953 nut 69,337 #26 Posted September 19, 2025 8 hours ago, WHX?? said: boiled linseed oil. Anyone using boiled linseed oil needs to be aware of the potential for spontaneous combustion. ANYTHING, rags, brushes etc. with linseed oil on it must be dried in an open area away from your shop or stored in a firesafe container. 4 1 Share this post Link to post Share on other sites
WHX?? 58,143 #27 Posted September 20, 2025 1 hour ago, 953 nut said: potential for spontaneous combustion This I did not know ... thank you. 2 Share this post Link to post Share on other sites
ebinmaine 80,714 #28 Posted September 20, 2025 3 hours ago, 953 nut said: Anyone using boiled linseed oil needs to be aware of the potential for spontaneous combustion. ANYTHING, rags, brushes etc. with linseed oil on it must be dried in an open area away from your shop or stored in a firesafe container. The interwebs shows this for penetrol as well. 1 1 Share this post Link to post Share on other sites
kpinnc 18,967 #29 Posted September 20, 2025 (edited) 2 hours ago, ebinmaine said: spontaneous combustion. ANYTHING, I am prone to the same- and have the same label printed somewhere... I know because my wife kept the manual after the purchase... Edited September 20, 2025 by kpinnc 2 1 1 Share this post Link to post Share on other sites
Lane Ranger 12,106 #30 Posted September 20, 2025 21 hours ago, WHX?? said: I agree with everything Bob but that statement. If you take away the oxygen the rust will stop. Say by coating with grease or oil or even WD-40. We have this discussion every year at plow day about our shares & lots of guys just use WD and it seems to work. Funny no one has mentioned boiled linseed oil. Now I have only used it one or twice but it seems to work. It dries and protects put it does attract dust which usually washes off in mild soap and water. It leaves a dull patina which I prefer. I believe patinas shouldn't be shiny unless a custom. It probably should be reapplied every so often. This 400 was done with it. There is no such thing as wrong decals Don .. unless they say JD ... Nice tractors this thread fellas ... Jim: I like the boiled linseed oil too. I have used on two or three of my Wheel Horse tractors. I put on this latest RJ. D.J. Harrison says. GIBBS Oil also is a good coating to place on tractors to protect the metal and patina look. 3 Share this post Link to post Share on other sites
squonk 48,126 #31 Posted September 20, 2025 I keep a supply of cheap Horror Fright chip brushes on hand. After use they go in the trash and can spontaneously combust in the landfill Share this post Link to post Share on other sites
953 nut 69,337 #32 Posted September 20, 2025 5 minutes ago, squonk said: After use they go in the trash and can spontaneously combust in the landfill Or in the garbage truck. Share this post Link to post Share on other sites
lynnmor 9,040 #33 Posted September 20, 2025 1 hour ago, 953 nut said: Or in the garbage truck. That's where my old lithium batteries explode. 1 Share this post Link to post Share on other sites
