terc 24 #1 Posted September 17 Hello All I recently picked up a barn find commando 8. I'm still trying to decide what I want to do with this tractor, Since the body parts have lost most of the paint color, I need to get started with the 8hp Kohler engine, that may a deciding factor as to what I do with tractor There are no rust holes only the sheet metal has a lot of surface rust. So what do you guys say about this tractor. 4 1 Share this post Link to post Share on other sites
WHX?? 52,408 #2 Posted September 17 It's got good bones. 3 Share this post Link to post Share on other sites
ebinmaine 73,893 #3 Posted September 17 S/G engine with stirrups on a Commando?? Must be a very early one... I'll bet there's more red paint under there than one might think. 2 Share this post Link to post Share on other sites
terc 24 #4 Posted September 17 ebinmaine - I guess the big question is how or what do i use to find out how much paint is under that current patina. I have always accustomed to using a wire brush then spraying with a rusty metal primer. If its not a lot of work I would like to save whatever is there, just have never done that process 1 Share this post Link to post Share on other sites
WHGuy413 2,796 #5 Posted September 17 27 minutes ago, ebinmaine said: S/G engine with stirrups on a Commando?? Must be a very early one... I'll bet there's more red paint under there than one might think. @WheelHorse_Kid has a Commando 8 with s/g and stirrup foot rests. 17 minutes ago, terc said: ebinmaine - I guess the big question is how or what do i use to find out how much paint is under that current patina. I have always accustomed to using a wire brush then spraying with a rusty metal primer. If its not a lot of work I would like to save whatever is there, just have never done that process I would suggest a deep degrease and a gentle pressure washing first. Some guys have had success with a light wet sanding. I haven’t tried it on anything yet. 4 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,622 #6 Posted September 17 2 Share this post Link to post Share on other sites
Lee1977 7,315 #7 Posted September 17 Has anybody tried Scotch-brite pads, they come in different roughness and are a little gentler then sandpaper. I have used them on rusted tools, never tried them on a rusted tractor. 1 Share this post Link to post Share on other sites
Pullstart 67,528 #8 Posted September 17 (edited) You’d be blown away at how much paint is still under all that rust! 600 grit wet/dry paper and some dish soapy water. Easy gentle strokes forward and backward. Keep it wet. Avoid the radiuses too much, they will wear faster. Go slow and check your results occasionally. Here is an example, this one was about as rusty as well. We also ran a little buffing compound across it at the 2018 Big Show too. Edited September 17 by Pullstart 2 1 Share this post Link to post Share on other sites
squonk 44,262 #9 Posted September 17 Smooth it down with scotch pads then wipe or brush this on it. Available at Lowes. 3 1 Share this post Link to post Share on other sites
953 nut 61,270 #10 Posted September 17 I have used steel wool, 400 wet/dry sandpaper on a flexible sanding block, and WD-40 to bring back the red that is hidden under the rust. Regardless of the type of abrasive (scotch-brite, wet dry paper, steel wool) use a random pattern and light downforce when you work large areas like the hood and fender pan. If you go diagonally (left front to right rear alternating to right front to left rear) your strokes will less noticeable. 2 Share this post Link to post Share on other sites
peter lena 9,373 #11 Posted September 17 @terc never used anything to remove long acquired patina , have always given it the penetrating oil soak down . also mineral oil . time and coverage , also enhances this , heat / sun or dry shop is perfect spot , for existing paint / patina look . biggest mistake is rushing this , you are looking at neglect . think the chalky state is best for saving . done a lot of this , left areas around , recovered spots as reference , emphasis is phases ,try spots , expect stages , not a fresh paint . another thing , is regular lubrication rub downs , clean cloth , mineral oil , pay attention to effect as you go , pete Share this post Link to post Share on other sites
rmaynard 16,480 #12 Posted September 17 I know that I'm going to get a lot of pushback on this, but here goes. Patina: A: Usually a green film formed naturally on copper and bronze by long exposure or artificially (as by acids) and often valued aesthetically for its color B: A surface appearance of wood grown beautiful by the touching of humans leaving oils that get darker and richer over time. Rust: The reddish brittle coating formed on iron/steel especially when chemically attacked by moist air and composed essentially of hydrated ferric oxide. Nice find. I love my Commando 8. But Patina? Nope, that's rust. No matter what you put on it, rust will continue to slowly eat away at the metal. 5 Share this post Link to post Share on other sites
