Mudrig150 395 #1 Posted July 26, 2025 Just wanted to share a bit of art I've done recently. 11 Share this post Link to post Share on other sites
Mudrig150 395 #2 Posted July 26, 2025 Fixed the colors and decided that the hood looked better white. Also making a version with a hiniker cab right now. 2 1 Share this post Link to post Share on other sites
953 nut 67,562 #3 Posted July 27, 2025 18 minutes ago, Mudrig150 said: hood looked better white. The whole thing would look much better RED 5 Share this post Link to post Share on other sites
Mudrig150 395 #4 Posted August 2, 2025 Cab version as well. 1 Share this post Link to post Share on other sites
Mudrig150 395 #5 Posted December 3, 2025 1965 Ridgewell-Larson LD-600 Traveler 1 1 Share this post Link to post Share on other sites
Mudrig150 395 #6 Posted July 11 For a size reference, this tractor is about the same size as a John Deere 2510, it's a 4 cylinder utility tractor. Also have another in progress, it's based on an International 284. 3 Share this post Link to post Share on other sites
MainelyWheelhorse 2,917 #7 Posted July 13 (edited) What Illustration program are you using to make your art? Edited July 13 by MainelyWheelhorse Share this post Link to post Share on other sites
Mudrig150 395 #8 Posted July 13 21 hours ago, MainelyWheelhorse said: What Illustration program are you using to make your art? I use a program called Medibang paint, but frankly, I can't really recommend it in 2026 since all of the updates have locked so much behind a paywall, including the ability to use the paint bucket. I use an older version. 1 Share this post Link to post Share on other sites
MainelyWheelhorse 2,917 #9 Posted July 14 (edited) Cool, those turned out great! Ah, ok, I’ve used Adobe Illustrator, MS Paint and a bunch of others to varying degrees of success over the years. I’ve started using a program called Affinity for editing photos. It looks like it might be an all in one program you can use for illustrations too. Edited July 14 by MainelyWheelhorse Share this post Link to post Share on other sites
Mudrig150 395 #10 Posted July 22 Making more progress on the F-1310. 1 Share this post Link to post Share on other sites
Mudrig150 395 #11 Posted July 25 Ridgewell Larson F-1310 Engine: 3.1 liter 4 cylinder diesel (45 horsepower) Transmission: Power-Shuttle (6 speed gear with powershift High/Low/Reverse shuttle control) Weight: 4500 lbs (operating) 5600 lbs (ballasted) Pictured with no attachment, front loader, and 72" belly mower. 1 2 Share this post Link to post Share on other sites
