Farmer Forbes 8 #1 Posted October 24, 2025 To all of you mechanically inclined folks out there, I need your assistance. I own a 1975 C-100 Wheel Horse and am updating some of the parts on the tractor. I happened to notice the stud bolt (Part # 104842) was broken inside the PTO, so after much anguish I was able to remove the remainder of the bolt (It had lock-tite on the threads). I found a replacement part and need to know the following: 1. How far should the stud bolt be screwed into the shaft? 2. What is the orientation of the 2 x washers and 1 x thrust bearing? 3. Which direction does the thrust bearing face, towards or away from the engine? Any assistance would be greatly appreciated since I was not able to locate any information about this online. Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,256 #2 Posted October 24, 2025 Have never pit one back together. Instead replaced the outer pto shaft to a new one that has a snap ring on both sides of the outer ball bearing. That way the pto linkage pulls the bell out instead of using the original parts you have. The stub shaft uses the same 102872 part number that now has two snap ring grooves. All the internal parts you are dealing with can be omitted. The shaft and two retaining rings required. https://www.partstree.com/models/31-12k801-312-8-toro-garden-tractor-1990/pto-clutch-and-control-47/ Here is an original illustrated parts list in case you do not have it. Share this post Link to post Share on other sites
Farmer Forbes 8 #3 Posted October 24, 2025 Thanks for your prompt reply. I appreciate the option you provided along with the attachments Share this post Link to post Share on other sites
Racinbob 12,980 #4 Posted October 25, 2025 I did that same modification than gwest did on my 76 Reborn B-80. I had the same issue you have, broken stud. Works better and I will make the change if I ever have mess with another one. Share this post Link to post Share on other sites
Farmer Forbes 8 #5 Posted October 25, 2025 Thanks for your input Racinbob. Share this post Link to post Share on other sites
peter lena 9,893 #6 Posted October 25, 2025 @gwest_ca love the pto breakdown diagram , very typical set up over the years . starting with # 11 , clutch rod , mounting set up and detailing function as you go , amazing how easily , solidly it can function , my first sloppy connection transition, led me to eliminate , every wobbly , hand off , that led me to related bearing failures . been years now on my 3 horses , solid smooth and no screaming / squealing pto engagement . the other very interesting thing , is that your initial , view of it , is not seen ? paint it red / black , it disappears , that heim joint replacement , from the sloppy trunnion , has led me to go to that very often . killer on a plow set up . realise its not original , but repetitive problem is ? guy I sold a tractor too , thought clutch ,and pto were broken? clutch pedal had no, squealing / binding to it , pto lever was smooth / and silent . improve as you go , pete Share this post Link to post Share on other sites
Farmer Forbes 8 #7 Posted October 25, 2025 Thanks Pete, and just so I am clear do I need to purchase items 33-36 or just 33 & 34 x pcs? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,256 #8 Posted October 25, 2025 Just #33 and 2 of #34. If you have access to a lathe you could cut a second groove in #33. The ball bearing goes between the two grooves. Should replace a retaining ring once it is used. They lose their shape and tension. When retaining rings are made they are stamped. One side has rounded edges and the other has sharp edges. The sharp edges have more holding power. The outer ring should have the sharp edge out and the inner ring have the sharp edge in towards the engine. The outer ring pushes the bearing in and the inner ring pulls the bearing away from the engine. It would be a good time to replace the bearing if you can and save the old one for a spare. 1 Share this post Link to post Share on other sites
Farmer Forbes 8 #9 Posted October 25, 2025 Thanks for all of the replies. I should be able to take it from here. 1 Share this post Link to post Share on other sites
Lee1977 7,638 #10 Posted October 25, 2025 If you need the out side PTO bearing it is P204RR6 or Z9504RST 0.75" ID, 1.7805" OD. and 0,610 " width. This bearing is also used in JD mower spindles so it's easy to find. 1 Share this post Link to post Share on other sites
