screech 18 #1 Posted August 25 This is on my 312-8. It is not on my other Wheel Horse Tractors. What is it for, I can not find it on any part diagrams. Thank You! Share this post Link to post Share on other sites
Ed Kennell 43,082 #2 Posted August 25 Clutch damper that slows the engagement of the belt. Safety feature that prevents a quick start that may flip the tractor over. 1 Share this post Link to post Share on other sites
screech 18 #3 Posted August 25 3 minutes ago, Ed Kennell said: Clutch damper that slows the engagement of the belt. Safety feature that prevents a quick start that may flip the tractor over. Thank You, Why is it not on my newer tractors and not on any parts lists? Share this post Link to post Share on other sites
Ed Kennell 43,082 #4 Posted August 25 3 minutes ago, screech said: Thank You, Why is it not on my newer tractors and not on any parts lists? Probably one of several Wheel Horse ideas where the benefit did not justify the cost. Anti vibration shaker plate engine mounts are another example. 2 Share this post Link to post Share on other sites
ri702bill 10,024 #5 Posted August 25 It is a cousin to gas hood or trunk struts. Over time it is destined to fail..... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,730 #6 Posted August 25 Item #53 on this page. I call it an air shock. If you take it off and clean it out it will likely function OK. Debris plugs up the holes that allows air to enter and exit. https://www.partstree.com/models/31-12k801-312-8-toro-garden-tractor-1990/clutch-brake-and-speed-control-linkage-4/ 2 Share this post Link to post Share on other sites
Ed Kennell 43,082 #7 Posted August 25 A word of caution. Make sure it is adjusted properly. If the belt is too long, it can allow the contact plate to pass below the piston pin. The spring loaded piston pin then pops out and locks the clutch in the engaged position and will not allow the clutch pedal to be depressed. And of course the clutch pedal switch prevents the tractor from starting. How do I know? I bought a 310-8 sight unseen for scrap price. The ad said the clutch and transmission are locked up and the tractor will not start. It took about an hour to replace the worn belt and clean and adjust the damper. Oh, it came with a 4yo 42"SD deck. Runs and mows great. 3 Share this post Link to post Share on other sites
squonk 44,587 #8 Posted August 25 It's a reminder to clean off that debris around the transmission and to replace that shifter boot! 1 1 2 Share this post Link to post Share on other sites
lynnmor 8,076 #9 Posted August 26 2 hours ago, squonk said: It's a reminder to clean off that debris around the transmission and to replace that shifter boot! And then do an immediate transmission oil change because of the torn boot leaving water and debris in. 1 Share this post Link to post Share on other sites
oldlineman 1,577 #10 Posted August 26 Squonk and Lynnmor beat me too it, what they both said. 1 Share this post Link to post Share on other sites
screech 18 #11 Posted August 26 20 hours ago, squonk said: It's a reminder to clean off that debris around the transmission and to replace that shifter boot! Ordered a couple new boots. Maybe dirt but I bought this 312-8 new and it has never been gotten wet! Share this post Link to post Share on other sites
peter lena 9,451 #12 Posted August 27 @screech after going over my first W/H clutch linkage set up , also eliminated / corrected functional saposed to me movable areas . amazing to me to regularly see , failure points that are never even thought about . like HI MILAGE ATF fluid to enhance drive around and flush trans , penetrating oil first , make the rust run out , then aerosol red grease , extension tube , spring assist to linkage areas . ever looked at the PTO VEVER SET UP ? how could you possibly make that better ? or even care about it ? another thing I do to anything picked up , is to first get the penetrating oil soak down going ? days and weeks later , that chemical conkockshon , has soaked into / thru the grunge neglect , done a lot of that , not surprised at all in its easy paint recovery . done in stages , like to bring them back from the dead , pete 1 Share this post Link to post Share on other sites
