Red_Texan 4 #1 Posted June 12, 2025 Hello all, 310-8 owner here (and not the most mechanically inclined), wondering what type of oil yall run in your Kohler engines and in the uni-drive transmissions. The engine oil change seems simple enough, as the maintenance literature clearly shows the drain port/fill tube. However I am wanting to drain and refill the transmission (manual NOT hydro) but am unable to locate the drain tube. I see what looks to be a fill hole in the top left side but do not see any drain... Any recommendations on fluids and the possible location of the drain would be greatly appreciated. Additionally, I have seen some guys online saying to run a light diesel mix, then run with the back end lifted to "flush" out but am hesitant to do so.. Thanks in advance. B Share this post Link to post Share on other sites
oliver2-44 11,610 #2 Posted June 12, 2025 Shell Rotella 30 wt or 10w30 for the engine For the transmission use &0w90 gear oil. WAL-MART store brand is good since these are not fancy transmissions. There is an Allen head drain plug under the transmission just in front of the rear hitch. Clean the Allen socket head out good so the Allen wrench goes all the way in and doesn’t strip out. This is a tapered pipe thread Allen. So don’t over tighten when reinstalling. Put some teflon tape on it. There is a hump in the middle of the transmission. So When you drain it lift up the front of the tractor as high as you safely can. If the oil you drain out is whiteish gray or creamy brown it has some water in it. The diesel flush is a good way to clean any watery oil out if needed. 4 1 Share this post Link to post Share on other sites
mrc 1,093 #3 Posted June 12, 2025 engine...summer use---straight 30W rotella 'T' has high zinc i'm told which is good for our old kohlers tranny...put your hand under the back of the tranny and you should feel the drain plug. (near the drawbar) if i remember correctly it uses a 1/4 inch allen wrench. jack up the FRONT of the tractor very high to get the used oil to flow over the casting hump inside the tranny and out the drain port. if oil looks ok then refiil with 90 weight gear oil. 2 qts.. if used oil looks milky flush with kero or diesel and drive around a bit. then drain and fill with the fresh gear oil 2 Share this post Link to post Share on other sites
mrc 1,093 #4 Posted June 12, 2025 oliver2-44 types faster than me! 1 Share this post Link to post Share on other sites
Red_Texan 4 #5 Posted June 12, 2025 Thanks everyone, I found the drain (don't know how I missing that) and will be doing the service tomorrow. I am going to bight the bullet and do the diesel flush, can anyone tell a dummy exactly what and how much to mix. I'm assuming once you run it and drain it (the diesel mix) its understood that trace amounts will still be left and will not harm anything..? Thanks again guys, this forum is a lifesaver! 1 Share this post Link to post Share on other sites
8ntruck 9,021 #6 Posted June 12, 2025 Does the gear oil for the transmission need to be 'safe' for brass? I might be mixing Wheel Horse and 8N transmission oil needs up, though. 1 Share this post Link to post Share on other sites
mrc 1,093 #7 Posted June 12, 2025 Red-Texan, straight diesel 2-2.5 qts. then drive it around in all gears and hi-lo range. then jack up front of tractor and drain. have a beer while it drips. then refill with 2 qts gear oil (90W) trace amounts of diesel will be left but, should not harm anything 1 Share this post Link to post Share on other sites
953 nut 67,225 #8 Posted June 12, 2025 4 hours ago, 8ntruck said: 'safe' for brass? No brass in the Wheel Horse transmission. 1 Share this post Link to post Share on other sites
clueless 3,421 #9 Posted June 12, 2025 10 hours ago, oliver2-44 said: Shell Rotella 30 wt or 10w30 for the engine For the transmission use &0w90 gear oil. WAL-MART store brand is good since these are not fancy transmissions. There is an Allen head drain plug under the transmission just in front of the rear hitch. Clean the Allen socket head out good so the Allen wrench goes all the way in and doesn’t strip out. This is a tapered pipe thread Allen. So don’t over tighten when reinstalling. Put some teflon tape on it. There is a hump in the middle of the transmission. So When you drain it lift up the front of the tractor as high as you safely can. If the oil you drain out is whiteish gray or creamy brown it has some water in it. The diesel flush is a good way to clean any watery oil out if needed. Share this post Link to post Share on other sites
Red_Texan 4 #10 Posted June 12, 2025 9 hours ago, mrc said: Red-Texan, straight diesel 2-2.5 qts. then drive it around in all gears and hi-lo range. then jack up front of tractor and drain. have a beer while it drips. then refill with 2 qts gear oil (90W) trace amounts of diesel will be left but, should not harm anything great, ill git er dun! Share this post Link to post Share on other sites
Handy Don 16,915 #11 Posted June 12, 2025 5 hours ago, clueless said: Put some teflon tape on it I am ok with this advice for 8-speeds, but for hydros that circulate the transaxle oil, I would avoid tape lest a stray piece go where it wouldn’t be welcome. 2 Share this post Link to post Share on other sites
pfrederi 20,823 #12 Posted June 12, 2025 40 minutes ago, Handy Don said: I am ok with this advice for 8-speeds, but for hydros that circulate the transaxle oil, I would avoid tape lest a stray piece go where it wouldn’t be welcome. And no RTV in hydros either 1 Share this post Link to post Share on other sites
