Teddy da Bear62 172 #1 Posted June 3, 2025 (edited) I'm giving a friend of mine a 633. It's in excellent shape having been restored somewhere in the past. He's been chomping at the bit (horse pun) to get a good look at it. It's been in storage for at least 15 years in a second story in my barn. Well today was the day we attempted to roll it out. It would NOT roll!!! It was definitely in neutral. Brake was not on .... But wouldn't roll! It acted as if it was in gear, but wasn't. I attempted to run it through its gears and it would not shift! Isn't shifting accomplished with a series of "forks" in tranny? What could be the problem guys? As always with my horses "ran when parked". Edited June 3, 2025 by Teddy da Bear62 3 Share this post Link to post Share on other sites
Ed Kennell 47,375 #2 Posted June 3, 2025 Water in the trans that froze and broke something??????????? 8 Share this post Link to post Share on other sites
Pullstart 71,259 #3 Posted June 3, 2025 If he’s willing to patient, it might be worth filling the transmission up completely with diesel or kerosene, and letting it sit a while. I had a stuck engine a while back, and filled every part of it with used engine oil. I put it away for one year and managed to free it up enough to fire it! 9 Share this post Link to post Share on other sites
Teddy da Bear62 172 #4 Posted June 3, 2025 10 minutes ago, Ed Kennell said: Water in the trans that froze and broke something??????????? I can't see how. Barn doesn't leak. Unless cat peed in tranny? 😂😂😂 6 Share this post Link to post Share on other sites
pfrederi 21,156 #5 Posted June 3, 2025 14 minutes ago, Teddy da Bear62 said: I can't see how. Barn doesn't leak. Unless cat peed in tranny? 😂😂😂 The amount of condensation inside a tranny is surprising and after 15 years of widely variable temps and humidity who knows what rusted in place 7 Share this post Link to post Share on other sites
WHX?? 58,157 #6 Posted June 3, 2025 Don't force it can break a shifter fork or something. Only thing you can do is pull the shifter and look for the H pattern. Maybe stuck in two gears from the kids playing on it. Screwdriver to get in in neutral. 7 Share this post Link to post Share on other sites
stevasaurus 23,856 #7 Posted June 3, 2025 Hey Teddy, it's been a long time since you have been on here. Good to hear from you. Pull the shifter and look in there and see what it looks like (see pick above). I would think nothing is broke, just surface rust keeping things form moving. I would not try to start it with the drive belt on. You could fill it up with diesel and keep trying to move the shifter once in a while. But, you know, the best thing is to drop the trans and open it up. You will probably only need the case gasket and a wire brush. BTW...How are you doing these days??? 5 Share this post Link to post Share on other sites
Teddy da Bear62 172 #8 Posted June 4, 2025 (edited) 8 hours ago, WHX?? said: Don't force it can break a shifter fork or something. Only thing you can do is pull the shifter and look for the H pattern. Maybe stuck in two gears from the kids playing on it. Screwdriver to get in in neutral. How do you manipulate it with screwdriver? Forks move pretty easily? I will try to post pictures of it. Wait! I got kids in my barn? 🤔🤣🤣🤣 I know how you guys LOVE your photos.....lol Edited June 4, 2025 by Teddy da Bear62 3 1 Share this post Link to post Share on other sites
WHX?? 58,157 #9 Posted June 4, 2025 (edited) 15 minutes ago, Teddy da Bear62 said: How do you manipulate it with screwdriver? Forks move pretty easily? Pry on the blocks that the shifter ball rides against. Yes the forks should move somewhat easily. You may have have to jiggle the input pully and rock the tractor abit to facilitate the forks movement. After you pull the shifter look at the forks. Have a flash light with you. They should be centered like the pic. One of the blocks should always be centered. The other to the left or right but never both to the left or right at the same time. BTW please don't start a thread with XXX give away... has a tendency to put the boys here in a frenzy when they think a tractor is free... Edited June 4, 2025 by WHX?? 5 Share this post Link to post Share on other sites
oliver2-44 11,753 #10 Posted June 4, 2025 10 hours ago, WHX?? said: BTW please don't start a thread with XXX give away... has a tendency to put the boys here in a frenzy when they think a tractor is free... Kind of like a school of Piranha when fresh meat is thrown in. OK Maybe more like a flock of Yard Birds when you throw out the left over fishing worms. 4 Share this post Link to post Share on other sites
Teddy da Bear62 172 #11 Posted June 4, 2025 3 hours ago, oliver2-44 said: Kind of like a school of Piranha when fresh meat is thrown in. OK Maybe more like a flock of Yard Birds when you throw out the left over fishing worms. Heyyyyyy!! I had to make sure my mundane post would get some attention !! Right?? Free wheel horse is usually an eye grabber! 🤣🤣🤣 Ok.... News is not good. Pulled the shifter. It was indeed in neutral. Two forks toward front of tractor move. Rear two forks will not budge. Tranny was dry as a bone. We are getting kerosene next and filling it up. And I am giving the tractor to my friend. It's a free one! 2 1 Share this post Link to post Share on other sites
