Handy Don 17,400 #26 Posted October 28, 2025 2 minutes ago, 702854boy said: Got some stuff in the mail today. Dad's thinking about taking them to work so he can put them in a lathe and polish them up a little bit. ScotchBrite won’t hurt not much work to do manually, either. 1 Share this post Link to post Share on other sites
702854boy 1,132 #27 Posted October 29, 2025 2 hours ago, Handy Don said: ScotchBrite won’t hurt not much work to do manually, either. Got them nice and shiny with some scotch Brite, elbow grease and patience 5 Share this post Link to post Share on other sites
Handy Don 17,400 #28 Posted October 29, 2025 13 hours ago, 702854boy said: elbow grease and patience Nice investment and very satisfying even though no one will see it after it’s assembled! 1 Share this post Link to post Share on other sites
702854boy 1,132 #29 Posted October 29, 2025 1 hour ago, Handy Don said: Nice investment and very satisfying even though no one will see it after it’s assembled! It helps ensure that we won't have to take it back apart because of rust or something in the tranny. It'll also help make sure the bearings and seals have a good place to ride against. 1 Share this post Link to post Share on other sites
oliver2-44 11,718 #30 Posted October 30, 2025 On 10/28/2025 at 2:13 PM, 702854boy said: Would anyone happen to know how to restore a shift know so its shiny and not all dull? If you have access to a drill press here’s how I do it. Get a 2-3” bolt that screws into the shifter ball and cut the head off. Screw a nut on the bolt then thread the ball on. Tighten the nut against the shifter ball. Chuck the bolt in the drill press. If the ball is dull and scratched up start with 220 and paper. Work you way to finer and finer sand paper 229, 320,400,600,1000. Then I move the ball and bolt to my hand drill. I have a cloth buffing wheel that I use white rouge on. Now just buff the ball with the drill turning on a slow speed. You can turn a faded scratched up ball into a mirror finish. 2 2 1 Share this post Link to post Share on other sites
702854boy 1,132 #31 Posted October 30, 2025 Well I got some shift knobs all shined up using some almost paper sand paper thats how fine it was and then getting a piece of 3/8 all thread and chucking it into the hand drill and used some cleaner and polish carnuba wax. The worser of the two is going back on our dump trailer 6 3 Share this post Link to post Share on other sites
953 nut 68,930 #32 Posted October 31, 2025 On 10/29/2025 at 11:33 PM, oliver2-44 said: Then I move the ball and bolt to my hand drill. I have a cloth buffing wheel that I use white rouge on. Now just buff the ball with the drill turning on a slow speed Great tip Jim, I had one on a bolt against the turning buffing wheel one day and lost my concentration switching around to the direction that allowed the knob to unscrew itself, it took off across the floor and out the door in a heartbeat. If it was being turned by the drill motor it would have been much safer and I wouldn't have had to start all over again. 1 2 Share this post Link to post Share on other sites
702854boy 1,132 #33 Posted November 12, 2025 Just curious, with the six speed and lsd would it help to add the zinc additive such as what we do for the engines or are there more additives in gear oil that help with wear? Share this post Link to post Share on other sites
ebinmaine 80,488 #34 Posted November 12, 2025 2 minutes ago, 702854boy said: Just curious, with the six speed and lsd would it help to add the zinc additive such as what we do for the engines or are there more additives in gear oil that help with wear? I don't add anything to our gear oils. They have their own Additive Package. The Wheelhorse transmission is VERY stout and likely won't need help. We run the least expensive gear oil available. 1 Share this post Link to post Share on other sites
Handy Don 17,400 #35 Posted November 12, 2025 4 minutes ago, 702854boy said: Just curious, with the six speed and lsd would it help to add the zinc additive such as what we do for the engines or are there more additives in gear oil that help with wear? Never gave a thought to adding zinc. I’m running off-the-shelf 80W gear oil. Share this post Link to post Share on other sites
953 nut 68,930 #36 Posted November 12, 2025 13 hours ago, 702854boy said: would it help to add the zinc additive These are garden tractors, not dragsters or NASCAR race cars. Don't guess it would hurt anything but doubt it would be all that beneficial. 3 Share this post Link to post Share on other sites
702854boy 1,132 #37 Posted November 16, 2025 (edited) Is the whole axle and diff assembly supposed to be able to move back and forth about 3/16 of an inch in the casing once its all together? Edited November 16, 2025 by 702854boy 1 Share this post Link to post Share on other sites
ineedanother 2,851 #38 Posted November 16, 2025 Not to worry. Axles and differentials aren't shimmed like crank shafts. A bit of end play is to be expected. 2 Share this post Link to post Share on other sites
702854boy 1,132 #39 Posted November 16, 2025 What would be the cause of low range not low ranging and just neutral? I do know we will probably have to take the tranny back off the tractor and tear it apart again. 1 Share this post Link to post Share on other sites
