pylp 6 #51 Posted June 11 The left most valve is the intake ? And you know anywhere to get a kit to replace that and rebuild ? I'm in Ohio Share this post Link to post Share on other sites
RED-Z06 2,689 #52 Posted June 11 24 minutes ago, pylp said: Lmao ok so what's next could I fix the bent valve I wish Ive done that sooner All in diagnosis, in the first post you said it had compression and we started down the path to spark, then fuel. You will need to pull thr carb, breather cover, compress the spring, extract the keepers, and pull the valve. A new valve will be sourced and will at minimum need to be lapped in, and valve lash set. 2 Share this post Link to post Share on other sites
pylp 6 #53 Posted June 11 (edited) Split the case right down to the crank to replace valves and retainers just wondering if anyone has a engine schematic for model K3415 spec 71128a and any good place to order valve kits Edited June 11 by pylp Share this post Link to post Share on other sites
RED-Z06 2,689 #54 Posted June 11 4 minutes ago, pylp said: Split the case right down to the crank to replace valves and retainers just wondering if anyone has a engine schematic for model K3415 spec 71128a and any good place to order valve kits You dont have to open it up to do valves, don't even really have to pull it off the frame. Share this post Link to post Share on other sites
Handy Don 15,108 #55 Posted June 11 1 hour ago, RED-Z06 said: You dont have to open it up to do valves, don't even really have to pull it off the frame. You do need a valve spring compressor, but they are not expensive and if you’ve got enough mechanical skill to open an engine, they you’ll have no trouble. Share this post Link to post Share on other sites
pylp 6 #56 Posted June 12 Ok does anyone have any schematics on it to do the valves I do have a valve compressor tool and any sites to get valve kit Share this post Link to post Share on other sites
pfrederi 19,208 #57 Posted June 12 1 hour ago, pylp said: Ok does anyone have any schematics on it to do the valves I do have a valve compressor tool and any sites to get valve kit Have you downloaded the K series service manual??? 1 Share this post Link to post Share on other sites
pylp 6 #58 Posted June 12 Thank you very much I have been referencing to a different manual but this one is better and where to get parts ? Share this post Link to post Share on other sites
953 nut 62,958 #59 Posted June 13 15 hours ago, pylp said: where to get parts ? Several sellers on have NOS Kohler parts, A-Z Tractor https://www.a-ztractor.com/, Jack's https://www.jackssmallengines.com/manufacturer/kohler Share this post Link to post Share on other sites
pylp 6 #60 Posted July 3 Fixed with valves and special valve tool from amazon tool was 14 new valves and springs and retainers were 40 used out them in it starts now runs but dies when trying to mow it'll sit and run just fine tho till I shut it off Share this post Link to post Share on other sites
