jsoluna 514 #26 Posted August 10, 2025 (edited) 11 minutes ago, rjg854 said: That's what you're looking for Sweet. Is it missing anything more than the rear axle brackets? I don't see the blade angle adjustment bar anywhere. Edited August 10, 2025 by jsoluna Share this post Link to post Share on other sites
rjg854 13,360 #27 Posted August 10, 2025 Make sure he has all the parts for the blade. I may have the axle bracket you need. 1 Share this post Link to post Share on other sites
jsoluna 514 #28 Posted August 10, 2025 19 hours ago, rjg854 said: Make sure he has all the parts for the blade. I may have the axle bracket you need. Thanks 👍🏼 Any guess what model of blade that could be, or a suggestion for what model to reference to make sure I'm generally looking at a correct IPL when making sure these blades have everything they need? Share this post Link to post Share on other sites
c-series don 12,458 #29 Posted August 10, 2025 (edited) @jsoluna The blade in the last picture is for a D-series tractor, you can tell by the fact that it has four trip springs and the mount on the right side where the angle lever attaches is a big boxy thing. The correct one doesn’t have that and has two trip springs. That blade I believe is 54” or 56”s wide and it’s a little taller. I put one of those on my Work Horse GT-1800 once, and even with the hydraulic lift it seemed to be a bit much for the tractor. I ended up taking it off and going back to a 48” blade. It might fit your tractor but I’d wait for the correct one. Edited August 11, 2025 by c-series don 1 Share this post Link to post Share on other sites
jsoluna 514 #30 Posted August 11, 2025 36 minutes ago, c-series don said: @jsoluna The blade in the last picture is for a D-series tractor, you can tell by the fact that it has four trip springs and the mount on the right side where the angle lever attaches is a big boxy thing. The correct one doesn’t have that and has two trip springs. That blade I believe is 54” or 56”s wide and it’s a little taller. I put one of those on my Work Horse GT-1800 once, and even with the hydraulic lift it seemed to be a bit much for the tractor. I ended up taking it off and going back to a 48” blade. It might fit your tractor but I’d wait for the correct one. Thanks for the detailed description. Will keep looking! 1 Share this post Link to post Share on other sites
rjg854 13,360 #31 Posted August 11, 2025 12 hours ago, c-series don said: The blade in the last picture is for a D-series tractor I did not notice that Don, I should have taken a better look, thanks for picking that out. 1 Share this post Link to post Share on other sites
jsoluna 514 #32 Posted August 22, 2025 Here's another local blade that just popped up. Does this look to be a proper fit? I had a very kind forum member also offer one that is a couple hours drive, and it is in better shape than this one. Making time for 6+ hour road trip is difficult right now so if I can find one locally, that's more realistically possible. Share this post Link to post Share on other sites
rjg854 13,360 #33 Posted August 23, 2025 That one should work ! Share this post Link to post Share on other sites
