sqrlgtr
Chineseium Carb trouble
sqrlgtr
This a first for me, this chiiinaa carb weeps fuel out of top of carb. I had stuck it on awhile back and it runs out ok but I have a couple Carter n carbs that I rebuilt this week so one of these will be going on the 857 along with the rebuilt fuel pump ready for another 50years of service.
sqrlgtr
Forgot pic of the 2 N carbs. I like pics lol
ri702bill
Porous casting???
sqrlgtr
2 hours ago, ri702bill said:
Porous casting???
@ri702bill only thing I can figure:unsure:. I looked over it  best I could, but never seen anything but my ol eyes :geek: ain't what they use to be.
ri702bill
I worked as an Assembler years ago for a local company that built valves for the Chemical, Petroleum, and Nuclear Industries. Once built, they would be hydro tested - tap water inside pressurized to usually 5000 PSI. Amazing how many were leak free at 4500 PSI, but failed at 5000.
Edited by ri702bill
lynnmor
Did you look inside at the float, needle and seat?  Any debris in the bowl or passages?
Retired Wrencher
Those carbs today are like gold. Hard to find a real carburetor today that will work on your engine. And if you do find one, they’re big dollars. Glade you saved them.
sqrlgtr
@lynnmor yeah, I've had off more times than I would like to admit lol. I finally came to the conclusion it's just junk. If it didn't leak, I would be satisfied with it, but it just keeps on dripping. It does seem to go way lean in a long hard pull so it may go from weeping to drawing air IDK.
@Retired Wrencher agreed.
