JSW 9 #1 Posted September 27, 2025 Does anyone know the o ring sizes used between the manifold and hyd.motor on d series? Share this post Link to post Share on other sites
pfrederi 19,859 #2 Posted September 27, 2025 The sealing washer is 102817. I use a sealing washer from McMaster I have all the rings and the washer. PM your address and I will send you a set. 1 Share this post Link to post Share on other sites
JSW 9 #3 Posted September 27, 2025 Thank You for the information! Jerry 1 Share this post Link to post Share on other sites
Wild Bill 633 905 #4 Posted September 28, 2025 FYI, Marco has an O-ring catalog you can download for reference. Also, another source for Stat-O-Seals is Earl's Performance Plumbing. 1 Share this post Link to post Share on other sites
JSW 9 #5 Posted September 28, 2025 Thanks for the info. WB Share this post Link to post Share on other sites
peter lena 9,752 #6 Posted September 28, 2025 @ jsw might consider using a lubricant on that set up , we always used a specific dielectric lube , prevents rubber binding / sealing agent , binding / grabbing o rings stretches them out and also causes them to roll when tightened , pete Share this post Link to post Share on other sites
