Pullstart 71,253 #51 Posted October 25, 2025 Interesting geometry on this setup! IMG_7515.mov 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,521 #52 Posted October 26, 2025 IMG_8643.mov First try with back blade and rake... blade needs weight but functional. rake tines need to be trimmed 3" to raise / lower adequately. it binds up at top if I don't stop it in time. Thinking need to either add a hard stop or eliminate the parallel function and replace with single 2" square tube that simply pivots on one plane... use pin so I can raise / lower it on the vertical beam. Thoughts appreciated. Oh, and Denali liked the new flat area so much he pooped on it right at the end of the video...!!! IMG_8646.mov IMG_3645.mov 1 1 Share this post Link to post Share on other sites
Handy Don 17,474 #53 Posted October 26, 2025 On 10/24/2025 at 5:53 PM, SylvanLakeWH said: and gonna need a bunch of weight up front With the implement so far to the rear, I’d be concerned about it potential to use its weight/leverage to put very strong bend/twist forces on the tractor. F-plate/frame reinforcement? 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,521 #54 Posted October 26, 2025 40 minutes ago, Handy Don said: With the implement so far to the rear, I’d be concerned about it potential to use its weight/leverage to put very strong bend/twist forces on the tractor. F-plate/frame reinforcement? Thank you. I'm not an engineer so I appreciate such input... it's mounted via a 2" hitch from wheel horse parts and more... 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,521 #55 Posted November 4, 2025 Today's episode: IMG_3657.mov Share this post Link to post Share on other sites
kpinnc 18,966 #56 Posted November 4, 2025 Very nice! With these tractors, you just never run out of options when making new attachments! My favorite part of my tractors anyway. 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,521 #57 Posted November 7, 2025 Added front blade: 4 Share this post Link to post Share on other sites
SylvanLakeWH 32,521 #58 Posted February 16 Reconfiguring the rear hitch system... a bit less complicated and far stronger... lower center of gravity, higher lifting of implements. 1 3 Share this post Link to post Share on other sites
AlexR 3,113 #59 Posted February 17 Is this going to be your plow mule for Pullstart's plow day? I got some chains you can borrow if it's muddy again 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,521 #60 Posted February 17 46 minutes ago, AlexR said: Is this going to be your plow mule for Pullstart's plow day? I got some chains you can borrow if it's muddy again Yes... I have a set of chains that I am going to put on it. But if they don't fit I will take you up on that offer!!! Mud...? What mud? But to be fair, @Pullstart obviously gave me a defective tractor... not to mention the faulty mud in his back forty... I mean, you can't even drive a bus through the field... 1 3 1 Share this post Link to post Share on other sites
ebinmaine 80,713 #61 Posted February 17 Just now, SylvanLakeWH said: you can't even drive a bus through the field 1 1 Share this post Link to post Share on other sites
WHX?? 58,140 #62 Posted February 17 I like the plow ... 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,521 #63 Posted February 17 (edited) 3 minutes ago, WHX?? said: I like the plow ... Thx. Ill sell it to ya for $100... old lady from northern Wisconsin drove it only to church on Sundays... But seriously, I am guardedly optimistic that the money tree will sprout soon and I'll get you your $$$... Edited February 17 by SylvanLakeWH 2 Share this post Link to post Share on other sites
SylvanLakeWH 32,521 #64 Posted September 20 Added permanent weight up front. Gonna keep this as the plow mule and second back up snow rig. B-80 will be for towing kids and back up snow rig. 2 Share this post Link to post Share on other sites
