Lane Ranger 12,023 #1 Posted August 7, 2025 I have used this product several times and let me tell you it not only easily removes surface rust on wheels but also seems to protect them from reemergence of yhe rust for some time! i order this off of Amazon but it comes in a p bag that often leaks the gel as they send it with the sprayer nozzle installed instead of a solid cap! But I recommend this product for use on Wheel Horse tractors! The first wheel on the dump cart was sprayed with the gel and cleaned with a rag either moderate pressure on the surface rust. The second wheel pic shows the gel applied and working its magic! Spray with water after completion of an application! 2 3 Share this post Link to post Share on other sites
Lane Ranger 12,023 #2 Posted August 7, 2025 Photo after one application of the Rustoleum Rust Removal GEL! 7 Share this post Link to post Share on other sites
Sodaking27 1,265 #3 Posted August 7, 2025 (edited) @Lane Ranger Have you tried this on rusted chrome? Edited August 7, 2025 by Sodaking27 Share this post Link to post Share on other sites
ebinmaine 79,509 #4 Posted August 7, 2025 Found a comment on reddit that this is basically a relabeled naval jelly. That's usually pretty good so I ordered a couple bottles and some brushes off the Wally world...... Share this post Link to post Share on other sites
953 nut 67,231 #5 Posted August 7, 2025 Most rust converters are Phosphoric Acid with a few additives which allows them to give it their own name and a patent number. When I worked on the hydroponic greenhouse farms we used 50% phosphoric acid injected into our drip irrigation lines for a couple of minutes each day to flush out any iron or calcium that may have been in the lines. Fertilizers contain phosphates anyway so the plants were happy. I also dipped any rusted tools in it, just a few seconds ant the rust was converted to a black coat of iron phosphate. 3 1 Share this post Link to post Share on other sites