Red_Texan 4 #13 Posted June 12, 2025 21 hours ago, oliver2-44 said: Shell Rotella 30 wt or 10w30 for the engine For the transmission use &0w90 gear oil. WAL-MART store brand is good since these are not fancy transmissions. There is an Allen head drain plug under the transmission just in front of the rear hitch. Clean the Allen socket head out good so the Allen wrench goes all the way in and doesn’t strip out. This is a tapered pipe thread Allen. So don’t over tighten when reinstalling. Put some teflon tape on it. There is a hump in the middle of the transmission. So When you drain it lift up the front of the tractor as high as you safely can. If the oil you drain out is whiteish gray or creamy brown it has some water in it. The diesel flush is a good way to clean any watery oil out if needed. ANY Rotella T oil I am finding is saying its HD diesel engine oil.. are we talking about the same thing? Does it matter? The only reason I am getting so specific, is the manual calls for "API Service SF" oil exclusively. After a little research it looks like this is a thing of the past and is no longer considered safe to use due to it not handling modern and offering sludge protection . I am hoping that modern OIL does not have any additional additives that the engine shouldn't have..? I know I am getting caught up in the weeds on this but I need this machine to last trying to do everything right the first time and just make it part of my normal maintenance routine. Share this post Link to post Share on other sites
8ntruck 9,021 #14 Posted June 12, 2025 (edited) Rotella T oils are designed for diesels. In general terms, that oil has a better extreme pressure package that also helps the flat tappers and rod bearings in our now antique Kohlers and Onans. The current passenger car oil is designed for roller tappets and tighter clearance journal bearings, which also might have some sort of lube enhancing coatings. Edited June 13, 2025 by 8ntruck 2 Share this post Link to post Share on other sites
oliver2-44 11,610 #15 Posted June 13, 2025 The Rotella diesel oil comes closer to meeting the additives of the old spec oil. 1 Share this post Link to post Share on other sites
Red_Texan 4 #16 Posted June 13, 2025 1 hour ago, oliver2-44 said: The Rotella diesel oil comes closer to meeting the additives of the old spec oil. copy that, just wanted to be sure. Thanks! Share this post Link to post Share on other sites
lynnmor 8,875 #17 Posted June 13, 2025 Of course you can buy oil made for your gasoline engine and know that you have the correct oil. Kohler and Kintix are two. Share this post Link to post Share on other sites
Anderson-310-8 5 #18 Posted September 8, 2025 Hey guys! Just got a 310-8 a few days ago and wanting to restore it. Little rough but runs drives and seems all original. Was kept outside unfortunately for a few years but still used here and there. I am going to do the flush on the trans and wanted to know how it went for OP. Checking the dipstick I can See it’s milky. Getting fresh tires in the mail tomorrow so wanna get it drained today and do the run with diesel tomorrow afternoon. thanks! Very excited for this machine and love this forum seems super positive and informative 😎 2 Share this post Link to post Share on other sites
Handy Don 16,915 #19 Posted September 8, 2025 310-8 is a “base” model, but is tough and strong. It’ll handle that 37” deck without strain and do a credible job with the box blade. Seeing the shreds of rubber remaining on those rims, I’d give a careful check before mounting new tires--no dents, bead seat smooth and clean, valves well sealed to the rim? 310-8 was my first WH some years ago. It has moved on but is still in service. Share this post Link to post Share on other sites
Anderson-310-8 5 #20 Posted September 8, 2025 Got a (good buddy) local tire shop throwing them on now actually, just finished a oil change, dumping trans fluid and added diesel to do a flush run once I get the call the tires are ready, he said he’d round the rims back out if needed. blades are beyond shot gonna get a new set soon. For $275 with the blade I can’t complain! Also gives me a new project to strip it down and rebuild it up 😃 2 Share this post Link to post Share on other sites
kpinnc 18,721 #21 Posted September 9, 2025 On 6/12/2025 at 9:39 PM, lynnmor said: Of course you can buy oil made for your gasoline engine and know that you have the correct oil. Kohler and Kintix are two. Vanguard too. Share this post Link to post Share on other sites
lynnmor 8,875 #22 Posted September 9, 2025 (edited) 2 hours ago, kpinnc said: Vanguard too. Vanguard oils have an API rating of SN. In order to get that rating, lower levels of ZDDP are necessary. Information on their website is sketchy. https://www.vanguardpower.com/emea/en_gb/service-and-support/faqs/browse/oil-recommendations.html Edited September 9, 2025 by lynnmor Share this post Link to post Share on other sites
Retired Wrencher 6,767 #23 Posted September 9, 2025 On 6/12/2025 at 3:55 AM, mrc said: Red-Texan, straight diesel 2-2.5 qts. then drive it around in all gears and hi-lo range. then jack up front of tractor and drain. have a beer while it drips. then refill with 2 qts gear oil (90W) trace amounts of diesel will be left but, should not harm anything have a beer while it drips. < I like that comment mrc: 2 Share this post Link to post Share on other sites
Anderson-310-8 5 #24 Posted September 9, 2025 @lynmor ended up going with the rotella heavy duty that I see people recommend in this forums. Found a small oil leak digging in last night waiting for the tire shop, time to jump online and get some new gaskets. Will most likely end up rebuilding the motor once I start opening it up. Share this post Link to post Share on other sites
953 nut 67,225 #25 Posted September 9, 2025 20 hours ago, Anderson-310-8 said: Checking the dipstick I can See it’s milky. 310-8 is a great Wheel Horse. I have had one as my primary mowing machine for many years and love it. There is a rubber boot on the shift lever that is likely to be in need of replacement. Since your 310's previous owner left it outside rain water got into the transaxle causing the milky oil. The rubber boot can be found on or from one of our vendors, https://wheelhorsepartsandmore.com/product/2-3577-reproduction-wheel-horse-shifter-boot/ Share this post Link to post Share on other sites
