FLtractor 223 #1 Posted July 14, 2025 (edited) Is there a independent powered pull behind mower I could pull with my 856 to mow a 5 acre plot? Edited July 14, 2025 by FLtractor Share this post Link to post Share on other sites
wallfish 20,618 #2 Posted July 14, 2025 Gang reel mowers? 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #3 Posted July 14, 2025 There are many on the market. One example https://www.drpower.com/power-equipment/field-brush-mowers/tow-behind Share this post Link to post Share on other sites
Handy Don 17,474 #4 Posted July 14, 2025 , and... If any of the 5 acres is “rough” growth, I’d consider a tow-behind flail of at least 48”. Look for one with an optional cutter bar. 4 Share this post Link to post Share on other sites
ebinmaine 80,718 #5 Posted July 14, 2025 Setting up a home DIY gang mower would be fairly easy. Back in the 70s my family had around 3 acres of grass to mow. My father got several old push mowers. Removed the wheels from one side of all of them. Used angle iron to attach the left of one to the right of the next trailing unit. He used a 60s vintage Ariens 8 HP rear engine riding mower to pull either 4 or 5 in the gang set up. 1 Share this post Link to post Share on other sites
grinchsr 674 #6 Posted July 14, 2025 Swisher mowers 2 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,524 #7 Posted July 14, 2025 1 hour ago, ebinmaine said: Setting up a home DIY gang mower would be fairly easy. Back in the 70s my family had around 3 acres of grass to mow. My father got several old push mowers. Removed the wheels from one side of all of them. Used angle iron to attach the left of one to the right of the next trailing unit. He used a 60s vintage Ariens 8 HP rear engine riding mower to pull either 4 or 5 in the gang set up. You, of all people, know the rules... 1 Share this post Link to post Share on other sites
clueless 3,439 #8 Posted July 14, 2025 You can buy a couple of 60 inch with offset adjustments like Swishers to pull behind along with your deck and get about a 14 foot cut every pass. By the time you spend that much money you could just buy a decent Zero turn even a used one that has been maintained with a 48 inch deck and get it done in a lot less time, a lot less gas and a lot less money. My neighbor across the street cuts his 5 acre field with an older Toro midrange price Z turn with a 42 inch deck, takes him about a hour and a half to two hours depending on how thick it is. Since your in Fl. your going to need to cut yours every week now and for at least another month. Just my four cents worth. Also a Z turn with sharp blades can cut even Bahia grass at around 5 to 6 mile an hour easily. 1 Share this post Link to post Share on other sites
ebinmaine 80,718 #9 Posted July 14, 2025 10 hours ago, SylvanLakeWH said: You, of all people, know the rules... I wish I could find one. 1 Share this post Link to post Share on other sites
wallfish 20,618 #11 Posted July 15, 2025 1 hour ago, adsm08 said: That's A LOT of maintenance!!!!!! and/or a lot of this 1 Share this post Link to post Share on other sites
FLtractor 223 #12 Posted July 15, 2025 14 hours ago, ebinmaine said: Setting up a home DIY gang mower would be fairly easy. Back in the 70s my family had around 3 acres of grass to mow. My father got several old push mowers. Removed the wheels from one side of all of them. Used angle iron to attach the left of one to the right of the next trailing unit. He used a 60s vintage Ariens 8 HP rear engine riding mower to pull either 4 or 5 in the gang set up. So just like the picture someone posted above of the 3 reel mowers? Share this post Link to post Share on other sites
ebinmaine 80,718 #13 Posted July 15, 2025 6 minutes ago, FLtractor said: So just like the picture someone posted above of the 3 reel mowers? Combining @wallfish's with @adsm08 pic. Share this post Link to post Share on other sites
Handy Don 17,474 #14 Posted July 15, 2025 2 hours ago, adsm08 said: Not that I’d even have room to turn a rig like this, but imagine the fuel consumption and the noise?! The neighbors would surely have an opinion about it! Share this post Link to post Share on other sites
peter lena 10,065 #15 Posted July 15, 2025 @FLtractor like @grinchsr tow idea , that would also allow your tractor , to have an easier job of just towing . no added pto drag , but thats also quite a lot of heavy grass to deal with , watched an old J/D 34" rear tires 16 horse sickle blade , acreage , with no effort , then hitch up to a hay thresher , for aeration , and then bail it , just sayin , pete Share this post Link to post Share on other sites
