fish59 0 #1 Posted July 24, 2025 Thanks to all of you in the past who have given me advice. Here's my latest: I need to squirt gas into the carb every time I start her cold. Its time consuming removing the air filter to do this. Is this caused by a bad fuel pump? Once started, she runs fine. Thanks in advance for your advice. Rick Share this post Link to post Share on other sites
Goldnboy 1,147 #2 Posted July 24, 2025 Quite possible need to replace fuel lines..when they age the rubber become brittle and hard 3 Share this post Link to post Share on other sites
Ed Kennell 46,982 #3 Posted July 24, 2025 Add a marine primer bulb at a low spot in the fuel line. Two or three squeezes and you'll have instant starts. Your battery and starter will thank you. 2 5 Share this post Link to post Share on other sites
ri702bill 12,808 #4 Posted July 24, 2025 5 hours ago, fish59 said: Is this caused by a bad fuel pump? Not so much bad, but dirty. The little valve discs can get crud under them. If that happens, fuel can drain back. I added a primer bulb on my C81 - no regrets. One other choice is to go with a low pressure electric fuel pump. 4 Share this post Link to post Share on other sites
SylvanLakeWH 32,139 #5 Posted July 24, 2025 6 hours ago, Ed Kennell said: Add a marine primer bulb at a low spot in the fuel line. Two or three squeezes and you'll have instant starts. Your battery and starter will thank you. 1 Share this post Link to post Share on other sites
953 nut 68,501 #6 Posted July 24, 2025 Time for a bit of deferred maintenance to be done. As @Goldnboy mentioned, fuel hose could be old and degraded restricting fuel flow. Also the fuel pump valves could be leaking as @ri702bill suggested. A new fuel hose, filter and pump cleaning or replacement should get the job done. If you have been using gas with ethanol STOP. Ethanol will ruin fuel system components on small engines. To find a station that sells real gas use this site, https://www.pure-gas.org/ 2 1 Share this post Link to post Share on other sites
rmaynard 17,527 #7 Posted July 24, 2025 Might want to put a check valve between the fuel pump and the fuel tank. That way, any gas that may siphon back towards the tank due to a weak fuel pump, will be held by the check valve. 2 Share this post Link to post Share on other sites
clueless 3,436 #8 Posted July 24, 2025 10 hours ago, Ed Kennell said: Add a marine primer bulb at a low spot in the fuel line. Two or three squeezes and you'll have instant starts. Your battery and starter will thank you. Do this first, it will cost you about $15, if it's still not starting then go from there. Even if this doesn't fix the problem you've made it to where it will start up four time faster than it use to once you've fix your problem. Best $12 to $15 improvement I've ever made on my rear tank tractors 5 Share this post Link to post Share on other sites
peter lena 10,013 #9 Posted July 24, 2025 @fish59 another area you can check is the function of the choke linkage and the throttle plate , very often just a small tweak and some penetrating oil makes parts move easily , often refer to smooth easy function of parts . choke is smooth and easy , pete Share this post Link to post Share on other sites
ri702bill 12,808 #10 Posted July 24, 2025 (edited) As I mentioned earlier, I added a Marine primer Bulb on the C81. I got ambitious and mounted it under the seat pan with a spring loaded rod & knob under the seat. Had all the materials in house, why not..... Edited July 24, 2025 by ri702bill 1 3 3 Share this post Link to post Share on other sites
Ed Kennell 46,982 #11 Posted July 24, 2025 Luv it, a bouncy seat powered fuel pump. 1 Share this post Link to post Share on other sites
Handy Don 17,316 #12 Posted July 24, 2025 9 minutes ago, Ed Kennell said: Luv it, a bouncy seat powered fuel pump. Does it hit the seat? I think Bill just lifts the seat and pushes the knob a couple of times. Share this post Link to post Share on other sites
Ed Kennell 46,982 #13 Posted July 24, 2025 11 minutes ago, Handy Don said: I think Bill just lifts the seat and pushes the knob But R Goldberg would surely have made it seat activated. 1 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,139 #14 Posted July 24, 2025 That is cool!!! Share this post Link to post Share on other sites
ri702bill 12,808 #15 Posted July 24, 2025 Nope - purposely designed not to hit the underside of the seat. As @Handy Don said, flip up the seat, give it a couple of pushes, lower the seat, start it up. I did this to "protect" the fuel line & primer. Seen way too may installed out in the open just a-waitin' to get snagged on something.... 1 Share this post Link to post Share on other sites
ri702bill 12,808 #16 Posted July 24, 2025 23 minutes ago, Ed Kennell said: But R Goldberg would surely have made it seat activated. Rube would have used gears, twine, and a mousetrap.... 1 Share this post Link to post Share on other sites
ri702bill 12,808 #17 Posted July 24, 2025 52 minutes ago, Ed Kennell said: Luv it, a bouncy seat powered fuel pump. Not to be confused with Archimedes in the bathtub with the fat chick...... 2 Share this post Link to post Share on other sites
Ed Kennell 46,982 #18 Posted July 24, 2025 My primer bulbs are located near my left foot where I have to bend down. Now Bill has me thinking how nice a foot operated bulb would be. 2 Share this post Link to post Share on other sites
Handy Don 17,316 #19 Posted July 24, 2025 2 hours ago, Ed Kennell said: My primer bulbs are located near my left foot where I have to bend down. Now Bill has me thinking how nice a foot operated bulb would be. One of my Dad’s cars from the 50’s had a foot operated pump for the windshield washer fluid right next to the headlight dimmer pedal. The car was a hand-me-down from his rich uncle and aunt so it had all the options. Automatic transmission, fender skirts, an exterior windshield visor, heat, and even a radio! 3 1 Share this post Link to post Share on other sites
adsm08 5,006 #20 Posted July 24, 2025 6 hours ago, Ed Kennell said: But R Goldberg would surely have made it seat activated. Given the location of the tank in a 312 that's a lot more sensible than it should be. 2 Share this post Link to post Share on other sites
peter lena 10,013 #22 Posted July 27, 2025 @ri702bill those seat springs are easy , have them on 3 horses . once you start experimenting , you just keep gaining , also like adding a vibration pad , as a height spacer . pete Share this post Link to post Share on other sites
8ntruck 9,216 #23 Posted July 27, 2025 On 7/24/2025 at 1:44 PM, ri702bill said: Not to be confused with Archimedes in the bathtub with the fat chick...... WHAT a visual!!! Share this post Link to post Share on other sites
