Joefrommi65 26 #1 Posted October 19, 2025 I was wondering what electric fuel pump would work for a 416-8 whith an onan motor i broke the nipple trying to replace the fuel lines and saw some of you folks are switching to electric pumps. Thanks Share this post Link to post Share on other sites
ebinmaine 80,739 #2 Posted October 19, 2025 I keep a list of fuel pumps handy. Facet 60245 or 60304. Mr. Gasket 42s. Carter P4070. I use and recommend the Facet 60245. 3 Share this post Link to post Share on other sites
Joefrommi65 26 #3 Posted October 19, 2025 (edited) Thanks very much so I take it max 3.5 psi fuel pressure Edited October 19, 2025 by Joefrommi65 2 Share this post Link to post Share on other sites
Achto 32,729 #4 Posted October 19, 2025 2 hours ago, Joefrommi65 said: so I take it max 3.5 psi fuel pressure Anything under 4psi is good. 1 1 Share this post Link to post Share on other sites
Joefrommi65 26 #5 Posted October 19, 2025 Thank you Share this post Link to post Share on other sites
Retired Wrencher 6,989 #6 Posted October 20, 2025 (edited) I have been using this for a few years now. I figured if it’s good enough for lightweight aircraft it’s good enuf to power a Kohler engine. They are a little bit expensive as you can see, but I’ve had good luck with them starts right up. It is one to two psi. Edited October 20, 2025 by Retired Wrencher 3 Share this post Link to post Share on other sites
Joefrommi65 26 #7 Posted October 20, 2025 Thanks do you have a part number on that pump as I didn't see it in the picture 1 Share this post Link to post Share on other sites
ebinmaine 80,739 #8 Posted October 20, 2025 4 hours ago, Joefrommi65 said: Thanks do you have a part number on that pump as I didn't see it in the picture 1 Share this post Link to post Share on other sites
ebinmaine 80,739 #9 Posted October 20, 2025 4 hours ago, Joefrommi65 said: Thanks do you have a part number on that pump as I didn't see it in the picture Either of the two Facet pumps I listed above will work fine. 1 Share this post Link to post Share on other sites
sqrlgtr 3,945 #10 Posted October 20, 2025 Facet Cube 12v Fuel Pump, 1/8 NPT, 1.5-2.5 psi Part# FAC-40163 (1.5 to 2.5psi) is one I ordered to use on my 857 but decided to rebuild original fuel pump instead. I ordered this pump before I found the great rebuild kits from Then and Now automotive. I assume this pump I ordered would work fine but like the looks of the pumps that those above have listed better. 1 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #12 Posted October 21, 2025 22 hours ago, Joefrommi65 said: Thanks do you have a part number on that pump as I didn't see it in the picture #60304 when you get on the site you will find a list of all pumps that they make. Depending on your horsepower as I only use it for an 8 hp I chose the 1-to 2 psi 1 Share this post Link to post Share on other sites
Joefrommi65 26 #13 Posted October 21, 2025 Thank you Share this post Link to post Share on other sites