702854boy 1,132 #40 Posted November 16, 2025 In low range I am able to shift through all gears with the belt engaged and there is n grinding, if I try to go from low to high with belt engaged there is grinding, other way around, no grinding, high range all gears work 1 Share this post Link to post Share on other sites
Retired Wrencher 6,961 #41 Posted November 16, 2025 On 11/11/2025 at 7:36 PM, ebinmaine said: I don't add anything to our gear oils. They have their own Additive Package. The Wheelhorse transmission is VERY stout and likely won't need help. We run the least expensive gear oil available. Eric Walmart gear lubricant ,that is what I use. 2 Share this post Link to post Share on other sites
ebinmaine 80,488 #42 Posted November 16, 2025 1 hour ago, Retired Wrencher said: Eric Walmart gear lubricant ,that is what I use. Same here 1 Share this post Link to post Share on other sites
702854boy 1,132 #44 Posted November 16, 2025 What would be the cause of low range not working? The shifter goes into both detents but in low range its just neutral and woth the clutch disengaged I am able to shift through all 3 forward and reverse gear with no grinding or movement. In high range everything works as it should. If I try to shift from high to low without clutch there is no grinding but if I try to go low to high there is. 1 Share this post Link to post Share on other sites
702854boy 1,132 #45 Posted November 17, 2025 Well we found out was causing the problem and got the tranny put back together for the third time and put it in the tractor again and now it works and is a lot slower in low gear. I've also got 100 pounds total weight per wheel plus my 135-140 pounds and limited slip and chains I shouldn't be spinning very much this winter. 2 5 Share this post Link to post Share on other sites
702854boy 1,132 #46 Posted May 5 Painted a belt guard and the brake linkage cover and got my 864 logo stuck on. I haven't gotten to take a photo of the belt guard on the tractor as I need to get the right pulley because the one we have is too thick and rubs on the belt guard. @Handy Don, @ri702bill, what pulley did you guys use for your hi-lo 854s? 3 Share this post Link to post Share on other sites
ri702bill 12,937 #47 Posted May 5 Since Don used a Raider 6 speed, all his drive components were stock WH parts - same as a 4 speed. No change in belt length either. I used a C81 8 speed with the 5/8" input shaft. I got my pulley from McMaster - same OD as the 4 speed one. I do not recall the part number. I do remember I had to use an 89" long belt, not the OE 90" one... 1 Share this post Link to post Share on other sites
Handy Don 17,400 #48 Posted May 5 12 hours ago, 702854boy said: I haven't gotten to take a photo of the belt guard on the tractor as I need to get the right pulley because the one we have is too thick and rubs on the belt guard. @Handy Don, @ri702bill, what pulley did you guys use for your hi-lo 854s? The transaxle drive pulley on the 6-speeds is unusual in that the sheave must run very, very close to the transaxle body (~.125”) to maintain the proper belt alignment to the small block K181. As well, the input shaft is very short, not leaving enough room for a hub on the side away from the transaxle case. To accommodate both requirements, the stock pulley has the setscrew in the valley of the sheave. My transaxle came without the pulley (which should have gotten my attention!). After not finding a suitable after-market pulley I finally got a used one. I would check with the vendors on this site--AtoZ (CALL Lincoln, don’t email) and K&B horse parts (Brian Badman @76c12091520h) Share this post Link to post Share on other sites
cafoose 3,826 #49 Posted May 5 9 minutes ago, Handy Don said: The transaxle drive pulley on the 6-speeds is unusual in that the sheave must run very, very close to the transaxle body (~.125”) to maintain the proper belt alignment to the small block K181. As well, the input shaft is very short, not leaving enough room for a hub on the side away from the transaxle case. To accommodate both requirements, the stock pulley has the setscrew in the valley of the sheave. I'm thinking of putting a 6-speed in a 953 with a sickle. @953 nut says because of the brakes I need to use a 6-speed and not an 8-speed. So if I look for a high/low transaxle with the setscrew in the drive pulley am I safe to say that's a 6-speed? 1 Share this post Link to post Share on other sites
Handy Don 17,400 #50 Posted May 5 1 minute ago, cafoose said: I'm thinking of putting a 6-speed in a 953 with a sickle. @953 nut says because of the brakes I need to use a 6-speed and not an 8-speed. So if I look for a high/low transaxle with the setscrew in the drive pulley am I safe to say that's a 6-speed? The easier way is to look at the brake drum location and rotation. On six-speeds, the drum & band are very close to the rear axle housing (i.e. within an inch or two). On 8-speeds, they are three or four inches away. If the donor is on a tractor, then you can check the drum rotation: clockwise when the tractor is moving forward on six speeds; counter-clockwise on 8-speeds. Another look is the linkage attachment: six-speed linkage attaches at the end of the band clockwise from the case mounting tab; 8-speed at the end of the band counter-clockwise from the mounting tab. This is a six-speed brake 4 Share this post Link to post Share on other sites
