mrc 1,109 #1 Posted June 11, 2025 local guy calls me today. he got my number from the auto parts store. they know i'm a wh guy. local guy says he has a 310-8 with 37 inch sd deck. i never had a 37 sd deck so i do not know where to send him for a belt. he said it was a 6 sided belt. from the cross chat on RS i said "yeah i think that is right" i urged him to join this site. i told him i would try and get an answer from you guys and report back. thank you in advance for any help regards mike Share this post Link to post Share on other sites
Brockport Bill 2,454 #3 Posted June 11, 2025 i have had a 37" s.d. deck with my 312-8 since 1989 -- terrifc mower - mine has bagger also -- belt is # 111178 - be sure he checks the mule -- be sure it is correct pulleys for that belt. Bill Share this post Link to post Share on other sites
Brockport Bill 2,454 #4 Posted June 11, 2025 one other note Mike for him - i have lift blade on mine for the bagger to function properly -- if he has bagger which is what those 37s are designed for ( although not required )... then he will want that lift blade design - - Also be prepared .. the belts are $$ expensive - also suggest he carefully read the manual for the belt deflection between mule and pto at 1 inch so that belt does not "roll over" or "twist" or it will wear quickly as well as not function properly. Share this post Link to post Share on other sites
Brockport Bill 2,454 #5 Posted June 11, 2025 suggest he have a manual Share this post Link to post Share on other sites
Brockport Bill 2,454 #6 Posted June 11, 2025 belt routing - important 1 Share this post Link to post Share on other sites
Pullstart 71,085 #7 Posted June 11, 2025 It’s not just the length here, that’s a 4 sided belt! Share this post Link to post Share on other sites
dcrage 636 #8 Posted June 13, 2025 On 6/11/2025 at 4:28 PM, Pullstart said: It’s not just the length here, that’s a 4 sided belt! Ahhh……,,I think you meant to say the belt is 6 sided!!! 1 Share this post Link to post Share on other sites
Pullstart 71,085 #9 Posted June 13, 2025 7 hours ago, dcrage said: Ahhh……,,I think you meant to say the belt is 6 sided!!! yeah, I know it’s wild! You’re correct Share this post Link to post Share on other sites
