oliver2-44 10,976 #1 Posted June 29 This starter was in a large box of parts I got from a member by Pony Express from the Big Show. I'm guess its for a vertical shaft engine! Ok experts out there, what does it fit? If someone needs/can use it, let me know. 2 1 Share this post Link to post Share on other sites
squonk 44,608 #2 Posted June 29 I think a push mower. I've seen that style on a few. You pull straight up. 1 Share this post Link to post Share on other sites
ri702bill 10,036 #3 Posted June 29 (edited) 2 hours ago, squonk said: You pull straight up. Hmmm. So that you lift the mower up when you pull the rope and it lands on your foot??? Edited June 29 by ri702bill Share this post Link to post Share on other sites
squonk 44,608 #4 Posted June 29 (edited) 10 minutes ago, ri702bill said: Hmmm. So that you lift the mower up when you pull the rope and it lands on your foot??? You put your size 13 on the deck. Edited June 29 by squonk 2 1 2 Share this post Link to post Share on other sites
adsm08 3,617 #5 Posted June 29 38 minutes ago, ri702bill said: Hmmm. So that you lift the mower up when you pull the rope and it lands on your foot??? It was the olden days. Saftey 3st and all. 3 1 Share this post Link to post Share on other sites
Teddy da Bear62 113 #6 Posted June 29 2 hours ago, squonk said: You put your size 13 on the deck. Gee, I was size 13 when I was 10... 1 1 Share this post Link to post Share on other sites
8ntruck 8,152 #7 Posted June 30 5 hours ago, ri702bill said: Hmmm. So that you lift the mower up when you pull the rope and it lands on your foot??? Sounds like a @Pullstart special. 1 Share this post Link to post Share on other sites
ri702bill 10,036 #8 Posted June 30 7 hours ago, 8ntruck said: Sounds like a @Pullstart special. See - he agrees!! Share this post Link to post Share on other sites
Bill D 2,362 #9 Posted June 30 3.5 -5 HP Briggs vertical shaft engine. I used to have a couple on old Snapper walk behind mowers. 1 1 Share this post Link to post Share on other sites
WheelhorseguyKC 1 #10 Posted July 1 (edited) 3.5HP on push mower. Snappers, MTDs, etc all used it. Not aware of any 5hp with vertical pull. Probably due to the plastic hear not being able handle the extra stress. Rewound hundreds in my your days working on them. Edited July 1 by WheelhorseguyKC 1 Share this post Link to post Share on other sites
RED-Z06 2,679 #11 Posted July 1 Snapper used them alot...had a spot embossed on the deck that said place foot here. 1 1 Share this post Link to post Share on other sites
Handy Don 14,637 #12 Posted July 1 16 hours ago, RED-Z06 said: Snapper used them alot...had a spot embossed on the deck that said place foot here. Even on the side pulls, up until the blade brakes came in, I made a habit of bracing my foot against the mower shell when pull starting. Share this post Link to post Share on other sites
