Easton Rich 1,260 #1 Posted September 14, 2025 Bought a 520-H and a 656 today, kind of impulse buys, but I’m happy! The two are getting delivered tomorrow. What should I expect? The 520 doesn’t run but it’s in decent shape. The 656 on the other hand, a little worse, sorry a LOT worse. Pictures when they come tomorrow 2 Share this post Link to post Share on other sites
wallfish 20,618 #2 Posted September 14, 2025 2 minutes ago, Easton Rich said: What should I expect Check for spark and clean the carbs. Every tractor I have ever bought was an impulse buy 4 Share this post Link to post Share on other sites
Easton Rich 1,260 #3 Posted September 14, 2025 The 520 was $125 and the 656 was $45 so it was a given that I bought them 4 2 Share this post Link to post Share on other sites
ri702bill 13,068 #4 Posted September 14, 2025 Pull the 9 pin connector on the 520 apart to look for signs of overheating damage... 4 Share this post Link to post Share on other sites
953 nut 69,339 #5 Posted September 14, 2025 Also you should do a compression check on the Onan before going too far into the 520. 1 2 Share this post Link to post Share on other sites
Easton Rich 1,260 #6 Posted September 14, 2025 Ok, if it has no compression what should I expect after? Bad head gasket? I’ve heard about the 9 pin connector before…. Share this post Link to post Share on other sites
Wayne0 1,634 #7 Posted September 14, 2025 12 hours ago, Easton Rich said: The 520 was $125 and the 656 was $45 so it was a given that I STOLE them Fixed that for ya' 1 4 Share this post Link to post Share on other sites
Lee1977 7,772 #8 Posted September 14, 2025 (edited) Be sure to remove the engine cover and fender pan and clean all the cooling fins. The Onan moves a lot of air and will blow dirt and grass in to fill the fins. When change the oil filter make sure the half circle under the filter is clean of oil. Make sure the rubber engine vent on top of the engine is tight. Edited September 14, 2025 by Lee1977 1 Share this post Link to post Share on other sites
Easton Rich 1,260 #9 Posted September 14, 2025 Ok, it’s raining now, but I will get pictures tomorrow. Sorry 1 Share this post Link to post Share on other sites
Easton Rich 1,260 #10 Posted September 15, 2025 No spark. Gonna tear it down tomorrow to clean it up, change oil, and clean carb 1 Share this post Link to post Share on other sites
953 nut 69,339 #11 Posted September 15, 2025 4 hours ago, Easton Rich said: No spark. Gonna tear it down tomorrow to clean it up, change oil, and clean carb Is power to the coil getting past the 9 pin? Share this post Link to post Share on other sites
peter lena 10,065 #12 Posted September 15, 2025 @Easton Rich https://www.google.com/search?q=wheel+horse+belt+guard+ventalation&rlz=1C1CHBF_enUS866US866&oq=&gs_lcrp=EgZjaHJvbWUqBggHEEUYOzIKCAAQRRgWGB4YOTIICAEQABgWGB4yCAgCEAAYFhgeMg0IAxAAGIYDGIAEGIoFMgoIBBAAGIAEGKIEMgcIBRAAGO8FMgcIBhAAGO8FMgYIBxBFGDvSAQkxNjI0N2owajSoAgGwAgHxBexTTozizNCU8QXsU06M4szQlA&sourceid=chrome&ie=UTF-8#vhid=-IsNCFYPmX078M&vssid=_WvTHaNbhEvztptQP3OmEmAg_186 , known for heat related issues , a RE ROUTING OF FRIED / BAKED WIREING , and added belt guard venting , bring that guard to a local , metal shop , they will have lever punch , bench set ups , made for that , its in the BEVERLY SHEAR , FAMILY , makes metal work very easy , pete Share this post Link to post Share on other sites
lynnmor 9,040 #13 Posted September 15, 2025 4 hours ago, Easton Rich said: No spark. Gonna tear it down tomorrow to clean it up, change oil, and clean carb We have a thread for that: 1 Share this post Link to post Share on other sites
Easton Rich 1,260 #14 Posted September 15, 2025 Yes, they are rough, but they are a good start for project 2 Share this post Link to post Share on other sites
Lee1977 7,772 #15 Posted September 15, 2025 It's worth $125 the front axle and wheels are worth that. The slot hitch on the 656 is worth the $45. Both can be be made into nice tractors. Share this post Link to post Share on other sites
Easton Rich 1,260 #16 Posted September 15, 2025 I think so too Share this post Link to post Share on other sites
