sqrlgtr 3,173 #1 Posted October 2, 2025 (edited) This a first for me, this chiiinaa carb weeps fuel out of top of carb. I had stuck it on awhile back and it runs out ok but I have a couple Carter n carbs that I rebuilt this week so one of these will be going on the 857 along with the rebuilt fuel pump ready for another 50years of service. Edited October 7, 2025 by sqrlgtr 2 1 Share this post Link to post Share on other sites
sqrlgtr 3,173 #2 Posted October 2, 2025 Forgot pic of the 2 N carbs. I like pics lol 3 Share this post Link to post Share on other sites
ri702bill 12,395 #3 Posted October 2, 2025 Porous casting??? Share this post Link to post Share on other sites
sqrlgtr 3,173 #4 Posted October 3, 2025 2 hours ago, ri702bill said: Porous casting??? @ri702bill only thing I can figure. I looked over it best I could, but never seen anything but my ol eyes ain't what they use to be. Share this post Link to post Share on other sites
ri702bill 12,395 #5 Posted October 3, 2025 (edited) I worked as an Assembler years ago for a local company that built valves for the Chemical, Petroleum, and Nuclear Industries. Once built, they would be hydro tested - tap water inside pressurized to usually 5000 PSI. Amazing how many were leak free at 4500 PSI, but failed at 5000. Edited October 3, 2025 by ri702bill 3 Share this post Link to post Share on other sites
lynnmor 8,875 #6 Posted October 3, 2025 8 hours ago, sqrlgtr said: @ri702bill only thing I can figure. I looked over it best I could, but never seen anything but my ol eyes ain't what they use to be. Did you look inside at the float, needle and seat? Any debris in the bowl or passages? Share this post Link to post Share on other sites
Retired Wrencher 6,768 #7 Posted October 3, 2025 15 hours ago, sqrlgtr said: Forgot pic of the 2 N carbs. I like pics lol Those carbs today are like gold. Hard to find a real carburetor today that will work on your engine. And if you do find one, they’re big dollars. Glade you saved them. 1 1 Share this post Link to post Share on other sites
sqrlgtr 3,173 #8 Posted October 3, 2025 1 hour ago, lynnmor said: Did you look inside at the float, needle and seat? Any debris in the bowl or passages? @lynnmor yeah, I've had off more times than I would like to admit lol. I finally came to the conclusion it's just junk. If it didn't leak, I would be satisfied with it, but it just keeps on dripping. It does seem to go way lean in a long hard pull so it may go from weeping to drawing air IDK. @Retired Wrencher agreed. Share this post Link to post Share on other sites
sqrlgtr 3,173 #9 Posted October 7, 2025 Update on carb finally found out where leak was coming from.... Fuel fitting in top of carb hade a pin hole in it and was spraying very fine mist of fuel on to top of carb! Never seen anything like it lol. Replaced fitting and should be good to go for a long time. Im glad it wasnt carb because it rund great and works good . 2 Share this post Link to post Share on other sites
