ebinmaine 80,076 #151 Posted December 17, 2025 7 hours ago, jsoluna said: excels at front blade work. Agreed. Wheelhorse company paperwork from around the vintage of your own tractor shows more than 20 available implements. That's not even getting into the myriad of aftermarket equipment. The more you use one, the more you will be impressed. 2 1 1 Share this post Link to post Share on other sites
jsoluna 514 #152 Posted January 2 Wheel/Tires/Seat Video: 3 1 Share this post Link to post Share on other sites
jsoluna 514 #153 Posted January 2 Winter Mode Video: 2 1 Share this post Link to post Share on other sites
jsoluna 514 #154 Posted January 2 (edited) Snow Plowing Action! My first time using a WH to plow. That limited slip must work at least a little, it really grips. Edited January 2 by jsoluna 3 5 Share this post Link to post Share on other sites
sqrlgtr 3,583 #155 Posted January 3 IDK who had the most fun, you are the pup. 2 Share this post Link to post Share on other sites
jsoluna 514 #156 Posted January 3 10 hours ago, sqrlgtr said: IDK who had the most fun, you are the pup. This boy loves the snow. He's just a bundle of joy in general, truly. 1 2 Share this post Link to post Share on other sites
jsoluna 514 #157 Posted January 3 (edited) Already thinking about spring. More to come on the front blade, weight ballasting, etc but I'm curious: I had planned on patching up the 42"SD deck, but it is pretty bad for the entire spindle mounting area and will require significant repairs. Rather than fix the Raider's 42", am I able to swap the lifting carriage from it onto another, more common newer style deck? The Raider is pre Attach-A-Matic. There this decent newer 48" not far from me. Is it possible to swap the lifting components over and use a different deck or are there other issues I'm unaware of? Edited January 3 by jsoluna Share this post Link to post Share on other sites
Handy Don 17,188 #158 Posted January 3 Disclaimer: I am NOT an expert on the Raiders. That said, decks need three things: 1. A compatible lifting chassis (attach-a-matic location and strength) 2. A compatible power delivery, i.e. mule & belt routing 3. Room under the tractor (short, “medium”, or long frame; front wheel size) @gwest_ca can you please add a link to the “cross reference” document that shows which decks were made to go on which models? 2 Share this post Link to post Share on other sites
ebinmaine 80,076 #159 Posted January 3 @jsoluna You got one o them there welding thingamajigs. Y' oughtta add a mule bracket to the front of the Raider. 1 Share this post Link to post Share on other sites
pfrederi 20,992 #160 Posted January 3 (edited) might be faster easier to put front tachmatic on the tractor. and use this to lift the deck Edited January 3 by pfrederi 3 Share this post Link to post Share on other sites
ebinmaine 80,076 #161 Posted January 3 I've got extra tach-o-matic hitches... 1 1 Share this post Link to post Share on other sites
kpinnc 18,851 #162 Posted January 3 @jsoluna Very good job with the repower on your Raider. That machine looks very happy pushing all that snow with the new heart transplant! Again- all you guys plowing and blowing snow make me a bit jealous. My tractors do very little in winter here in NC. Maybe tow something around but not much else. IF by chance we do get snow, I get to drive around and put tire tracks in it, but it's gone in just a day or two. 2 1 Share this post Link to post Share on other sites
jsoluna 514 #163 Posted January 3 2 hours ago, Handy Don said: Disclaimer: I am NOT an expert on the Raiders. That said, decks need three things: 1. A compatible lifting chassis (attach-a-matic location and strength) 2. A compatible power delivery, i.e. mule & belt routing 3. Room under the tractor (short, “medium”, or long frame; front wheel size) @gwest_ca can you please add a link to the “cross reference” document that shows which decks were made to go on which models? I have the document in my files, thanks Don. I was curious if anyone has done this exact thing before by using a deck that was not necessarily intended for that model, and if so what that entails. Share this post Link to post Share on other sites
jsoluna 514 #164 Posted January 3 1 hour ago, pfrederi said: might be faster easier to put front tachmatic on the tractor. and use this to lift the deck How big of a deal is it to convert the Raider to the Attach a Matic mule and lift system? Would it still work with the electric PTO vs the manual PTO that is more common? 2 Share this post Link to post Share on other sites
ebinmaine 80,076 #165 Posted January 3 Just now, jsoluna said: I have the document in my files, thanks Don. I was curious if anyone has done this exact thing before by using a deck that was not necessarily intended for that model, and if so what that entails. Add the front hitch by welding a bracket on it. That'll permit use of the front mule drive. Then add a mid attach o matic if ya don't already have one. Then add the lift link as seen above. Presto. 1 1 Share this post Link to post Share on other sites
ebinmaine 80,076 #166 Posted January 3 1 minute ago, jsoluna said: Would it still work with the electric PTO vs the manual PTO that is more common? Yes 2 1 Share this post Link to post Share on other sites
Handy Don 17,188 #167 Posted January 3 See, the collective knows! 2 1 Share this post Link to post Share on other sites
jsoluna 514 #168 Posted January 3 58 minutes ago, ebinmaine said: Add the front hitch by welding a bracket on it. That'll permit use of the front mule drive. Then add a mid attach o matic if ya don't already have one. Then add the lift link as seen above. Presto. Fantastic. Thanks again guys. I'll be looking for the related parts to convert this spring if anyone would like to part with them. 1 Share this post Link to post Share on other sites
jsoluna 514 #169 Posted January 3 1 hour ago, kpinnc said: @jsoluna Very good job with the repower on your Raider. That machine looks very happy pushing all that snow with the new heart transplant! Again- all you guys plowing and blowing snow make me a bit jealous. My tractors do very little in winter here in NC. Maybe tow something around but not much else. IF by chance we do get snow, I get to drive around and put tire tracks in it, but it's gone in just a day or two. Thanks, it is a very happy machine, which means a happy operator. Glad we saved it. Fingers crossed for some of the white stuff your way this year! 1 Share this post Link to post Share on other sites
jsoluna 514 #170 Posted January 3 18 minutes ago, Handy Don said: See, the collective knows! I am still very grateful for the community here, thanks everyone. 1 Share this post Link to post Share on other sites
ebinmaine 80,076 #171 Posted January 3 4 minutes ago, jsoluna said: Fantastic. Thanks again guys. I'll be looking for the related parts to convert this spring if anyone would like to part with them. I gotcha... 1 1 1 Share this post Link to post Share on other sites
jsoluna 514 #172 Posted January 3 Just now, ebinmaine said: I gotcha... You have been such a great resource for me on this build. The Raider and the 520-H both thank you. 2 Share this post Link to post Share on other sites
ebinmaine 80,076 #173 Posted January 3 51 minutes ago, jsoluna said: You have been such a great resource for me on this build. The Raider and the 520-H both thank you. Hey man. I got PLENTY of some spares... Very happy to share. 2 Share this post Link to post Share on other sites
SylvanLakeWH 31,993 #174 Posted January 3 18 minutes ago, ebinmaine said: Hey man. I got PLENTY of some spares... Very happy to share. In the Mainah' dialect, this means "I'm a WH Howder..." 4 Share this post Link to post Share on other sites
ebinmaine 80,076 #175 Posted January 3 2 minutes ago, SylvanLakeWH said: In the Mainah' dialect, this means "I'm a WH Howder..." Wheel hoss ho-ahduh. 2 1 Share this post Link to post Share on other sites
