peter lena 9,812 #1 Posted September 19, 2025 just got a batch of shingles for , re topping shed roofs , found best way to move bulk weight , 1st gear low range , easily turns heavy bulk weight into a slow sliding , set up , using plow blade , on grass slide point , did not even tear up any grass areas . that blade width , was the answer to total control of bulk weight . always experimenting with an improvement to a problem , no clutch issues , it all moved easily , pete 3 Share this post Link to post Share on other sites
953 nut 64,858 #2 Posted September 19, 2025 Now if you could only put the shingles up on the roof that way, gotsta work on that. 1 Share this post Link to post Share on other sites
peter lena 9,812 #3 Posted September 19, 2025 @953 nut got that covered too , got a guy coming over , to do a number of house , upgrades , my days of doing that are over . pete Share this post Link to post Share on other sites
953 nut 64,858 #4 Posted September 19, 2025 13 minutes ago, peter lena said: my days of doing that are over I'm right there with you. Seems to me they are making shingles (and everything else) heavier than they were 30 years ago. When I was 50 I could put a bundle of shingles on my shoulder and climb up a ladder with no problem, by the time I was 60 the shingles were heavier and I could only do a half bundle at a time. now they make them so heavy I can only lift a couple at a time , , , , and as for a ladder , , , , 2 2 Share this post Link to post Share on other sites
8ntruck 8,701 #5 Posted September 19, 2025 I'm not crazy, then. I've been having the same thoughts. 2 1 Share this post Link to post Share on other sites
peter lena 9,812 #6 Posted September 19, 2025 @8ntruck been at this house 45 years , was a regular thing to be involved in every aspect of it , the real thing that gets me is that the related pricing , makes you shop around , found a guy that was in building maintenance , branched out on his own , and has been very / satisfying , to do a number of things . he is always busy , and will also give you a heads up on opportunity , or recommend / suggest , alternative . you have to realise , you are not , mid life any more . pete 1 Share this post Link to post Share on other sites
953 nut 64,858 #7 Posted September 19, 2025 6 hours ago, peter lena said: you have to realise , you are not , mid life any more Are you telling me I won't live to be 160? Guess I had figured that out myself. Share this post Link to post Share on other sites
Marv 994 #8 Posted September 20, 2025 7 hours ago, peter lena said: @8ntruck been at this house 45 years , was a regular thing to be involved in every aspect of it , the real thing that gets me is that the related pricing , makes you shop around , found a guy that was in building maintenance , branched out on his own , and has been very / satisfying , to do a number of things . he is always busy , and will also give you a heads up on opportunity , or recommend / suggest , alternative . you have to realise , you are not , mid life any more . pete long gone. Marv Share this post Link to post Share on other sites