Easton Rich 1,260 #17 Posted September 15, 2025 The 520 lives! I filled the tank with gas changed the oil and it fired right up! No spark problem. Now for the 656, what should I do with it? 2 Share this post Link to post Share on other sites
Easton Rich 1,260 #18 Posted September 15, 2025 I will be posting a wanted ad in the classifieds also, but I’m in need of a set of fenders and a hood for my 520. If you’ve got something PM me. Thanks Share this post Link to post Share on other sites
MainelyWheelhorse 3,133 #19 Posted September 15, 2025 1 hour ago, Easton Rich said: I will be posting a wanted ad in the classifieds also, but I’m in need of a set of fenders and a hood for my 520. If you’ve got something PM me. Thanks The 520 bodywork doesn’t look horrible. The sheet metal is pretty soft and you could get the dents out pretty easy with a rubber hammer/metal hammer and a block of wood. I fixed a pushed in nose on a spare hood like that. The dent in my 312’s hood was significantly worse before I massaged the hood on it.The fenders on the 520 look decent and could be fixed the same way. Share this post Link to post Share on other sites
Easton Rich 1,260 #20 Posted September 16, 2025 Yeah, I’ll see if I can get them out. Some are pretty bad that the camera doesn’t show. I’ll try to get some close-ups tomorrow. 1 Share this post Link to post Share on other sites
peter lena 10,065 #21 Posted September 16, 2025 @lynnmor picked up on your clean carb , issue , ever think about eliminating it ? years ago , was in the same , regular spot , consistent fuel hose , break down , change out all related rubber hose , cleaned every hold / build up area , been adding ounce or two , to every tank top off , of fuel STA BIL , guess what ? no debris in tank , filters , or carb . have filter close to tank , always clean / clear second filter just before carb , also clean / clear , carb is always clean / clear , basic trial for , ELIMINATION , same set up on my 3 units , also home generator , instant starts . just an opportunity , to correct that , by the way , I use , regular ethanol gas, no fuel / carb debris , pete Share this post Link to post Share on other sites
lynnmor 9,040 #22 Posted September 16, 2025 34 minutes ago, peter lena said: @lynnmor picked up on your clean carb , issue , ever think about eliminating it ? years ago , was in the same , regular spot , consistent fuel hose , break down , change out all related rubber hose , cleaned every hold / build up area , been adding ounce or two , to every tank top off , of fuel STA BIL , guess what ? no debris in tank , filters , or carb . have filter close to tank , always clean / clear second filter just before carb , also clean / clear , carb is always clean / clear , basic trial for , ELIMINATION , same set up on my 3 units , also home generator , instant starts . just an opportunity , to correct that , by the way , I use , regular ethanol gas, no fuel / carb debris , pete I don't have a carb issue, everything is stock and I use the cheapest gas available. You probably saw that the OP mentioned the carb on his well abused tractor. 1 Share this post Link to post Share on other sites
Easton Rich 1,260 #23 Posted September 16, 2025 Yes, I’ve replaced the the fuel line and filter Share this post Link to post Share on other sites
Easton Rich 1,260 #24 Posted October 19, 2025 Ok, I’ve got a problem. Someone has cut the wiring for the headlights. There are no wires coming from anywhere that would be to hook them up. Where do the long wires plug into? I’m stumped Share this post Link to post Share on other sites
lynnmor 9,040 #25 Posted October 19, 2025 37 minutes ago, Easton Rich said: Ok, I’ve got a problem. Someone has cut the wiring for the headlights. There are no wires coming from anywhere that would be to hook them up. Where do the long wires plug into? I’m stumped The headlights are grounded at the temperature sensor on the engine. The positive wire goes over the engine, but under the intake manifold, along with the temperature sensor wire and are protected with a sleeve. Those wires continue on to the 9 pin connector. Share this post Link to post Share on other sites
