Chrishar
Suburban 400 project
Chrishar
Yay findly got my transmission parts in and a good starter cup too so this weekend I'm going to findly have time to work on it again because I only have 2 1/2 weeks to get it done for the big show in TX
Edited by Chrishar
Chrishar
Well I thought I was going to have the transmission together today but I got the wrong four bearing shipped to me just sucks waited almost a month for them so I started taking the frame apart found some welds broken so tomorrow will weld them and fix the hood stand too
Edited by Chrishar
Chrishar
Did some welding today fix the braces, new spring holder and fix the hole in the front bracket for the blade assembly
Chrishar
Transmission together with the help of Oliver2-44 with four good bearings until they get the new bearings figured out for me
Chrishar
Transmission is on and will have new tires on the front tomorrow now just going through the parts and see what else have to fix and put on the suburban and get this thing up and going for the show in about two weeks
  • Like 5
wallfish
You can change those bushings out and use wheel bearings instead. Bushings wear the spindles down so you might want to check those too. :twocents-02cents:
Probably not the most important thing on such a time crunch job
IMG_20250918_233255832_HDR.jpg.703df14c3bcab4be7866bd69c3aeec11.jpg.8830fda7d7c40cd5cde3372bfbde2a33.jpg
Chrishar
How do you get the pulley off this stud
Chrishar
Some done today
  • Excellent 4
953 nut
A Bearing Splitter will do the job   VEVOR Bearing Puller Kit 14-Piece 5 Ton Capacity Bearing Separator Pinion Wheel Bearing Removal Kit with 2-Inch and 2.8-Inch Jaws Bearing Puller Set you may be able to borrow on from an auto parts store.
Chrishar
Motor together and ready
  • Excellent 3
Chrishar
Motor, fenders, belt and belt guard on
  • Excellent 6
Chrishar
Little more done starting to look like something exhaust, seat and rear lift system done
  • Excellent 4
Chrishar
Hood on and gas tank is ready to be put on that's tomorrow nights deal does anybody have a picture of how they ran the fuel line and the throttle and choke cables to the motor
wallfish
Fuel line, sediment bowl outlet directly to the carb. That line is short and just suspends. Not a bad idea to put a fuel filter in there too
The choke is just a direct link wire from the lever to the carb. no conduit
Throttle cable loops from the lever towards the hood stand and goes to the carb from the bottom
Chrishar
Do you have picture of the choke wire that would help me out
Racinbob
Here ya go.
wallfish
:text-yeahthat:
Z bend on the bottom of the wire to fit the carb and a throttle cable swivel fitting on the lever so it can be slid into place then locked down once it's all adjusted correctly
Chrishar
Gas tank and on/off ignition switch are installed should have the fittings so I can put the fuel line on tomorrow night and maybe the throttle and choke lever assembly on too thanks for the pictures it helps me out a lot
Edited by Chrishar
  • Excellent 2
Chrishar
Throttle/choke are hook up and works great my fuel parts didn't make it today should be here tomorrow I hope
  • Excellent 4
Chrishar
Fuel line done foot steps on will fire up the motor tomorrow hope it goes well and adjust the throttle if that all good put the exhaust sheld on and work on putting the front blade on and be ready for the show next weekend does anybody have a picture on how the blade hooks to the lift system
  • Excellent 2
wallfish
It's a solid link to the lift arm. Here's the manual below. I don't have one around any more to measure it for you but shouldn't be to difficult to figure out when it's mounted to the tractor.
Do you have the pedal? goes on the right side foot peg. That's used to release the index pin and yes, a rope connected to the top corners of the blade and draped over the hood was used to swivel it back and forth
Blade Dozer 42in 1961 BD-4261 Formerly HD-42 #A-7138.pdf
Edited by wallfish
Chrishar
No I don't have the pedal for the right side have have the long bar that goes to the lift handle I just need to know we're it hooks up to
Chrishar
Got the motor running today but it smokes ready bad supposed to be a rebuilt motor I guess not I'm having a problem can't get it to go in gear the belt will not stop turning what am I missing here and the belt is a wheel horse belt number 1569 help please
wallfish
Clean the groove on that engine pulley. I can see all the rust in the pic. It must be clean and smooth, no paint either
Some of those can be a PITA and the belt guard can be tweaked around a little by loosening the bolts, adjust tighten
Edited by wallfish
wallfish
There's a bar with a hole right on the indexing part behind the blade. Then to the lift handle. The bend in the lift bar link is to avoid hitting the hood.
Pretty sure it's this hole but it's been 20 years since I sold all of the attachments. Or hook it up to hole on the plow frame and see where it lines up on the lift handle
IMG_20250923_232633119.thumb.jpg.1f2477edf761e9a5b490b819185a15bc.jpg.c504907d9abd5eabcf8ad94da9043270.jpg
Edited by wallfish
