Derek W 31 #26 Posted November 23, 2025 Good afternoon fellas! I've got some news. I removed that clutch dampener thing and I went ahead and replaced the drive belt. That seems to have helped. The dampener rod (piston) didn't even move on its own at all. I'd press it all the way in and it would stay in. I'd pull it half out and fully out and it would just stay. It's now residing in the garbage bin. I took the Wheel Horse out for a spin and it drove pretty well. I pulled it into the garage to check something and then wanted to start the engine to test something and it wouldn't start. Just crank, crank, crack. That's weird! Speed the story up and I'm not getting any spark now. I pulled the plug and tested it against the metal on the tractor and no spark. I added my spark tester and cranked the engine....no spark. That's so weird because the ignition coil was new just a few months ago. Would you have any ideas on this no spark issue or could it be the ignition coil? Share this post Link to post Share on other sites
953 nut 70,654 #27 Posted November 23, 2025 Check your 10 amp fuse. If the fuse holder is corroded or the fuse is blown it will prevent the Kill relay from opening. This link will give you wiring information to help you find the problem. 1 Share this post Link to post Share on other sites
Derek W 31 #28 Posted November 24, 2025 Thanks Richard! I'll have a look! Share this post Link to post Share on other sites
