TonyToro Jr. 2,417 #1 Posted July 3, 2025 Hello all. Possibly going to look at an early 520-H that doesn’t have a swept front end though. It was a barn find and the guy says the engine spins over and has compression. But won’t turn over by the key. Just trying to get some info of what to look for if we do go and look at it. Thanks in advance. 1 1 Share this post Link to post Share on other sites
ri702bill 12,100 #2 Posted July 3, 2025 Look at the condition of the dreaded 9 pin connector. Even if it looks OK, undo it to see the terminals. It might be an unpleasant surprize..... 4 1 Share this post Link to post Share on other sites
lynnmor 8,827 #3 Posted July 3, 2025 8 minutes ago, TonyToro Jr. said: Hello all. Possibly going to look at an early 520-H that doesn’t have a swept front end though. It was a barn find and the guy says the engine spins over and has compression. But won’t turn over by the key. Just trying to get some info of what to look for if we do go and look at it. Thanks in advance. Look for signs of abuse, dirty oil, fittings not greased and anything that the general population destroys. The small blue wire to the starter solonoid should show 12 volts when the key is turned to start, if not try jumping it to the + battery terminal. You could check for voltage at the + terminal of the coil, if it ain't getting 12 volts between it and ground, take the jumper wire that you brought along and jump from + battery terminal. Don't leave it on more than necessary to test fire. If you have voltage at the coil, try pouring a teaspoon of gas down the carburetor and quickly cranking to see if will fire. A 520 takes considerable cranking if it sat for a long time, don't run the starter more than 30 seconds at a time and give it several minutes between tries, you don't want to smoke that expensive starter. 1 1 Share this post Link to post Share on other sites
Handy Don 16,590 #4 Posted July 3, 2025 (edited) Seconding that bringing a good voltmeter, access to a good battery, and some patience to do basic examination and diagnostics can go a long way to making sure you get good value. If you read past threads on 520’s, you’ll learn that they are great machines but they rebel at poor maintenance and abuse. Edited July 4, 2025 by Handy Don 3 1 1 Share this post Link to post Share on other sites
c-series don 11,907 #5 Posted July 3, 2025 I like using a spray bottle with gas and a little two stroke oil mixed in. This way if it does fire you can run it on the bottle until it picks up the fuel. 7 2 Share this post Link to post Share on other sites
peter lena 9,883 #6 Posted July 3, 2025 @ri702bill regular reference to dreaded 9 pin connector , has anyone dared to mount that in a cooler safer spot ? personally look for , a repetitive problem / issue to make a change , you already know what fails , why not eliminate it ? a cooler air flow , wire chafing , etc . would be worth a try . one of the first things I would add / try is a slotted / holed belt guard , it insures heat removal . just my view of a consistent problem , thats like living with bearing failure issues , make a change , pete 4 Share this post Link to post Share on other sites
ri702bill 12,100 #7 Posted July 3, 2025 34 minutes ago, c-series don said: I like using a spray bottle with gas and a little two stroke oil mixed in. This way if it does fire you can run it on the bottle until it picks up the fuel. Unless it has a bad intake valve !!!! 3 Share this post Link to post Share on other sites
JCM 11,151 #10 Posted July 3, 2025 Good luck with it young man. Be safe and have fun with it. 5 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,417 #11 Posted July 3, 2025 More pictures to come soon. 4 Share this post Link to post Share on other sites
squonk 46,550 #14 Posted July 3, 2025 Check all of those bolts on the engine around the PTO bearing. When they loosen you lose all the oil real quick! 4 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,417 #15 Posted July 3, 2025 Now we are home so I can give you the story of the tractor. So this was the PO’s friends tractor. He passed away and it sat for a bit. His barn got cleaned out and the PO bought it from the family. He started to dig into it. He says it cranks over and one cylinder has spark and the other doesn’t. So probably going to dig into this weekend. Oil is not too bad and a tad low. Other then that the tractor is in decent condition with 1058 on the hour meter. Things it will need so far as we can see. Rear lenses for the taillights Gas cap 4 new tires Full tuneup Storm rolling through now. Pics either later or tomorrow morning. 4 Share this post Link to post Share on other sites
TonyToro Jr. 2,417 #16 Posted July 4, 2025 Now here’s some pictures. WARNING: PICTURE HEAVY 😂😂 2 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,417 #17 Posted July 4, 2025 And here’s the deck: 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,417 #18 Posted July 4, 2025 And shes already ready for the shows! 2 Share this post Link to post Share on other sites
WHX?? 56,591 #20 Posted July 4, 2025 Run & drives then? What was the spark issue? 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,417 #21 Posted July 4, 2025 8 minutes ago, WHX?? said: Run & drives then? What was the spark issue? Nope not yet. She just wanted to see how she looked with a tub cart 😂😂 tommorow I may look into her a bit more. If not then definitely Saturday. 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,417 #22 Posted July 4, 2025 20 minutes ago, Chaz54 said: A 1988. How could you tell? Just with the model number or changes with the tractor? 1 Share this post Link to post Share on other sites
Sparky-(Admin) 25,287 #23 Posted July 4, 2025 59 minutes ago, TonyToro Jr. said: How could you tell? Just with the model number or changes with the tractor? Model number tells all: 31-20OE01 1988 520-H Garden Tractor Automatic OnanP220G-I/10540A 1 1 Share this post Link to post Share on other sites
Sparky-(Admin) 25,287 #24 Posted July 4, 2025 Your 9 pin connector looks like it’s toasted. That’ll need to be added to your list of things to address. 1 Share this post Link to post Share on other sites
Lee1977 7,637 #25 Posted July 4, 2025 I could tell it's an1988 because the key switch is on the right side. My 1989 the key switch is on the left side. The first thing is remove all the engine covers. shifter plate and the one below the dash, and rear fender and remove all the dirt and grass. 'Onan's move a lot of air and will pack it full of dirt and grass if not cleaned. Here is a picture of mine at 780 hours. 1 Share this post Link to post Share on other sites
