kthomas62 46 #1 Posted August 21, 2025 Good evening all! I am looking at replacing the spindle nuts on my 414-8, since I would venture to say they are originals and have been off and on countless times. Would anyone happen to know a part number? My deck model is 1542SC01. TIA!! Kevin Share this post Link to post Share on other sites
JoeM 10,268 #2 Posted August 21, 2025 The top nut that holds on the pulley the bottom nut that holds on the blade. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #3 Posted August 21, 2025 https://www.wheelhorseforum.com/search/?q=15-42sc01&quick=1&type=downloads_file Share this post Link to post Share on other sites
kthomas62 46 #4 Posted August 21, 2025 21 minutes ago, gwest_ca said: https://www.wheelhorseforum.com/search/?q=15-42sc01&quick=1&type=downloads_file Thanks! Share this post Link to post Share on other sites
kthomas62 46 #5 Posted August 21, 2025 5 hours ago, JoeM said: The top nut that holds on the pulley the bottom nut that holds on the blade. Thank you 1 Share this post Link to post Share on other sites
953 nut 69,337 #6 Posted August 21, 2025 Here is a link to some much lower priced Jam nuts. I have been using these and hey work well. https://www.ebay.com/itm/390675312710 Share this post Link to post Share on other sites
kthomas62 46 #7 Posted August 22, 2025 12 hours ago, 953 nut said: Here is a link to some much lower priced Jam nuts. I have been using these and hey work well. https://www.ebay.com/itm/390675312710 Thank you!!! 1 Share this post Link to post Share on other sites
JoeM 10,268 #8 Posted August 22, 2025 Another option is McMaster Carr these are the grade 8 nuts for the blades. shipping is a killer tho Share this post Link to post Share on other sites
peter lena 10,065 #9 Posted August 22, 2025 @kthomas62 also like a 6 point socket , for solid , movement / hook up , pete 2 Share this post Link to post Share on other sites
kthomas62 46 #10 Posted August 27, 2025 On 8/22/2025 at 4:16 AM, JoeM said: Another option is McMaster Carr these are the grade 8 nuts for the blades. shipping is a killer tho Thank you! Share this post Link to post Share on other sites
