slim67 2,825 #1 Posted September 16, 2025 I picked this up today while I was on marketplace looking for just any aerator. I've had a couple in the past but not built like this one. I actually need one this time and lucked out finding this one. I've seen a lot of Wheelhorse implements but never seen a spiker aerator. 1 8 Share this post Link to post Share on other sites
c-series don 11,759 #2 Posted September 16, 2025 Wow! Good score! I have a similar one made by Ohio Steel, needs plenty of weight to be effective. 2 Share this post Link to post Share on other sites
ebinmaine 77,975 #3 Posted September 16, 2025 Looks pointy. 1 Share this post Link to post Share on other sites
slim67 2,825 #4 Posted September 16, 2025 31 minutes ago, c-series don said: Wow! Good score! I have a similar one made by Ohio Steel, needs plenty of weight to be effective. Yes its got plenty of room on top for ballast of any sorts. Definitely going to use it this fall, 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,092 #5 Posted September 17, 2025 I'm thinking it should be a model 7-2411 but that does not look like what is on the plate. Looks like 7-2311 which is a lawn roller. The 7 on the end makes it a 1972 model. 1 Share this post Link to post Share on other sites
slim67 2,825 #6 Posted September 17, 2025 10 hours ago, gwest_ca said: I'm thinking it should be a model 7-2411 but that does not look like what is on the plate. Looks like 7-2311 which is a lawn roller. The 7 on the end makes it a 1972 model. Thanks for looking it up and you are correct. I found the manual last night and am happy its available. Could have someone accidently put the wrong tag on during the manufacturing process? One of those Monday/Friday workers? Share this post Link to post Share on other sites
peter lena 9,812 #7 Posted September 17, 2025 @slim67 nice pick up , those dry , rusty movement areas , mineral oil / penetrant , also red aerosol grease , spray tube extension , flip that over on a bench , and VERIFY LUBRICATION effect , should / can move with ease , also wheels . pete Share this post Link to post Share on other sites
slim67 2,825 #8 Posted September 17, 2025 7 hours ago, peter lena said: @slim67 nice pick up , those dry , rusty movement areas , mineral oil / penetrant , also red aerosol grease , spray tube extension , flip that over on a bench , and VERIFY LUBRICATION effect , should / can move with ease , also wheels . pete I sure will Pete, thanks! 1 Share this post Link to post Share on other sites
