JoeM 9,390 #1 Posted September 18, 2025 Seen this rust proofing stuff from Eastwood on the interweb, interesting. $30 a can ish. 3 Share this post Link to post Share on other sites
adsm08 3,979 #2 Posted September 18, 2025 Yup. Worked with a guy who used this when repairing uni-bodies. Swears by it. 1 Share this post Link to post Share on other sites
peter lena 9,642 #3 Posted September 18, 2025 @JoeM thanks for the shout ! been doing that for a very long time , the newer cars / trucks out there with heavy solid rust , is scary , like the 2 stage lubrication creep . lighter penetrating oil at / in highest body areas ,chain / cable spray picture an oil creep down , thats the spread , and verifies every seam , and boxed zone , then an over spray with open / gear spray , that tracks over / into the boxed areas , showing film , then full bottom coating , never had any peel off or rust , fender trim is solid , zero anything . another thing about lubricants , once they seal off , you are good , talking years out , also wash my cars . all of my door bottom seaming , is lubrication , tracked , full length , my tractors also have a lot of , attachment related lube experiments , think the plow set up is just so smooth / easy to use . run by quadrant spring . pto lever set up is ridiculous , lubricants again take the lead . pete 2 Share this post Link to post Share on other sites
