Teddy da Bear62 172 #1 Posted August 25, 2025 (edited) Don't forget to clean your deck regularly! Uhhhh .... yeahhhh.......oops! I think it has its own ecosystem!! 😏 Edited August 25, 2025 by Teddy da Bear62 1 3 Share this post Link to post Share on other sites
peter lena 10,065 #2 Posted August 25, 2025 @Teddy da Bear been doing this for years , my own personal experience , is to BREAK THE GRUNGE CYCLE , zero rust / rot , the regular hot oiling bake in , has made itself . self defending , for any kind of grunge, rarely if ever have any debris hold on to this finish .combine that with lucas chassis grease / in every related bearing , cleaned out and hand packed , no noise , or typical bearing whine, also mule drive , spins up quiet / easy , repetitive issue problem , shows you the way . 3 decks , no problems , pete Share this post Link to post Share on other sites
