markseven 62 #1 Posted September 29 I have this Bronco 14 the k321 and the points are behind the flywheel I believe I don't know if it's an actual set of points or it's just a module still does run good but I'm thinking I'd like to convert it over where you put the points where they would normally go external engine up by the carburetor low left how hard is this to do. And who would have the parts ? Coil points condenser cover for point etc Share this post Link to post Share on other sites
953 nut 62,565 #2 Posted September 29 Your Bronco probably has the electronic ignition with a trigger under the flywheel. Here is a thread that should give the information you need. 1 Share this post Link to post Share on other sites
ebinmaine 74,934 #3 Posted September 29 I'm curious to know why we would want to change the ignition? Does the tractor run? 1 Share this post Link to post Share on other sites
pfrederi 19,076 #4 Posted September 29 The Kohler Breakerless ignition system that you have either works well or not at all. If it is workring it has advantages over the Battery points system. No points to corrode or need adjusting... timing is perfect... I would leave it alone, it may run for years...if it does die then convert. 7 Share this post Link to post Share on other sites
markseven 62 #5 Posted September 29 1 hour ago, ebinmaine said: I'm curious to know why we would want to change the ignition? Does the tractor run? Yes it actually runs fine but I would rather convert it now when I have some time and eventually its going to be my kids tractor and im the electrician . 2 1 Share this post Link to post Share on other sites
ebinmaine 74,934 #6 Posted September 29 1 minute ago, markseven said: Yes it actually runs fine but I would rather convert it now when I have some time and eventually its going to be my kids tractor and im the electrician . I'm with Paul above. The system you have is from the early days of electronic ignition, if you will. It's a very good reliable system while it's working. The most I would do for that system is to remove the engine shrouds and clean everything. Points are simple. Yes. And also reliable. Yes. But the system you have is at least as good. 1 Share this post Link to post Share on other sites
Maz91 296 #7 Posted September 29 I’ve seen this before.. You tube “How-To Convert Kohler Breakerless Ignition System to Breaker Points Ignition System | Kohler Engine” by isavetractors. In the video he says like the others here to do the conversion if the factory ignition fails. There is also a fair amount of parts involved and isavetractors is no longer in business so the cost and availability are worth considering. 1 Share this post Link to post Share on other sites
ebinmaine 74,934 #8 Posted September 29 4 minutes ago, Maz91 said: cost and availability are worth considering. I like Norman as a person but he closed for a reason. Parts availability is still perfectly fine and his prices were nothing special. Share this post Link to post Share on other sites
markseven 62 #9 Posted September 29 2 hours ago, pfrederi said: The Kohler Breakerless ignition system that you have either works well or not at all. If it is workring it has advantages over the Battery points system. No points to corrode or need adjusting... timing is perfect... I would leave it alone, it may run for years...if it does die then convert. Good point? 2 Share this post Link to post Share on other sites
kpinnc 15,931 #10 Posted September 29 Mine still works. If it ever quits, you can convert to points from the outside. The pin hole for the points push rod is plugged but easily removed. New keyswitch, coil, points, and cables. Easy but not cheap fix. You basically have to rewire the whole thing. 4 Share this post Link to post Share on other sites
oliver2-44 11,023 #11 Posted September 29 5 hours ago, markseven said: eventually its going to be my kids tractor and im the electrician . Now's a great time to teach them. But yes I know they have to be interested! 1 Share this post Link to post Share on other sites
Maz91 296 #12 Posted September 29 8 hours ago, ebinmaine said: I like Norman as a person but he closed for a reason. Parts availability is still perfectly fine and his prices were nothing special. Yea it was a ransomeware attack on his third party warehouse/shipper. I was really just pointing out the how-to video that I’d seen before. and since it requires multiple parts the cost may be something to consider. He plugs them in the video so figured I’d mention that isavetractors is closed before he went trying to find them there. Share this post Link to post Share on other sites
markseven 62 #13 Posted September 30 Does my bronco 14 have the voltage rectifier external or is that behind the flywheel next to the stator Share this post Link to post Share on other sites
kpinnc 15,931 #14 Posted September 30 3 hours ago, markseven said: Does my bronco 14 have the voltage rectifier external or is that behind the flywheel next to the stator Should be external. May be mounted behind the dash tower. If not it's mounted on the engine tins. 1 Share this post Link to post Share on other sites
953 nut 62,565 #15 Posted September 30 Your voltage regulator should look like this one mounted in the hood stand. 1 Share this post Link to post Share on other sites
Maz91 296 #16 Posted October 1 16 hours ago, 953 nut said: Your voltage regulator should look like this one mounted in the hood stand. This absolute disaster of a garage looks just like my garage 🤪 1 Share this post Link to post Share on other sites
953 nut 62,565 #17 Posted October 1 18 hours ago, Maz91 said: This absolute disaster of a garage looks just like my garage 🤪 Not my garage, I borrowed that photo from another thread to show where the regulator is mounted. 1 Share this post Link to post Share on other sites
Maz91 296 #18 Posted October 2 (edited) It’s my garage hahaha @953 nut Edited October 2 by Maz91 Tagged a member 1 1 Share this post Link to post Share on other sites
