Wheel Horse312-8 2 #1 Posted July 21, 2025 Hello, in process of replacing drive/transmission belt on my 417xt. Can't seem to figure how to remove belt from around clutch. I replaced it 4-5 years ago but have no idea how i did it. The only visible way seem to be to remove the clutch bracket, but i don't recall having done that in the past, and it doesn't appear as if it will slip off around the clutch itself. Thank you! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,017 #2 Posted July 21, 2025 Service manual help? 2 1 Share this post Link to post Share on other sites
Wheel Horse312-8 2 #3 Posted July 21, 2025 Thank you, got into service manual, just need to loosen/remove the clutch bracket to create enough space for the belt. Share this post Link to post Share on other sites
Wheel Horse312-8 2 #4 Posted July 21, 2025 11 hours ago, gwest_ca said: Service manual help? It did. Thank you for your help! Share this post Link to post Share on other sites
peter lena 9,782 #5 Posted July 21, 2025 @WHEEL HORSE 312-8 also a good opportunity to go over any / every related , MOVEMENT CONNECTION POINT . personally like a penetrating oil , or super lube , hydraulic oil , most of the stuff I see is rust bound or just has dragging movement areas . pete 1 1 Share this post Link to post Share on other sites
MainelyWheelhorse 2,347 #6 Posted July 22, 2025 11 hours ago, peter lena said: @WHEEL HORSE 312-8 also a good opportunity to go over any / every related , MOVEMENT CONNECTION POINT . personally like a penetrating oil , or super lube , hydraulic oil , most of the stuff I see is rust bound or just has dragging movement areas . pete I took apart the brake on my C-141 as I thought something was binding it turns out @peter lena’s advice came in handy. I lubed it and it works great now. 1 Share this post Link to post Share on other sites
peter lena 9,782 #7 Posted July 22, 2025 @MainelyWheelhorse thanks for the shout ! do a lot of functional detailing , very often its simple . washer , lube , enhance every hang up . rarely a one and done , once I did , my pto lever start and related pulley drive set up , I looked at just about everything for a better function , that directed me to plow blade function , another simple GOLD MINE , for functional gain . marvel at its simplicity of swing lever ease. just tinkering , pete 1 1 Share this post Link to post Share on other sites
