graywolf1939
PTO CLUTCH & CONTROL
graywolf1939
My 1980 model C1100 Special is having a PTO problem. The drive belt is OK, the transmission and idler pulley are all OK. The problem seems to be the play in the Pulley Housing. After 45 years of working 3 acres, it is to be expected. I am wondering which of the following parts is MORE suspect and prone to wear and tear than the others. Here are the parts that I suspect: Ball Bearing part 106947, Needle Bearing part number 106769 (6662 or Torrington J-2420), Seal 6663, Bearing Race 6935, Clutch Plate & Facing part number 103817. Any ONE or MORE of these parts may have a COMBINED wear that might cause my issue. When I first engaged the PTO the tractor ran fine, all gears, then after a stop no engagement but a noise like several bee bees in an empty freight car. I went to check the 0.012 spacing for adjustment but there was what I think, too much play to make the proper adjustment. I can take hold of the Pulley Housing and pull it back and forth about a 1/4 inch!!! My expertise is Electrical not mechanical but I know enough to observe, make adjustments and READ manuals especially when I am "out of my elements".  Can the experts on the forum who know a BOATLOAD more than I about this problem give me your expert advice? Thank you in advance,
Richard, aka Dick
Edited by graywolf1939
age of tractor was wrong, 45 years not 25.
Ed Kennell
If the PTO bell is moving 1/4"  front to rear or up and down, the needle bearing has  to be gone or severely damaged.  Adjacent parts are also probably damaged.
Pull the bell off and take some pictures.
graywolf1939
Thank you Ed for your quick response. I intend to take photos tomorrow morning and post them. The movement of the Pulley Housing is in and out as I remember from this morning, but I will recheck this in AM when I disassemble the PTO and take photos.
squonk
The most common thing I see is the outer bearing failing. It's a common # 204RR6
Ed Kennell
This is  good.   As Mike said, likely the thrust bearing and or retaining clip.
wallfish
Hello neighbor, I didn't know (or forgot) anyone else from town was member on here.
Believe you are going to find the problem pretty quickly after removing the PTO bell housing. Most likely that outer bearing like Mike posted
graywolf1939
Hi John, another loyal Wheelhorse customer! I live on Michael Ave.
953 nut
When searching for a suspected bearing failure heat can be your best indication. Don't burn yourself in the process but after running the deck for a short time check all moving parts for heat and you can find the most likely culprit.
graywolf1939
G ood point, the spindle was HOT
gwest_ca
If you happen to remove or disturb the transmission drive pulley you need this. Just in case you were not aware of it.
