spring. Net effect is to weaken the grip and it’ll come apart easier and easier in future. And probably when you are on the first pass, at 20º F, with driving sleet or snow and in the dark. I tried reassembling one with a slather of JB weld. The fricative motion simply wore it away (and yes, in regular use, there is motion) I tried a metal-filled epoxy. It lasted longer but still failed. I tried building up with a welder and re-shaping the thread. That lasted longest and for someone more skilled than me, it might be semi-permanent. Welding to cast iron and grinding precisely is no picnic. Resigned myself to getting replacements at the show in 2024 (and made sure to check the lengths--I think there are two part numbers). Edited 20 hours ago by Handy Don 5 Share this post Link to post Share on other sites
Dan 312-8 315 #105 Posted 20 hours ago Ready for more than ever will come. 4 6 Share this post Link to post Share on other sites
ebinmaine 75,187 #106 Posted 12 hours ago Latest forecast. We are in the jackpot area I guess. We live just about at the end of the Arrow under the B and U 4 Share this post Link to post Share on other sites
adsm08 3,734 #107 Posted 9 hours ago We had some when I got up this morning, just a coating, but now it's starting to come down faster. Looks like the drvieway may be ice. 3 Share this post Link to post Share on other sites
702854boy 350 #108 Posted 8 hours ago We've got about 6 inches outside right now, on Thursday and Friday we had about 4 inches each day. Definitely getting a lot of seat time so far. Yesterday I put front tire chains on to see if that helps me steer until we can fab up a front weight. So far I have not spun out even when moving the snow bank from an entire 30 foot driveway. The hundreds pounds total weight per wheel plus lsd plus chains plus my 135 pounds probably helped a little. The 8 horse kohler barely even grunted. The one time over the summer I had scotch brited that scratches and waxed the plow and that helped with the snow sticking and now I'm gonna see if silicone spray helps even more. 6 1 Share this post Link to post Share on other sites
Wishin4a416 2,263 #109 Posted 6 hours ago 5 inches of partly cloudy overnite. Ole Thumper never missed a beat knock on wood. 3/8 of a mile of driveways are all done. The renters can clean up their sidewalks their-selves. It was a wet and heavy one. 2 2 Share this post Link to post Share on other sites
adsm08 3,734 #110 Posted 5 hours ago We got about an inch, its not raining and just above freezing. I'm not even cleaning the driveway, this will take care of itself at this rate. 3 Share this post Link to post Share on other sites
Ed Kennell 43,478 #111 Posted 3 hours ago We got about 1/32" of ice that has allready melted. Now waiting for rain to wash the salt brine down the Chesapeake Bay and make it safe to drive a car. Pee Aaa sprays over 12 million gallons/year on our state roads. Of course the local guvments add their share. 3 Share this post Link to post Share on other sites
Wayne0 1,402 #112 Posted 2 hours ago 17 hours ago, Handy Don said: Sad to inform you that the motion of the spring against the cast iron end piece has been slowly wearing away the “threads” on the cap and the inner surface of the spring. Net effect is to weaken the grip and it’ll come apart easier and easier in future. And probably when you are on the first pass, at 20º F, with driving sleet or snow and in the dark. I tried reassembling one with a slather of JB weld. The fricative motion simply wore it away (and yes, in regular use, there is motion) I tried a metal-filled epoxy. It lasted longer but still failed. I tried building up with a welder and re-shaping the thread. That lasted longest and for someone more skilled than me, it might be semi-permanent. Welding to cast iron and grinding precisely is no picnic. Resigned myself to getting replacements at the show in 2024 (and made sure to check the lengths--I think there are two part numbers). I would suggest drilling between the coils and adding a roll pin or bolt. 1 2 Share this post Link to post Share on other sites
sqrlgtr 1,186 #113 Posted 2 hours ago On 12/1/2025 at 8:46 AM, Lane Ranger said: looks like operator error to me . 1 1 Share this post Link to post Share on other sites
MainelyWheelhorse 2,185 #114 Posted 1 hour ago ‘Before… After… During… I got about 3 or 4 inches of snow here, and it was still snowing when I stopped. I’ve got tomorrow off too, so I’ll touch it up then. It’s pretty powdery so it shouldn’t be too hard. 1 Share this post Link to post Share on other sites
Handy Don 14,937 #115 Posted 56 minutes ago 1 hour ago, Wayne0 said: I would suggest drilling between the coils and adding a roll pin or bolt. Have you actually done this? Pictures? Share this post Link to post Share on other sites
Bar Nuthin 1,692 #116 Posted 56 minutes ago We got around 8" Sunday then another 3" or 4" overnight, last night. 1 Share this post Link to post Share on other sites
