kthack657 329 #1 Posted June 8, 2025 (edited) Hi all, looking for some information for a kt19. We are working on a tractor and It was on a test tank due to a collapsed line. Well we replaced the line and it looks like the fuel pump is not working. I want to put on an electric fuel pump, but want to make sure to get one that will work with an opposed twin. Any help would be appreciated...it is a hydro so hard to move now that we parked it to fix the fuel line. Thank you all!! Edited June 8, 2025 by kthack657 Share this post Link to post Share on other sites
pfrederi 19,875 #2 Posted June 8, 2025 There are many foreign pumps some times they work some times they don't I use Facet posi flo Made i in USA Get one with 4psi or less. 3 Share this post Link to post Share on other sites
953 nut 64,108 #3 Posted June 8, 2025 Location is very important, electric fuel pumps are much better at pushing fuel than they are at pulling it so the pump should be located lower than the tank outlet. Your electrical connection can be attached to the hour meter line which is fuse protected and only has power when the key is on. Share this post Link to post Share on other sites
peter lena 9,763 #4 Posted June 8, 2025 @kthack657 have a couple of CARBOLE MICRO ELECTRIC FUEL PUMPS ON MY TRACTORS . low pressure 2-3.5 GPH , also hooked them up to a single led green dash light to verify their function , just a personal idea , not really necessary, very solid , dependable , pete Share this post Link to post Share on other sites
ebinmaine 77,324 #5 Posted June 8, 2025 1 hour ago, kthack657 said: Hi all, looking for some information for a kt19. We are working on a tractor and It was on a test tank due to a collapsed line. Well we replaced the line and it looks like the fuel pump is not working. I want to put on an electric fuel pump, but want to make sure to get one that will work with an opposed twin. Any help would be appreciated...it is a hydro so hard to move now that we parked it to fix the fuel line. Thank you all!! @kthack657 I keep a list of the part numbers I've seen folks recommend over the years. Facet 60245 or 60304. Mr. Gasket 42s. Carter P4070. I use and recommend the Facet. I recommend buying from Aircraft Spruce Co.. https://www.aircraftspruce.com While there on the site get a few good quality tank shutoffs, some tank grommets, and also the good name brand priming bulbs. 2 Share this post Link to post Share on other sites
kthack657 329 #6 Posted June 10, 2025 On 6/8/2025 at 6:46 PM, 953 nut said: Location is very important, electric fuel pumps are much better at pushing fuel than they are at pulling it so the pump should be located lower than the tank outlet. Your electrical connection can be attached to the hour meter line which is fuse protected and only has power when the key is on. I think this maybe an issue, it is on a C type tractor where the tank is under the seat pan, but have had success on other tractor similar, just not an opposed twin engine... 1 Share this post Link to post Share on other sites
953 nut 64,108 #7 Posted June 10, 2025 I have a 418-C with the Kohler Twin and under-seat tank. I have the electric pump mounter to the frame near the foot rest and it works well. 1 Share this post Link to post Share on other sites
kthack657 329 #8 Posted June 13, 2025 We picked a random pump, and seems to do the job. Yay it functions again!! 2 Share this post Link to post Share on other sites
bds1984 1,506 #9 Posted June 15, 2025 On 6/8/2025 at 5:41 PM, kthack657 said: Hi all, looking for some information for a kt19. We are working on a tractor and It was on a test tank due to a collapsed line. Well we replaced the line and it looks like the fuel pump is not working. I want to put on an electric fuel pump, but want to make sure to get one that will work with an opposed twin. Any help would be appreciated...it is a hydro so hard to move now that we parked it to fix the fuel line. Thank you all!! I had a failed fuel pump on a series II KT17 a few years ago. My first instinct was to replace it with a low pressure, electric pump mounted under the seat as many here have advised. Well, I didn't like it because it drove my volt meter nuts with it pinging back and forth faster than tennis match. I could have ran it as is, but I adapted a vacuum style pump that ran off of the front valve cover. 1 Share this post Link to post Share on other sites
953 nut 64,108 #10 Posted June 15, 2025 9 hours ago, bds1984 said: I had a failed fuel pump on a series II KT17 a few years ago. My first instinct was to replace it with a low pressure, electric pump mounted under the seat as many here have advised. Well, I didn't like it because it drove my volt meter nuts with it pinging back and forth faster than tennis match. I could have ran it as is, but I adapted a vacuum style pump that ran off of the front valve cover. What size wire did you use and where was the fuel pump wiring connected? I have four Wheel Horses with electric pumps and have not seen this volt meter problem. Share this post Link to post Share on other sites
bds1984 1,506 #11 Posted June 16, 2025 On 6/15/2025 at 6:59 AM, 953 nut said: What size wire did you use and where was the fuel pump wiring connected? I have four Wheel Horses with electric pumps and have not seen this volt meter problem. I used 14 gauge with a 10 amp fuse. I should have recorded a video of it. Perhaps I had a bad one, but for now, I just use a squeeze bulb. Share this post Link to post Share on other sites
953 nut 64,108 #12 Posted June 17, 2025 14 hours ago, bds1984 said: Perhaps I had a bad one, Share this post Link to post Share on other sites
