SylvanLakeWH 31,994 #26 Posted August 24, 2025 9 minutes ago, Awd79 said: $150 would this fit my c-105 Yes Share this post Link to post Share on other sites
Awd79 31 #27 Posted August 24, 2025 34 minutes ago, SylvanLakeWH said: Yes Thank you Share this post Link to post Share on other sites
Ed Kennell 46,794 #28 Posted August 24, 2025 A new wear bar is a plus. I don't see the triangle shaped piece that connects the wires to pull the angle locking pin or lift link. Share this post Link to post Share on other sites
Awd79 31 #32 Posted August 24, 2025 These were all the pics. I will ask him. he has rear mounts I need as well. Share this post Link to post Share on other sites
Ed Kennell 46,794 #33 Posted August 24, 2025 Those two missing parts are pretty easy to make, but maybe could be used to negotiate for a free axle bracket. 1 Share this post Link to post Share on other sites
Brockport Bill 2,448 #34 Posted August 24, 2025 suggest for the plow blade to use a grinder sander disc, or sand blast, or sand the rust off front of blade and then prime and paint -- Reducing friction so snow, slush etc peel away is your goal. Also consider oil spay, or car wax, on blade for more efficient clearing of snow - Oh yeah - - suggest anything deeper than 6 inches take half a blade on angle and don't ask the blade or tractor to be a bulldozer -- here are a few blade photos i did rehab Share this post Link to post Share on other sites
Brockport Bill 2,448 #35 Posted August 24, 2025 here is rear axle bracket you will need -- i rehab mine - not that it improves function but sometimes pretty is better 1 Share this post Link to post Share on other sites
Brockport Bill 2,448 #36 Posted August 24, 2025 here is view of a full plow set - including springs - mounting rods, lever arm and handle, lever arm index turn rod, lift link etc Share this post Link to post Share on other sites
Ed Kennell 46,794 #37 Posted August 24, 2025 (edited) What is this for Bill @Brockport Bill Edited August 24, 2025 by Ed Kennell Share this post Link to post Share on other sites
Awd79 31 #38 Posted August 24, 2025 This snowblower is missing the stuff I need to mount it. Wants $80 for it. He is in CT like me and said the blower handles our snow better than a plow. I don’t want both. thought? Share this post Link to post Share on other sites
Ed Kennell 46,794 #40 Posted August 24, 2025 2 hours ago, Awd79 said: This snowblower is missing the stuff I need to mount it. That blower mounts directly on any wheel horse with the front attach-a-matic which you have. The only thing I see missing is the cable to rotate the chute. I prefer to plow, but the blower is 1/2 the price of the plow and will handle a blizzard if you ever get one. 1 Share this post Link to post Share on other sites
Awd79 31 #41 Posted August 24, 2025 2 hours ago, Ed Kennell said: That blower mounts directly on any wheel horse with the front attach-a-matic which you have. The only thing I see missing is the cable to rotate the chute. I prefer to plow, but the blower is 1/2 the price of the plow and will handle a blizzard if you ever get one. Plow guy came down to $100. Probably can get him to throw rear mounts in also. Which he has. would that change your mind? 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,994 #42 Posted August 24, 2025 I prefer plowing... If you get the mounting brackets thrown in I'd go with the plow... 1 Share this post Link to post Share on other sites
adsm08 4,902 #43 Posted August 24, 2025 16 minutes ago, SylvanLakeWH said: I prefer plowing... If you get the mounting brackets thrown in I'd go with the plow... I agree. Now that I have a plow, and a blower, and a tractor for each, my plan for this winter is to plow like normal, and have the boy follow behind chucking the snow piles up farther out of the way. We have a double wide driveway, so twice the surface area to take snow out of, same amount of space at the edges to pile it in. I tend to run out of places to put it if we don't get a melt between storms. Share this post Link to post Share on other sites
Ed Kennell 46,794 #44 Posted August 24, 2025 (edited) 30 minutes ago, Awd79 said: would that change your mind? No brainer, buy the plow. Those couple missing parts are easy to make if he doesn't have them. I don't see the triangle piece or the rod to angle the plow. Edited August 24, 2025 by Ed Kennell Share this post Link to post Share on other sites
Awd79 31 #45 Posted August 24, 2025 Thank you everyone. I truly appreciate it as a new owner. Look forward to learning more. Share this post Link to post Share on other sites
Ed Kennell 46,794 #46 Posted August 24, 2025 These are the two parts that I don't see in the pictures. They tend to get misplaced when a plow is removed from a tractor. 2 Share this post Link to post Share on other sites
rjg854 13,268 #47 Posted August 24, 2025 6 hours ago, Awd79 said: Does he have the flag and the lift bar for it, I don't see them in the picture. 1 Share this post Link to post Share on other sites
Handy Don 17,190 #48 Posted August 24, 2025 1 hour ago, Awd79 said: Plow guy came down to $100. Probably can get him to throw rear mounts in also. Which he has. would that change your mind? My opinion... Plow: Handles wet sloppy slush Faster than a blower for snow amounts < 9" Requires a place to put the snow alongside the plowed area Can mark pavements/sidewalks Can dig up gravel/dirt driveways unless using skids Blower: LOVES dry snow up to 12-14" Tosses the snow well away from the cleared area Can clog with wet or slushy stuff unless kept nicely “loaded" Less marking of pavement/sidewalks In my area we are getting smaller, wetter snowfalls. I switched to a WH plow last year from a walk-behind 2-stage blower. I don’t think I’ll be going back. 1 1 Share this post Link to post Share on other sites
Brockport Bill 2,448 #49 Posted August 24, 2025 12 hours ago, Ed Kennell said: What is this for Bill @Brockport Bill interesting question - it seems like one of those obscure parts that beg a question -- wh rear axle bracket spacer manual info.htm Share this post Link to post Share on other sites
Awd79 31 #50 Posted August 24, 2025 17 hours ago, Brockport Bill said: suggest for the plow blade to use a grinder sander disc, or sand blast, or sand the rust off front of blade and then prime and paint -- Reducing friction so snow, slush etc peel away is your goal. Also consider oil spay, or car wax, on blade for more efficient clearing of snow - Oh yeah - - suggest anything deeper than 6 inches take half a blade on angle and don't ask the blade or tractor to be a bulldozer -- here are a few blade photos i did rehab Would you suggest a wire wheel or the sander disc as you recommended. any suggested grit. I have wire wheels but happy to grab discs at harbor freight Share this post Link to post Share on other sites
