Docwheelhorse 2,929 #1 Posted June 15, 2025 Hello all, Picking up a GT1848 at show... also picking up 60" deck. Can I hang said 60" deck on the 1848 with straight axle and be able to move it out to back field with limited steering or does steering not work at all / deck doesnt plain fit without forward swept? Thanks Tony Share this post Link to post Share on other sites
nylyon-(Admin) 8,938 #2 Posted June 16, 2025 Tony, thought I recently saw a picture of one of the guys lifting their non-swept axle up by the front to get the deck under it, thought to my self, that is one heavy deck. It was recent though. 1 Share this post Link to post Share on other sites
nylyon-(Admin) 8,938 #3 Posted June 16, 2025 @c-series don 2 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,630 #4 Posted June 16, 2025 Pretty sure you need swept forward set up 4 Share this post Link to post Share on other sites
kpinnc 18,296 #5 Posted June 16, 2025 2 hours ago, Docwheelhorse said: with limited steering or does steering not work at all / deck doesnt plain fit without forward swept? I know it's possible with 6 inch front wheels. Not sure about 8 inch wheels. But in my mind the hard part would be getting the deck under the tractor. 1 Share this post Link to post Share on other sites
Docwheelhorse 2,929 #6 Posted June 16, 2025 10 minutes ago, kpinnc said: I know it's possible with 6 inch front wheels. Not sure about 8 inch wheels. But in my mind the hard part would be getting the deck under the tractor. Interesting thought on 6" fronts... And I thought this deck was meant to be driven over to install 1 Share this post Link to post Share on other sites
Docwheelhorse 2,929 #7 Posted June 16, 2025 1 hour ago, Docwheelhorse said: Interesting thought on 6" fronts... And I thought this deck was meant to be driven over to install I believe and could be wrong on both aspects but 1) deck made by JD for WH. 2) JD made deck so you simply drive tractor over deck to mount... alot of even there bigger stuff is "drive over" 1 Share this post Link to post Share on other sites
Pullstart 70,023 #8 Posted June 16, 2025 We can get it under the tractor. Don’t you worry about that! 2 Share this post Link to post Share on other sites
Bill D 2,870 #9 Posted June 16, 2025 12 hours ago, Docwheelhorse said: I believe and could be wrong on both aspects but 1) deck made by JD for WH. 2) JD made deck so you simply drive tractor over deck to mount... alot of even there bigger stuff is "drive over" I've seen pictures of a 60" deck on a 416 with 6" front wheels, so that may be an option. I've seen other people say those decks were made by Dixie Chopper for Wheel Horse. 1 Share this post Link to post Share on other sites
Docwheelhorse 2,929 #10 Posted June 16, 2025 Ive got a plan to get it out to trailer!! 2 Share this post Link to post Share on other sites
c-series don 11,941 #11 Posted June 16, 2025 I’m the guy with the 416-H with the 60” deck and 6” front wheels. Once I got lazy and set up some blocks then drove over the deck to put it on. I will never do that again, for various reasons. If you were able to get it under your Work Horse you definitely would not be able to steer very much, and it would be a lot of work just to move the deck. I see you have a back rack, but that will be a lot of weight cantilevered off the back of the tractor. Steering may become a problem with that as well. A little pull behind cart may be your best option, or a small front end loader to carry it. 2 Share this post Link to post Share on other sites
kpinnc 18,296 #12 Posted June 16, 2025 2 hours ago, c-series don said: I’m the guy with the 416-H with the 60” deck That was the one I was thinking of. And I agree, driving over the deck is a bad idea. Tried it once, took a couple hours to get it straightened up because the hitch came down in a bad place and jammed all up. 2 Share this post Link to post Share on other sites
johnnymag3 2,646 #13 Posted June 17, 2025 21 hours ago, Docwheelhorse said: Ive got a plan to get it out to trailer!! IM SO GLAD YOU GOT THIS TRACTOR.....MUCH BETTER THAN SITTING UNDER A PINE TREE FOR 15 YEARS !!!! 1 2 Share this post Link to post Share on other sites
Teddy da Bear62 172 #14 Posted June 23, 2025 I put one of my C-195, 60" decks on one of my GT-14s. I also took mid tachamatic from C-195 and moved it to GT-14. (the round bar that is clamped is larger diameter than standard deck). Now before you all get puzzled looks on your faces "🤔" (yes that look). The GT-14 was updated with the latest mid and front tachamatic. It was a struggle to get it all together, but it mowed perfectly! A few years later, tried it again. I could not get the deck on for some reason! It's bothered me ever since. I had enough room to turn the tractor left or right. Extreme turns and the tires would rub on deck. I've always wanted to get a hold of last 60" deck made for 520 and try it on GT-14. To see if it functioned better. Share this post Link to post Share on other sites
Sparky-(Admin) 25,379 #15 Posted June 23, 2025 To anyone following..this is how the 60” deck was transported. My son used my 520-8 and we dragged it the whole 800’ to the trailer on the deck wheels. It kinda striped the field as we went! 1 Share this post Link to post Share on other sites
nylyon-(Admin) 8,938 #16 Posted June 23, 2025 So it can handle a 60” deck! 2 Share this post Link to post Share on other sites
Teddy da Bear62 172 #17 Posted June 23, 2025 2 hours ago, Sparky said: To anyone following..this is how the 60” deck was transported. My son used my 520-8 and we dragged it the whole 800’ to the trailer on the deck wheels. It kinda striped the field as we went! I feel so stupid now!!!! All this time I've carried mine around!! 😰 1 Share this post Link to post Share on other sites
