markseven 72 #1 Posted October 12 Is the correct length 1/2 ×107 ? Share this post Link to post Share on other sites
953 nut 63,106 #2 Posted October 12 Is this the drive belt for the tractor or a mower deck? If it is a mower deck, what size deck? These charts will come in handy. Share this post Link to post Share on other sites
markseven 72 #3 Posted October 12 37 minutes ago, 953 nut said: Is this the drive belt for the tractor or a mower deck? If it is a mower deck, what size deck? These charts will come in handy. Thanks im letting Lowell take care of it... Share this post Link to post Share on other sites
mrc 1,020 #4 Posted October 12 going by memory here as i'm not near my wh reference material right now. i think it should be a wh 7478 belt. which is 5/8 x 84 inches. this is the belt that goes from the engine to the tranny Share this post Link to post Share on other sites
daveoman1966 3,881 #5 Posted October 13 IMHO--- Your bronco 14 (like mine) is 50+ years old. Get the OEM belt 7478. A few bucks more, but money well spent. While after-market belts may match the width/length, they are not usually geometrically the same and won't last for decades like the OEM belts. Keep in mind---it's only money. gears-and-pulleys.webp Share this post Link to post Share on other sites
peter lena 9,565 #6 Posted October 13 @markseven would also suggest , that you physically hands on MOVEMENT CHECK , EVERY RELATED PULLEY . INCREMENTAL LUBRICATION FAILURE , adds up to eating belts , have people in my area , that never correct any mower issue , you cAN TELL THAT , BY THE SCREAMING BELT ENGAGEMENT TO ANY DRIVE SET UP . that goes for clutch pedal engagement , as well as pto lever arm set up . none of mine do that , just a suggestion , pete Share this post Link to post Share on other sites
