Brockport Bill 2,407 #1 Posted July 22, 2025 i had someone ask me about purchase of an entire spindle replacement unit -- i know we have a reliable vendor here at Red Square that sells spindles ( the housing or full unit i recall ) - and i suppose there may even be NOE spindles available -- but i was asked the reliability of the knockoff full spindle units now sold on Amazon for $56 - i have no idea if any RSq folks have had any experience with them - personally it would not be my choice but was wondering the durability,, life span, etc if anyone had tried the cheapies? Share this post Link to post Share on other sites
ri702bill 12,395 #2 Posted July 22, 2025 As they say, "Ya gets what ya pays for". I would consider one, but would disassemble it before use to flush out the Chinesium garbage grease in the bearings and repack them with Lucas green X-Tra Duty grease. @peter lena would approve!! 1 2 Share this post Link to post Share on other sites
oldlineman 1,749 #3 Posted July 22, 2025 I know that price and availability are big concerns, but for me I like to support local and USA made items when possible. Having said that, if need to purchase cheaper items is required then I would do as ri702bill has stated above. Bob 2 Share this post Link to post Share on other sites
RED-Z06 2,718 #4 Posted July 30, 2025 For many years WH spindles have been limited stock and the price reflected it, hundreds of dollars per spindle...it put alot of decks in the scrap yard, good rebuilt spindles were listed for hundreds of dollars. Now the imported spindles have really changed the game, you can go out and get a new set of 3 for less than one rebuilt one a few years ago. 1 Share this post Link to post Share on other sites
peter lena 9,932 #5 Posted July 31, 2025 @Brockport Bill every and any spindle I have has WIDE RUBBER GREASE SHIELDS ON THEM ? what could you possibly do ? you know the original " grease " is going to fail and get whinny noisy , every related bearing I have has a 550 deg flash point lubricant , very easy spin up and no noise , my mule drive also engages with no screaming / squealing / make a change , pete / Share this post Link to post Share on other sites
Brockport Bill 2,407 #6 Posted July 31, 2025 appreciate the insights -- was hoping to find some people who have some past experince with the 'cheapie" spindles - thanks Share this post Link to post Share on other sites
johnnymag3 2,646 #7 Posted July 31, 2025 (edited) I just did a rebuild / service on a John Deere for a customer....OEM JD Spindles are made in CHINA... I could not find any US made anywhere. I do think we are ending an era of anything made here anymore... Its very sad.. That being said, reviews for the 8TEN Spindles were very positive. they came empty and I filled them with Lucas RED extreme pressure....They are all cheapies, and even though they say OEM ,they carry the OEM price only. Edited July 31, 2025 by johnnymag3 1 Share this post Link to post Share on other sites
C-85 810 #8 Posted July 31, 2025 I have bought a pair of the 8Ten spindles and have only used them a few times and have had no problems. They are built a little different, but seem to go on and work well. C-85 Share this post Link to post Share on other sites
Ming89 2 #9 Posted September 17, 2025 can you share the p/n of the spindles you bought? Share this post Link to post Share on other sites
cleat 8,994 #10 Posted September 17, 2025 I have not used those but I have installed cheap Chinese bearings into oem wheel horse spindles and so long as you keep them greased they seem fine. 1 Share this post Link to post Share on other sites
sonny58 0 #11 Posted June 26 I’m looking to replace 3 spindle’s complete assembly on my 520H. Deck model 78350 rear discharge. Would like advice on what which after market brand is best ? And where I can purchase. Any guidance would be much appreciated. Thanks Share this post Link to post Share on other sites
OoPEZoO 605 #12 Posted June 27 (edited) I bought a set of the 8Ten branded spindles and pulleys for an old 48” deck I’ve been rebuilding. I have a whole box of spindles/pulleys/blades I’ve collected trying to keep my decks working. In this case, I was tired of trying to piece together original double D spindles and blades from other random decks. I have NOT installed them on the deck yet, but I have disassembled them to check’m out and I was very pleasantly surprised with the internal guts of them. They are cast aluminum housings, hollow spindle shafts with grease zerks on top, bearings look to be decent quality and are open on the inside to accept grease. Overall, I am very impressed with the build quality…..BUT, like said, I have yet to cut grass with them. I bought them from Amazon for $100 and then had to buy a replacement double pulley for the center deck spindle for another $30. There are a few threads on here breaking them down with pictures if you search for 8Ten. For the price, I had to take a chance on them. edit: I think direct links to Amazon are frowned upon, so here is the product header description for the spindles I bought for my 48” if it helps anyone “8TEN Mower Spindle Toro Side Rear Discharge 300 Series GT Recycler 48-Inch Deck 822327 111726 110172 3 Pack“ and the replacement double pulley “8TEN Center Spindle Pulley for Toro Wheel Horse 300 GT XT Series 15-48SC01 15-48SC02 15-48SC03 48-Inch 110147” Edited June 27 by OoPEZoO 1 Share this post Link to post Share on other sites
