JR Pedersen 18 #1 Posted August 8, 2025 Last night I was cutting my grass for about 30 minutes and everything was working great...shut it off for dinner and came back and it would run for 30 seconds only on "Full" Choke and then stalls. Any ideas what might be the issue? Share this post Link to post Share on other sites
953 nut 64,108 #2 Posted August 8, 2025 Could be time to do some fuel system maintenance. Is there gas in the tank? Are you using gasoline with Ethanol? If you are then STOP. Ethanol will kill the fuel system. You can find a station that sells real gasoline on this site.https://www.pure-gas.org/ Check the outlet from the tank to see that it is not obstructed. Replace the fuel hose and filter. Check the fuel pump to see that it is pumping. The carburetor may need to be rebuilt. 2 Share this post Link to post Share on other sites
rmaynard 16,864 #3 Posted August 8, 2025 Check the cap on your tank. The vent may be clogged. 1 Share this post Link to post Share on other sites
JR Pedersen 18 #4 Posted August 8, 2025 1 hour ago, rmaynard said: Check the cap on your tank. The vent may be clogged. Thank you...I'll start with this and move onto the advice from 953 nut 1 Share this post Link to post Share on other sites
JR Pedersen 18 #5 Posted August 8, 2025 1 hour ago, 953 nut said: Could be time to do some fuel system maintenance. Is there gas in the tank? Are you using gasoline with Ethanol? If you are then STOP. Ethanol will kill the fuel system. You can find a station that sells real gasoline on this site.https://www.pure-gas.org/ Check the outlet from the tank to see that it is not obstructed. Replace the fuel hose and filter. Check the fuel pump to see that it is pumping. The carburetor may need to be rebuilt. Thanks for all this info - hope to start getting into the maintenance this weekend! Also thank you for serving our country! 1 Share this post Link to post Share on other sites
ri702bill 11,254 #6 Posted August 8, 2025 Dad'd 702 did the same thing. It ran great until you shut it off. The rings are quite a bit tired - carbon would bridge the spark plug gap giving a no start condition. An inline spark checker shows it HAS spark, but it is shorting out. Clean the plug, it starts right up...... 1 Share this post Link to post Share on other sites
Retired Wrencher 6,448 #7 Posted August 9, 2025 22 hours ago, rmaynard said: Check the cap on your tank. The vent may be clogged. I agree with that Bob lots of people overlooked that. 1 Share this post Link to post Share on other sites