rjg854 12,402 #13 Posted September 17 13 hours ago, ebinmaine said: S/G engine with stirrups on a Commando?? Must be a very early one... both of my Commandos are like that 3 Share this post Link to post Share on other sites
WHGuy413 2,796 #14 Posted September 17 4 hours ago, Pullstart said: You’d be blown away at how much paint is still under all that rust! 600 grit wet/dry paper and some dish soapy water. Easy gentle strokes forward and backward. Keep it wet. Avoid the radiuses too much, they will wear faster. Go slow and check your results occasionally. Here is an example, this one was about as rusty as well. We also ran a little buffing compound across it at the 2018 Big Show too. I remember that tractor well! After you bought it it looked like a whole new rig. 2 Share this post Link to post Share on other sites
ebinmaine 73,893 #15 Posted September 17 2 hours ago, rjg854 said: both of my Commandos are like that Very interesting. We've had a Raider or two and a Charger go through our herd in the past but never seen a Commando here. I never knew the early ones were stirrup type. Always thought they were the first generation of Side Step Horses. Share this post Link to post Share on other sites
rjg854 12,402 #16 Posted September 17 2 hours ago, ebinmaine said: Very interesting. We've had a Raider or two and a Charger go through our herd in the past but never seen a Commando here. I never knew the early ones were stirrup type. Always thought they were the first generation of Side Step Horses. Basically the same as a 856 1 Share this post Link to post Share on other sites
ebinmaine 73,893 #17 Posted September 17 1 minute ago, rjg854 said: Basically the same as a 856 Is a Commando Short frame or long frame? Share this post Link to post Share on other sites
squonk 44,262 #18 Posted September 17 25 minutes ago, ebinmaine said: Is a Commando Short frame or long frame? Shorty 1 1 Share this post Link to post Share on other sites
rjg854 12,402 #19 Posted September 17 51 minutes ago, ebinmaine said: Is a Commando Short frame or long frame? 5 Share this post Link to post Share on other sites
c-series don 10,316 #20 Posted September 17 Here’s my Commando, with the wrong hood decals! 2 Share this post Link to post Share on other sites
Retired Wrencher 5,971 #21 Posted September 19 On 9/16/2025 at 8:48 PM, terc said: ebinmaine - I guess the big question is how or what do i use to find out how much paint is under that current patina. I have always accustomed to using a wire brush then spraying with a rusty metal primer. If its not a lot of work I would like to save whatever is there, just have never done that process Terc: I would just clean everything with some gas make sure there’s no oil or grease anywhere one part at a time. And I always choose Marvel mystery oil with a rag and wipe all metal parts down. wipe off excess. This bring back the patina that is there. There are other methods, but I find this much easier. Just take your time with it and you’ll be happy. This is how mine came out. 1 1 Share this post Link to post Share on other sites
squonk 44,262 #22 Posted September 19 WD 40 or Mystery oil can stay sticky and attract dirt. Penetrol dries and it's as easy to put on as the others. I did these Suburban fenders a year ago and they still shine. 3 1 Share this post Link to post Share on other sites
WHX?? 52,408 #24 Posted September 19 On 9/17/2025 at 8:51 AM, rmaynard said: No matter what you put on it, rust will continue to slowly eat away at the metal. I agree with everything Bob but that statement. If you take away the oxygen the rust will stop. Say by coating with grease or oil or even WD-40. We have this discussion every year at plow day about our shares & lots of guys just use WD and it seems to work. Funny no one has mentioned boiled linseed oil. Now I have only used it one or twice but it seems to work. It dries and protects put it does attract dust which usually washes off in mild soap and water. It leaves a dull patina which I prefer. I believe patinas shouldn't be shiny unless a custom. It probably should be reapplied every so often. This 400 was done with it. On 9/17/2025 at 4:46 PM, c-series don said: with the wrong hood decals! There is no such thing as wrong decals Don .. unless they say JD ... Nice tractors this thread fellas ... 1 1 1 Share this post Link to post Share on other sites
squonk 44,262 #25 Posted September 19 Another pic of the fender done with Penetrol. Why use something that attracts dirt? Share this post Link to post Share on other sites