Bill D 3,156 #12 Posted June 4, 2025 23 hours ago, Pullstart said: If he’s willing to patient, it might be worth filling the transmission up completely with diesel or kerosene, and letting it sit a while. I had a stuck engine a while back, and filled every part of it with used engine oil. I put it away for one year and managed to free it up enough to fire it! Would a fill up with ATF help loosen things? 2 Share this post Link to post Share on other sites
WHX?? 58,157 #13 Posted June 4, 2025 2 minutes ago, Teddy da Bear62 said: mundane post would get some attention !! Right?? Lol yer a hoot Teddy ... 3 minutes ago, Teddy da Bear62 said: getting kerosene next and filling it up. Yep I bet some moisture just got in there and seized her up ... hopefully not to serious. Squirt some rust blaster down in there too and roll it around. Maybe some ATF & acetone. Have yer buddy do a full blown flushing on it it gets running & driving. 2 Share this post Link to post Share on other sites
WHX?? 58,157 #14 Posted June 4, 2025 1 minute ago, Bill D said: Would a fill up with ATF help loosen things? Beat me to it. ... I got a tranny now that is like that input pully won't even move. Ill put some ATF in it as it sits on the shelf ... maybe help loosen it up for easier disassembly for the next guy. 1 Share this post Link to post Share on other sites
Teddy da Bear62 172 #15 Posted June 4, 2025 Never heard of *rust buster". I'll try to find it. Yes, friend mentioned flushing it. 1 Share this post Link to post Share on other sites
stevasaurus 23,856 #16 Posted June 4, 2025 Acetone may not be good for the seals. You will want to replace those seals anyway, but you dont want the trans leaking while it is lubing itself. 3 Share this post Link to post Share on other sites
Teddy da Bear62 172 #17 Posted June 4, 2025 2 hours ago, WHX?? said: Lol yer a hoot Teddy ... Yep I bet some moisture just got in there and seized her up ... hopefully not to serious. Squirt some rust blaster down in there too and roll it around. Maybe some ATF & acetone. Have yer buddy do a full blown flushing on it it gets running & driving. I hope you can specify this "rust buster" you are speaking of? I came across several types. 1 Share this post Link to post Share on other sites
Teddy da Bear62 172 #18 Posted June 6, 2025 We filled it with kerosene. Filled is maybe a misnomer..... Didn't stay filled long ..... Axle seal is leaking badly. But I will catch it and keep refilling! (a whole damned year they say.......grrrrr) I will start the ritual chant... "Is it done yet?" 1 3 Share this post Link to post Share on other sites
Pullstart 71,259 #19 Posted June 6, 2025 29 minutes ago, Teddy da Bear62 said: We filled it with kerosene. Filled is maybe a misnomer..... Didn't stay filled long ..... Axle seal is leaking badly. But I will catch it and keep refilling! (a whole damned year they say.......grrrrr) I will start the ritual chant... "Is it done yet?" If you have a large enough tub, I’ve heard of a trick, where you pump fluids into the top, let it drain through and keep the pump running. These people even had a nozzle they made, to spray the fluids into a spherical pattern to maximize coverage. A guy could run that fluid back into the shifter, and let it drain out. 1 Share this post Link to post Share on other sites
Teddy da Bear62 172 #20 Posted June 6, 2025 Now you're getting to fancy .... 😂😂😂 We are simple country folk. We will crack open tranny if need be. 😊 1 Share this post Link to post Share on other sites
WHX?? 58,157 #21 Posted June 6, 2025 34 minutes ago, Teddy da Bear62 said: Axle seal is leaking badly. That's kinda normal since kerosene is much thinner than 80 90. 1 Share this post Link to post Share on other sites
WHX?? 58,157 #22 Posted June 6, 2025 1 minute ago, Teddy da Bear62 said: Now you're getting to fancy .... 😂😂😂 We are simple country folk. Actually not a bad idea Kev. Problem for me would be lifting it in and out of the tub... I can't even haul my own carcass in and out of a tub... 1 Share this post Link to post Share on other sites
Teddy da Bear62 172 #23 Posted June 6, 2025 You all be good or won't show ya a "prototype" D-250. Share this post Link to post Share on other sites
Ed Kennell 47,375 #24 Posted June 6, 2025 3 hours ago, Teddy da Bear62 said: Didn't stay filled long ..... Axle seal is leaking badly. Put an external seal on it. A balloon or condom and a couple rubber bands. Share this post Link to post Share on other sites
Teddy da Bear62 172 #25 Posted June 6, 2025 39 minutes ago, Ed Kennell said: Put an external seal on it. A balloon or condom and a couple rubber bands. Used condom or new? 🤔 The used ones are all stretched out of shape!! 😂😂😂😂 1 Share this post Link to post Share on other sites
